Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Urgent help...please
      09-26-2018, 01:56 PM   #1
Mikez306
20
Drives: 2016 M4
2009 335xi
I replaced the drivers side rear wheel bearing, and clearly something has gone wrong.
When putting the car from P to D there is a loud clunking noise, followed by what sounds like the axle shaft turning (even though my foot is on the brake). The car will not drive forward (revs as though it's in neutral).....what is probably most concerning is the car will roll forward or backwards, with the car in P and engine off! Can someone please help me out with this? I am new to these cars and have no idea where to start.
Oh and no lights on the dash etc...
Thanks in advance for your help.
Mike
      09-26-2018, 03:13 PM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
sounds like somehow your halfshaft isn't interfacing to the hub, an assembly error likely. you haven't tried taking it apart and finding the issue..?
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      09-26-2018, 03:15 PM   #3
White330
31
Drives: From the passenger seat
Sounds like the axle isn't connected to the hub if its spinning by itself. Pull off you wheel and check all your connections
      09-26-2018, 03:16 PM   #4
Mikez306
20
Drives: 2016 M4
Well I would like to but not really sure I know a safe way to lift it.
      09-26-2018, 03:19 PM   #5
White330
31
Just throw it onto some jack stands. How did you replace the wheel bearing?
      09-26-2018, 03:20 PM   #6
Mikez306
20
Drives: 2016 M4
What is even more bizarre is that I didn't remove the half shaft from the diff to do the job, I pulled the axle shaft out of the hub by removing the entire knuckle from the suspension. Then I took the entire Hub assembly to the dealer to have them press off the old wheel bearing and press on the new one.
      09-26-2018, 03:24 PM   #7
White330
31
Its spinning because its probably still connected to the diff but not connected to the hub
      09-26-2018, 03:28 PM   #8
Mikez306
20
Drives: 2016 M4
Great point. I am wondering if perhaps the u joint in the knuckle (on the control arm side) has broken?
      09-26-2018, 03:37 PM   #9
White330
31
Either that or the splines may have stripped. How did you remove the axle? Did you hammer it out?
      09-26-2018, 03:49 PM   #10
Mikez306
20
Drives: 2016 M4
Yeah I hammered it out. I think either way I will replace the hub and axle assembly.....hopefully I can save the wheel bearing.
      09-26-2018, 03:57 PM   #11
White330
31
First you should pull your wheel off and check all the connections its possible that the axle came out of the hub
      09-26-2018, 04:05 PM   #12
Mikez306
20
Drives: 2016 M4
I pulled the center cap off the wheel and I can see the axle still fully seated in the hub. So I am assuming the problem is further back in the assembly. I think I will get someone in it, to put the car in drive to ensure the axle isn't spinning inside the hub.
      09-26-2018, 04:30 PM   #13
Mikez306
20
Drives: 2016 M4
I can hear the axle turning behind the knuckle. I have yet to take it apart to dig deep, I will post some pics when I do.
My last question is why would this issue prevent the tranny from going into P. The lever physically goes into P but neither the front of rear diffs lock?
      09-26-2018, 04:43 PM   #14
White330
31
I'm not too sure about that, hopefully the transmission didn't get damaged when removing the axle.
      09-26-2018, 04:56 PM   #15
Mikez306
20
Drives: 2016 M4
I suppose anything is possible however I didn't remove the axle from the differential when changing out the bearing....I can hear metallic grinding right behind the hub with the car in D.......but like I said I won't know the extent of the damage till I take it apart.
      09-26-2018, 05:14 PM   #16
White330
31
I was thinking that it may have become damaged when removed the axle from the hub. Did you have to hit it pretty hard or did it come out easy?
      09-26-2018, 06:56 PM   #17
Mikez306
20
Drives: 2016 M4
Probably one of the most difficult axle shafts to remove or insert that I have ever done....In other words I had to hit it pretty hard.
I am wondering (admittedly I don’t know much about these cars) if the computer is somehow locking it into neutral? Since it broke behind the hub the speed sensor is not detecting the wheel movement versus the other wheels?
Just a though....I appreciate all the replies!
