M2 Technical Topics > Cosmetic Modifications > M Performance Carbon Winglets Installation Question
      08-29-2016, 01:29 AM   #1
dacat
Drives: M2
Hey fellow M2 owners.
I have ordered the MPerformance carbon side and front winglets. (http://ind-distribution.com/ind/bran...ar-winglet-set) They come with plastic clips. I think there's 5 clips per side. They also come with pre-applied double sided tape.
On the car there is no holes for these clips to go into, but on the winglets there are 5 holes.
Does fitting these require drilling into the car or is the tape sufficient? For people who've had these dealer fitted, do they use the 5 clips in addition to the double sided tape?
Does anyone have a photo of the underside of the carbon winglet to show how they clip in?
Thanks
      11-25-2016, 04:52 AM   #2
Icsunonove
Argentina
10
Drives: M2 BSM
Thanks
anyone?
      11-25-2016, 06:26 AM   #3
jc9elfer
32
Drives: '16 BSM M2, 08 Porsche 911
Originally Posted by Icsunonove View Post
anyone?
Don't know for sure, I didn't do the Winglets. That said, I did do the M2 spoiler. It was installed with only the tape.... if that helps to answer your question.
      11-25-2016, 08:02 AM   #4
BAN_M2C
BAN_M2C's Avatar
4185
Drives: 991.2 Porsche GT3, BMW E46 M3
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
http://f87.bimmerpost.com/forums/att...7&d=1457195266
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      12-29-2016, 11:08 AM   #5
photos_by_ronnie
37
Drives: 2016 M2 DCT, 2017 X1 M Sport
Anyone figure out yet if those 5 tabs are necessary? I don't read or speak German, that link is useless.
      12-29-2016, 11:42 AM   #6
CommitConfirm
475
Drives: The Bus
It does show you need to drill some holes and use the supplied rivets. A quick google translate will provide further detail if still required.
      12-29-2016, 11:46 AM   #7
photos_by_ronnie
37
I was hoping someone with these side winglets could say if they've been okay without using the rivets. They seem kinda useless anyway, and I'd prefer not drilling..
*Edit* Google translate doesn't seem to work on a .pdf, at least not on my computer.
      12-29-2016, 12:31 PM   #8
Zippster
Zippster's Avatar
460
Drives: 17 BMW M2
I know what you mean about drilling into your car, but if it were me I would not trust just the tape, if they provide rivets, I bet you need to use them or one day you will discover that you are missing one of those expensive winglets.
      12-29-2016, 01:18 PM   #9
nd2002
nd2002's Avatar
179
Drives: 2017 M2
Just copy paste the steps into Google translate...
      12-30-2016, 10:23 AM   #10
photos_by_ronnie
37
Was able to get google translate to work..but that .pdf is just awful, I didn't end up using the instructions at all. Luckily it's really straightforward, no need to mark the holes or anything. Just use all the bolts that are already on the car to initially attach it, then drill the holes, and pop up in the rivets. Except the rivets are garbage, and I found much easier and more solid push tabs at O'Reillys for a few bucks. All in all, a pretty easy install once I realized the supplied rivets just weren't going to work.
      12-30-2016, 04:31 PM   #11
Icsunonove
Argentina
10
Drives: M2 BSM
Hi,
Could you provide the push tabs link @ O´Reillys ?
thnks
      12-30-2016, 05:21 PM   #12
photos_by_ronnie
37
Hi,
thnks
I just bought some 1/4" push tabs in the store, not sure where they would be online. But literally any 1/4" push tab will work 10x better than the rivets BMW supplied.
      12-30-2016, 05:35 PM   #13
CommitConfirm
475
Drives: The Bus
Was able to get google translate to work..but that .pdf is just awful, I didn't end up using the instructions at all. Luckily it's really straightforward, no need to mark the holes or anything. Just use all the bolts that are already on the car to initially attach it, then drill the holes, and pop up in the rivets.....
That's essentially what the instructions say
      12-31-2016, 09:12 PM   #14
Zippster
Zippster's Avatar
460
Drives: 17 BMW M2
Just curious, did you pull on the winglets a bit to ensure you have a solid mounting with the push tabs? At 80 MPH or so the slipstream will be pulling on them. Are they the plastic type with expanding legs when the pin is pushed in?
      01-02-2017, 05:57 AM   #15
photos_by_ronnie
37
I did tug on them a little before driving, they felt super solid. I've already hit 120 mph with the winglets on, no issues so far. The push pins I used were the plastic type that expanded, pretty sure that's how most push pins work. The ones I used were basically the same as the ones BMW used for the OEM rear diffuser.
      01-02-2017, 02:10 PM   #16
Zippster
Zippster's Avatar
460
Drives: 17 BMW M2
That sounds good, I'm sure it will be fine then.
      01-07-2017, 03:46 PM   #17
M2GB
71
Drives: 911 and M2
Is it the side blade that needs drilling or the actual car?!
      01-07-2017, 03:51 PM   #18
photos_by_ronnie
37
The actual car is drilled into several times for the side and front winglets.
      01-07-2017, 03:54 PM   #19
M2GB
71
Drives: 911 and M2
The lower side skirts are plastic so you drill into that?
Do you line up the winglet and drill through that to create the holes?
      01-07-2017, 04:52 PM   #20
photos_by_ronnie
37
I installed the winglets with tape and the pre existing bolts, then the next day I drilled the holes and put in the push tabs I bought. You really can't mess up with the drilling, only downside is you can't take it off later.
      01-07-2017, 10:12 PM   #21
jc9elfer
32
I read German, it says you have to "Drill" the 5 holes with 6mm drill bit.
      01-24-2021, 07:12 PM   #22
MaximilianB
Drives: 2021 BMW M2 Competition
Reviving this thread with a new question:
Does anyone know if self-tapping screws would suffice instead of the rivets or push tabs?
m2
