BMW M2 Forum > BMW M2 CS Model > Introducing the BMW M2 CS Racing
      11-13-2019, 08:03 AM   #45
Megator
Megator's Avatar
518
Drives: M2 Competition
Originally Posted by Poochie View Post
A set lockup is more race track friendly when the brake based assist is tuned out.
Any source for this? As far as I know the RWD M cars do not have brake based torque vectoring (unless you count TC and DSC but that is not really the same as it is there to help you maintain control not corner harder).
They have a diff that can lock from 0-100% that's it. This is already awesome as it helps you corner harder without the drawbacks of a fixed ratio diff,
M2C is super easy to drift stock BTW. Im a complete noob and this was me on the 1st time out on the drift track.
https://drive.google.com/file/d/1xaU...gSezGC3Qb/view
M2Crew220.50
      11-13-2019, 08:48 AM   #46
vale007
80
Drives: e82 1 M coupe
is this in aschheim germany?
      11-13-2019, 09:10 AM   #47
No Boost
enthusiasm > practicality
No Boost's Avatar
4027
Drives: 987 CS | G35x
Originally Posted by DriverDaily View Post
I just want that 120liter (32 gallon) gas tank for my M2C
That's about 200 lbs of fuel. A reason why the tanks are so small on these cars is because, I'm thinking, BMW is very aware on how heavy the M2 is on its own. We only add 75 lbs when filling up (assuming it's 12.5 gallon capacity).
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
///M TOWN20365.50
      11-13-2019, 09:42 AM   #48
Altra
267
Drives: 2016 AW M2
Well that looks like a ton of fun. I need to find one of these in Cali.
      11-13-2019, 10:10 AM   #49
Megator
Megator's Avatar
518
Nein bei den Nachbaren im Westen wenn es klappt, gehe ich im Dezember nach Weeze.
      11-13-2019, 12:00 PM   #50
Ghostriderf80
840
Drives: Just a Porsche
I am curious how much shop support you require for that car. Starts at 95K EU.
Do you need air compressor for jacks, tire change, etc... shop to change the springs. Can you have it for track days. Instead of a series of racing. How much tools do you need to run it successfully, fuel filling.?
So interested in it. It makes sense.
Appreciate 3
troym4.50
FormulaMMM3662.50
      11-13-2019, 08:04 PM   #51
Big boi m5
No_Country
322
Drives: 135i
A "Mechanical Drexler limited-slip differential with pre-load and separate cooling."
Interesting.. I wonder why it doesn't come with the electronic torque-vectoring setup that all the M car currently uses.
This unit is akin the M Performance LSD the regular series BMW offers as an aftersale option..
Probably becuase it eats up pads
      11-20-2019, 12:18 PM   #52
TeamPhenix
TeamPhenix's Avatar
Drives: Isetta,Z8,M5,M2C,M240iR,X7
2016 BMW M240iR  [0.00]
2019 BMW M2c  [0.00]
Originally Posted by Conissah View Post
Originally Posted by MetalMK View Post
The non adaptive headlights look cute but doesn't fit with the angular grills imo.
Also why does it have less horsepower?
For the headlights, it's most likely a weight savings thing
I don't see why, the M240i Racing uses Adaptive LED Headlights without concern for weight reduction.
I believe they are concerned with weight reduction. If you look close enough you can see the headlights aren't for street use. I'm not sure what the exact difference is from the street car, but weight reduction and deletion of the dipping beam may be one.
Poochie9107.50
      12-08-2019, 03:56 PM   #53
Artemis
Moderator
Artemis's Avatar
29669
Drives: BMW M2 Competition
///M is art Artemis
      12-10-2019, 09:17 AM   #54
Bee Pee
Bee Pee's Avatar
1784
Drives: AW M2 DCT
Don't all M2 have faux inner headlights ?
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      12-10-2019, 09:43 AM   #55
Anthony1s
756
Drives: 2018 Mineral Grey M2
The M2 CS Racing in the video below your comment has the adaptive headlights. Not sure if they have full functionality, but they have the hexagonal angel rings.
      12-10-2019, 10:01 AM   #56
Poochie
Luxury at the redline :)
Poochie's Avatar
9108
Drives: 2016 M2
Sorry about the delayed response, I've just now notice you had tagged me..
Anyways, on the subject of LSDs; I've also notice that the Porsche GT3 uses a standard locking diff, instead of their renowned torque-vectoring unit they currently offer. I believe torque vectoring is superior to a LSD in both applications.
However, It's more complex, which means more expensive and (maybe) failure prone. Racing is expensive enough as it is, I think teams don't want to deal with torque vectoring differentials at this point in time.
Whom ever at M Motorsports that writes the CS-R technical specs has decided to include a "regular" LSD to keep things simple.
Racing series will do this all the time to keep the series competitive. I tried to find a source on this but couldn't. Maybe someone else can.
I believe a racecar with a LSD would go around a corner (even a slow one) faster than a road car with torque vectoring because of the better tires and lower weight of the race car.
      12-10-2019, 12:11 PM   #57
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
+1, see it the same. Cost of entry is relatively low. Wouldn't push its limits or wear components at track days, so running costs should be reasonable. (Slicks not included.) Doubt clutches and engine rebuild requirements (if applicable) are anything like a Cup car, Ferrari Challenge, etc. I'd have it over a Radical or similarly priced track special.
I'd guess dealers could address basic services, e.g., oil, brake fluids, anything you didn't want to DIY.
Anyone have practical info? Will BMW sell to DE guys?? If so, delivery protocol?
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
      12-11-2019, 03:57 AM   #58
Megator
Megator's Avatar
518
You missunderstood me and still missunderstand how the M diff works. (even after I explained it to you a while back in another thread ).
The M diff IS NOT TORQUE VECTORING!!!! it is VARIABLE LOCKING. These are two different things. Torque vectoring is what a Focus RS rear diff does, it can individually control how much torque goes to each rear wheel.
The M diff is variable locking so it can decide how much and when to lock "freely" compared to a normal mechanical locking diff which can only do so when the speed differential between the wheels reaches whatever preset.
Complexity/cost/rules/performance could be a reason for not including it in the CS racing.
Coming back to your original point and my question.
Where did you read that the M2 has brake based torque vectoring?
I would be curious to know if the M2 has this as I have not seen it anywhere and was part of what made my Focus RS handle great but overheat the brakes way too quickly on track.
AX 1.1 --> AX GTI --> NA Roadster 1.8 --> E39 528i --> Xsara VTS --> Volvo 940 LPT --> Focus RS MK3 --> M2C + NA Miata 1.8
      12-11-2019, 07:07 AM   #59
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
Found a channel to inquire... Can be purchased by DE, SCCA, etc. guys. Contact sending me maintenance schedule and other practical info.
U.S. intro & pricing to occur at the 24 hrs of Daytona next month.
Eh.
243Racing1447.50
      12-11-2019, 07:15 AM   #60
Poochie
Poochie's Avatar
9108
Drives: 2016 M2
There is a bit of confusion here. We're both saying the same thing but I'm referring to as a "torque-vectoring" because of how it's described in BMW literature and it operates.
The main difference is that Active M diff only transfer torque from slower to faster. The M diff is a basically a typical LSD, say a clutch-type, where the clutches, and therefore amount of lockup, are electronically controlled instead of passively activated based on the difference in speed between the two wheels on an axle, like say on a AWD vehicle or an EV. That means that they can control when and how much to lock up but by different means.
It's basically the same principal of being able to disturbing torque in either direction, via the locking method. Perhaps I should of been a little clearer.
In addition, BMW also states that it also liberally uses the DSC system to distribute torque. Hence my suggestion that it uses the brakes also to bias the distribution.
I did not mean the M2 has only a brake-based torque-distribution like the standard vehicles but more of assistance from the brakes, based on when the computer determines its needed, in addition to the clutch locking diff.
      12-11-2019, 09:10 AM   #61
Megator
Megator's Avatar
518
So no basis for this happening on the RWD M models, got it.
Your confusing the 4wd/AWD M models with the RWD M models
And your wrong vis a vis the diff.
From the C&D article "Proper go-fast torque vectoring requires at least one overdrive gear in the differential (though often there are two) capable of spinning the wheels faster than if they were driven through a conventional diff." --> the M Diff does not have this hence not torque vectoring
https://www.caranddriver.com/feature...-test-feature/
and from BMW themselves who say variable LOCK not TORQUE distribution.
"The M Differential distributes the drive torque evenly to both rear wheels and compensates for the rotational speed difference."
https://www.bmw-m.com/en/topics/maga...ferential.html
      12-11-2019, 09:22 AM   #62
dmboone25
dmboone25's Avatar
4972
2007 E92 328i  [10.00]
2007 328i  [10.00]
Eh.
That's interesting news on the intro/pricing - it would be great to learn about it sooner but hopefully that gives a date to circle on the calendar.
BMW, if you're listening, please make the price $74,999.
      12-11-2019, 09:28 AM   #63
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
That's a good one... a BMW factory race car for the masses.
      12-11-2019, 10:11 AM   #64
Poochie
Poochie's Avatar
9108
Drives: 2016 M2
Well, thanks for clarifying, I get the gist of what M diff does, as in being able to electronically distribute power evenly, as you stated, by locking the diff accordingly.
As oppose to a standard, non-electronic locking diff where percentage of maximum lockup is already predetermined.
      12-11-2019, 10:35 AM   #65
dmboone25
dmboone25's Avatar
4972
2007 328i  [10.00]
We can hope!
In any event, it would be nice to get confirmation on pricing so people can decide if they're in or out...my F80 lease is up at the end of March, so I really need to know.
      12-11-2019, 10:50 AM   #66
Poochie
Poochie's Avatar
9108
Drives: 2016 M2
We can hope!
You are aware it's not "street-legal" right?
m2
