03-10-2010, 06:21 PM | #1 |
153
Rep 2,757
Drives: 2017 Audi A4
Need help with M Power pedals
K, does anyone know of or have a DIY for the //M Power Pedals, aluminum with the rubber backing and inserts. I specifically need the auto pedal DIY with the dead pedal. I know the DIY is diff with these vs. the BMW performance pedals because these came with different screws: 2 sets of equal length torx-head machine screws with matching nuts and 4 phillips-head screws that are a little bit shorter then the others..not sure which to use on which pedal..
BTW these pedals look like this, but mine are the auto's |
03-10-2010, 07:28 PM | #2 |
European Editor
10589
Rep 22,992
I am taking a 'wild" guess here... but the 4 phillips-head screws are probably for your dead pedal - since you can not get your hand around the back of it for the nuts!
Good Luck, David |
03-11-2010, 12:27 AM | #3 | |
got em' son
11
Rep 448
Drives: 08 135i sold / 08 E90 M3 sold
03-11-2010, 12:29 AM | #4 |
153
Rep 2,757
Ok so you used the longer thinner torx screws for the brake and accel pedal then? They seem like they may be too long and prevent WOT with the accel pedal, I dunno..
And so is it the same size drill bits? |
03-11-2010, 12:41 AM | #5 | |
got em' son
11
Rep 448
heres from the other thread:
Now to answer your question about the screws being too long for the gas... it worked out fine. I only used the washers that stayed on they are super small and hard to handle, so if they came off in the process, i just left them off and used only the nut |
03-21-2010, 09:52 PM | #6 |
153
Rep 2,757
Well...after 3 n a half hours I got these finally installed. My neck n back are killing me thou.
I ended up prying the "aluminum" piece on the front of the M sport dead pedal which revealed the hard plastic part of the pedal underneath to which I screwed the Power dead pedal, actually is great cuz it pushes the dead pedal out about another 1/2 inch or so which is good cuz Ive felt that pedal is a lil far from my left foot regardless of how I set my seat. The brake pedal obviously was a massive bitch, I did end up breaking one drill bit doing the upper left hole but I think it was my fault cuz I was pressing too hard at one point and the bit was at a bit of an angle so it snapped. Didnt have any problems thereafter thou =D I did drill a smaller pilot hole for each one of the screws for the brake, I dont remember the sizes off the top of my head but I measured a bunch till I found the right ones. The atom-sized nuts were a real pain, luckily I had some locking washers to put in front of the reg washers and nuts, hopefully that will get rid of any possibility of them ever coming loose. I used tweezer locking clamps to hold the tiny nuts in place while screwing the machine screws into them. The accel pedal I did a bit differently. I ended up not making any pilots, I just lined the pedal up to how I wanted it and drilled the first lower left hole, put the screw thru, then drilled the upper left hole, and so on. The power accel pedal is not a PERFECT fit to the shape of the stock pedal, as it does sit at a bit of an upward angle with it drilled inline on the side and bottom, honestly though, I cant tell at all, just a real minor angle, but they are all secured on each pedal so Im not worried. All n all i would say this was more of a pain then I would see installing my own FMIC and charge pipe would be, just so hard to get the minor details right n do all the tightening n shit specially when half the time I was just going by feel since you cant see a thing back there, I was even using an electric hanging light so.. They feel great, the dead pedal especially is ALOT more grippy than the m sport pedal, much more comfortable pedal feel over all. Oh and btw I did all this without removing ANY inside panels or anything above or beside the pedals |
04-05-2010, 10:52 AM | #7 |
Rep 34
hate to poop the party
but... i love these pedals... had them on my E36... but there's a problem... you'll be taking those pedals off again in about 2 years... once the rubber inserts are worn out and flush with the metal - the pedals become very slippery in wet conditions... so you'll have to replace the rubber...
keep that in mind - make sure you don't make your installation too permanent. |
04-13-2010, 08:38 PM | #8 |
30
Rep 586
here's a different set of pedals. They match up real nice to the metal trim.
[IMG]
2009 135i Black on Black
Options|Leather| Sport Package| Premium Stereo| Steering Assist | V1 Engine MODS| JB4 install | AR DPs | Berk Axleback | ITG Filter | BHS OCC | Exterior Bling| Kerscher splitter | Interior Bling | Bimmian pedals | 3P Cars gauage | |
04-16-2010, 06:13 PM | #9 |
Rep 1
Put in the M pedals today
I just installed the M pedals today on my 128. I have a manual, but can tell you that the phillips head screws are for the dead pedal. They go in the easiest...took longer for the clutch, brake and gas. Overall about an hour to install for me and I'm a beginner.
04-16-2010, 09:31 PM | #10 |
153
Rep 2,757
Totally off here but you know what the bitchiest bitch is with this car, the damn deadpedal sits soo much farther fucking back then the gas and brake, makes the whole position feel really weird sometimes if you're actually thinking about it
