03-02-2024, 12:00 AM | #1 |
Chaseman
27
Rep 145
Price check: 94k miles $15k maintenance quote
hey everyone, I joined this forum when I first got my car back in 2009 — I drove it up to 35k miles and then let my sister use it from 2015-2024 and it’s now up to 94k miles. She took it in for regular maintenance.
I just got it back from her and am planning to restore the car a bit, first starting with the critical internal parts and eventually with the aesthetic stuff. I got a quote for $15k for everything, but I have a 2 questions for the group: 1/ I haven’t had the car in so long and don’t have a sense at all for what is reasonable cost so would appreciate any thoughts/guidance? 2/ should I take it to the dealer for this service or is it ok going to a local reliable shop? Thank you!!
2009 E92 M3 JET BLACK
2008 TOYOTA PRIUS BLACK |
03-02-2024, 04:10 AM | #2 |
1061
Rep 892
Drives: F87 M2CS
About 1k too much for rod bearings. Last I checked, TA are about 700-800 for a rebuilt pair with core exchange and they have a lifetime warranty. The labor should be no more then 800 for TA so you're getting ripped off there. Can't comment on the paint/body work quotes. Is the steering wheel the OEM m performance? If so that's good pricing. If you're getting an amplifier, I'd recommend an aftermarket replacement instead of OEM. Something like bavsound, bimmertech, match 7up, etc. is worth the investment from the reviews. Don't just top off brake fluid do a proper flush. I switched to motul rbf600 with upgraded pads and stainless steel lines (all 6 lines). Instead of OEM headlights consider an upgrade like bayoptik for example. If you're investing this much then also look at your valve covers for leaks and replace if needed. The plenum will already be off for the TA and will be even easier to do the spark plugs. Consider replacing the coil packs too if doing plugs at 100k
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
03-08-2024, 12:08 PM | #3 |
99
Rep 250
I agree with everything Reddevils7 said (except for his choice in football club). It's a lot of work, price isn't too high.
RB and TA quotes seem a bit high. Body work seems reasonable if it's done at a quality shop. Amp replacement seems cheap but if you have the budget there are better ones for closer to $1k. Bimmertech's lightwave amp seems to be pretty awesome (assuming you have individual audio package). Depends on how much you care TBH since factory is pretty decent. EDC modules are $900 new or $150 used so I'm assuming that's for a used one (which is fine). As far as shops, I see you are also in the bay area. There are a few m-focused shops scattered around, and I would trust any of them more than a dealership. I go to Vt Motorworks in Pleasanton, they're pretty renowned as one of the best. Edge Motorworks in San Ramon is great too, I have some friends with e90s that go there (I might switch to this one since it's closer). Performance Dynamic in Mountain View is the place to go on the Peninsula, have some other e9x friends that go there. There are others, but those are the three I have personal experience with.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package Last edited by Thumbie; 03-08-2024 at 12:20 PM.. |
03-28-2024, 01:52 PM | #4 | |
14
Rep 41
03-28-2024, 03:42 PM | #5 |
322
Rep 504
Drives: M4 GTS
Holy hell that is WAY to much for the RB and TAs.
03-29-2024, 04:14 PM | #6 | |
99
Rep 250
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
