Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      03-18-2015, 07:51 AM   #1
gsrbri
gsrbri's Avatar
560
Drives: F87 6MT
DOT 5.1 Brake Fluid
Guys:
I don't have my manual handy (I'm on business travel)...can someone advise if the F80/F82 owner's manual recommends DOT 5.1 low viscosity brake fluid? It appears that all the performance shops now recommend this fluid for the new BMW braking systems (beyond DOT 4 - esp for cold weather).
However, I'm now researching racing brake fluid, which is all DOT 4 (or exceeding DOT 4 so as not to be confused with silicone/motorcycle DOT 5). I'm probably going to stick with Motul RBF 600 for the track, but didn't know if there is a racing DOT 5.1 out there? Maybe not, since the 5.1 might thin too much when heated to track temps.
Anyway, if someone could post a photo from the owner's manual, that would be awesome. Thanks!
      03-19-2015, 04:31 AM   #2
robbo mcs
143
Drives: F82 M4 and others
i dont believe a top quality dot 4 racing brake fluid will cause any problems, eg castrol srf etc.
I have used elf htx, which is available in 5.1 locally for me (I am in Australia). This is a high quality brake fluid with good wet and dry boiling points. Not sure if this is available in the US, or if it is the same specs.
http://www.meek.com.au/index.php?_a=...product_id=978
f80post
