2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum My first F10 retrofit - Soft Close Doors
      06-01-2012, 10:58 PM   #45
itzryyster
itzryyster's Avatar
37
Drives: i4/LCI G30/Tacoma
2011 BMW 535i  [7.00]
2021 BMW 530e  [0.00]
2021 Toyota Tacoma  [0.00]
Great write up man. Nice feature to have indeed!
      06-11-2012, 10:33 AM   #46
crushvbk
Drives: 535i
Is the Comfort Enter module necessary for retrofitting Soft Close Doors?
      06-11-2012, 11:09 AM   #47
Tuesday
Frequent Flyer
Tuesday's Avatar
51
Drives: 535LCI
No, you will have to run new wires no matter what features your car has.
      06-13-2012, 04:12 AM   #48
crushvbk
Drives: 535i
Thank you for replying me.
Is the crash pad in non Soft Close Doors vehicle different from the one which come with factory soft close door modules?If yes,can we modify the shape to fit?
There is a 740li(F01) in my garage,I want switch the modules to my 535i(F10) for test.
sorry about my poor English,if you are hongkongese,I'd like to e-mail you in chinese.
      11-07-2012, 09:45 AM   #49
Ducisco
Drives: BMW 520i
Originally Posted by itschase View Post
I didn't order my car to spec, I get bored with cars too easily. I saw this one on the lot and leased it thinking I had all the features I would want. It didn't take me long to realize I should have opted for a model with soft close doors - most of you know what I mean.
On my last car (E60 550i) I did all sorts of stuff like soft close doors, HUD and navigation retrofits and had a lot of fun doing them.
I have to take it easy with the retrofitting on the F10 because it is a lease and I'm probably going for the M5/6 in 3 years. Luckily this is a pretty straight forward retrofit, costs under 2k in parts (who cares what it would have cost to order it from the factory) and uninstalls without a trace.
I got all the door modules online, I will post part numbers after I get back in the US - but you can easily find everything you need on real oem.com.
I will post pics of my progress and a shoddy DIY for those that may be interested in doing it themselves. The important thing to mention as far as installation goes is that the soft close door modules replace the existing lock mechanisms completely, bolt right in to the door frame and only require power and ground to function. Everything is self contained so technically no coding is necessary at all. If you're uptight about it adding the proper VO is easy.
Over time the new car smell will wear off these things and people will go nuts adding features they wish they had, I wonder how long I will be able to resist the temptation to retrofit HUD, haha.
__________________________________________________ ________
**UPDATE: RETROFIT COMPLETE See below for details and pics!**
F10 Soft Close Door Retrofit
As I mentioned in my post, I did not order my car to spec – I just saw it on the lot and was happy with the included features. I decided to go with a lease because last time I owned a pre-LCI car, I spent way too much money updating the lights, interior and navigation. Although this is a leased car, I still find that a few features I am missing will end up turning into a regret (for not ordering them) so I decided to take matters into my own hands. Those of you who own an F10 without soft close doors can probably agree with me that these doors need them. BMW switched to aluminum for this body style, so for me personally – there is a major difference from the E60 I traded in for this car. It isn’t as if I cannot properly close a door, it’s just that these doors now require more effort and there are times (like when I am in a hurry) that I really wish I had this feature.
Getting the parts was rather easy, I searched realoem.com and found the part numbers for the modules, they are as follows:
Front left - 51217185689
Front right - 51217185692
Rear left - 51227154515
Rear right - 51227154516
The list prices are only what I found on realoem.com, the real prices were cheaper on getbmwparts.com – I paid roughly $1,500USD for all 4 modules shipped to my house.
I started with the right rear door, as this is one I use the least, so if something went wrong having one door out of service would not really inconvenience me. The first thing to do is to remove the trim around the inside door panel. To do this youÂ’ll need to use some sort of soft trim tool. Start on the side towards the back of the car and lightly snap it outwards. Pull open the door handle to make removing the rest easier; just gently pull outwards from the back and youÂ’ll hear it snap out of place. I read somewhere that it is normal to snap a clip or two from this trim when removing it, and this was true for me. This same source, however, also said that the trim will still snap back in securely and this was also true.
Once you have the trim off youÂ’ll see a T25 torx bit sitting there. Remove that and youÂ’re ready to pull the panel off. Start at the bottom center with your trim tool and gently pry until you can get your fingers under the panel. Pull outward with short and deliberate force and youÂ’ll feel the clips pull loose. Continue pulling around the sides until you feel the panel is separated from the door, with the exception of the top part.
**SIDE NOTE: If you have rear shades, youÂ’ll need to roll down the window and pop out the trim that carries the shade for the small back window before you can remove the door trim. It pulls out easy, when you look at it youÂ’ll see, start on one side and then gently pull the other side loose and it will come right off.
Now that the door panel is ready to be completely removed, you’ll want to pull the panel straight up until you feel it come loose and then gently rock the top of the panel back towards you allowing the bottom of the panel to still rest against the door. You’ll see a collection of wires attached to the inside of the door panel, and you’ll see the Bowden cable for the inside door handle. To remove the Bowden cable you just have to pull straight out from the side with the cable going into it. You can’t miss this, it’s white and in the way. When you have that side removed just let it hang and carefully unplug all the wires on the inside of the panel, as well as the anchors that attach the wire looms. Once all is removed put the door panel aside somewhere safe (I put mine in the trunk since I did one door at a time). Under the door panel you’ll notice there is a gray foam cover, this is weatherproofing and if you’ve never removed one of these before, get ready to have some fun. If you are doing this on a hot day and in a hot place, get ready for the mess to come because the sealant car manufacturers use to keep moisture out of the door is brutal. My advice is to do this part in the shade – I had no choice since I park underground in an apartment complex. You’ll see that the gray foam piece has splits in it to allow the wires through; this is a great place to start removing. I chose to use a razor blade to cut through the sealant, all I did was gently pull back on the foam and as the sealant started to stretch, I sliced it in the middle with the blade. This method works great for me because I like to have the sealant on both sides for when I reassemble the door. Slowly go all the way around, do not rush this step because if you get that black stuff anywhere it is not supposed to be you’ll waste a lot of time cleaning it up.
Now that the inside of the door is fully exposed itÂ’s time to get to work. You have a few tasks to complete:
1) get your wire inside of the door through the loom
2) remove the original door module
3) replace it with the soft close door module
I started with the wires because if that goes wrong, the rest is pointless. To open the loom that goes into the door you’ll need a 8mm socket and preferably a ¼” ratchet. Where the loom meets the body of the car you’ll see a bolt, remove that and pull up and out to free the wires. There is a clip you’ll have to remove to separate the harness so you can run wires through it. From this point there are two ways to go about getting the new wires ran. The quick way is to run the wire through what appears to be an empty MOST-bus port in the harness, the second would be to order the proper connectors and splice each end of the wires to each end of the connector. I did it the quick way.
You’ll have to remove a good deal of trim from the inside of the car, the trim at the bottom of the doors, the bottom of the rear seat (for ease of running wires) and the side trims from the B pillar. Run the wire, connect it to the module (how you do this is up to you) The OEM connectors appear to NOT be available unless you buy the entire wiring harness for the door – however if you are doing this retrofit, I will assume you are clever enough to improvise on this step.
The front doors are a little more challenging to wire and remove. On these doors you have to remove the wood (or whatever you have) trim. To do this, just pull straight out lightly from the end towards the front of the car. It will only come out about ¾” at first, keep pulling along the trim until it has come out that far all the way down. Once you’ve gotten that far you’ll need to locate the silver metal clip towards the front part of the trim – you need to somehow compress this to remove the trim. Many people on the forums have done this so I am sure they can chime in with a more detailed explanation, but trust me it is easy. When you have the wood trim off you’ll notice another T25 torx bolt is now exposed, remove this as well as the one behind the inside handle trim and you are ready to remove this door. Here is where the new complication begins…
If your car did not come with factory soft close door modules you’re kind of stuck right now. Inside the door, in the bottom outside corner you’ll notice a wedge of foam, or what BMW calls a ‘crash pad’. If it was called anything else in the English language I would have torn the whole thing out because as it sits, it completely blocks two of the 3 holes needed to bolt the motor section of the new door module. This caught me off guard so I immediately went to realoem.com where I found the part numbers for the appropriate crash pads. The part numbers are: 51717196757 and 51717196758. As you can imagine this obscure part is not in stock anywhere in the US, nor is it even in most BMW dealer’s computers. Since I have a good relationship with my parts guys they were happy to waste 30 minutes for $40 worth of parts and they added the part numbers to their catalog and ordered them for me. It will take a minimum of 15 working days to get them.
I decided that there has to be a way around this, so although it isn’t possible to remove the pads without taking out the entire window assembly, it is possible to take out the one torx bolt that holds it down and examine it. I noticed that one side of it was just filler on the other side of a ridge – hardly structural, so I used a serrated kitchen knife to trim the piece down. This took some time because all you can do is hold it in one precarious position at a time and trim off about an inch or so per position. Make sure you do not cut off the round white plug that allows this trim to be secured to the door, just cut along the bottom of the valley in the material and you’ll have plenty of room. I am not a structural engineer, so for all I know I completely compromised my side impact safety – in other words DO NOT DO THIS. But after you do, you’ll be free to proceed as you have for the other doors.
The other catch to the front doors is that there is a module mounted behind the kick panels on either side of the car, they are held in place with 10mm nylon bolts on the top and bottom of each. To get to these bolts youÂ’ll need to remove the kick panels, knee airbags (do not unplug them!) and the footwell trim. Once you get all of this out of the way you can remove the module and there is a very clear path from the back side of where the door loom comes into the vehicle.
Once you have all 4 doors done and wired up, youÂ’ll need to get the wire to the trunk on the right side of the vehicle where the main accessory power distribution panel (aka fuse box) is. Hooray for BMW, they really nailed it with this design. Take off the sides of the back seats, pull hard straight out from the top and then pull the bottom up and they will come right out revealing a wire conduit/tunnel leading right to the trunk! I was so happy to see this, and with a coat hanger I had my main power and ground wires running to the right side of the trunk.
Now I had to remove the flooring and right side panels of the trunk to fully expose the fuse box. I removed the fuse box by taking out the 3 (10mm I think) bolts that hold it in. From the back I could clearly see that a lot of the fuses are connected to nothing.
Because of the connectors and end terminals I have in my tool box I was only able to connect to one of the smaller type fuses, I chose a 15A and once I get to the BMW parts dept. I will buy a bigger connector because I personally believe these modules should have at least 35/40A. According to WDS for the E60 each side of the car should be wired together and be fused separately, I did not do this (or havenÂ’t done it yet). I just wired all the power and ground wires respectively to each other and a long wire to each junction to run to the trunk. Some day I will change this but once I tapped into ground and plugged the positive wire to the back of the unused fuse, all the door modules came to life. Each door works exactly as it should and once I tucked/tied all the wire away you would never know it did not come from the factory.
Please ignore the heavy breathing in this video, lol. Yesterday I pinched a nerve in my lower back and every move today was excruciating.
Hi itschase,
I'm going to retrofit the soft close for my 520i. I ordered everything you mentioned in the post. However, i'm wondering that is the wire ready for all 4 doors or we have to layout it? if we have to layout the electric cables, can we order the harness or some kind of that? And how about the terminal for both end?
Much appreciate if you can show me more detail on the cable instruction.
Sorry for my poor English.
Thanks.
      11-13-2012, 11:24 PM   #50
Ducisco
Drives: BMW 520i
itschase, where are you i need your help urgently!!!
      11-14-2012, 12:48 AM   #51
Ducisco
Drives: BMW 520i
Hi itschase,
Do you know the part # in terms of order a wiring harness door?
Thanks.
      12-19-2012, 07:17 AM   #52
5seriesHB
In The Game!
5seriesHB's Avatar
15
Drives: 12 535 Msprt/12 X5 5.0 Msprt
soft close retrofit
Picking up a 2012 e70 X5 MSport
are these the same part #'s for the specific vehicle as well.
Has this Modification/retrofit held up over time any issues reported from experience
Thanks in advance
Rob
It will all work out in the end....and if it hasn't worked out yet, its not the end!
2012 Titanium Silver Metalic w MSPORT+Prem Sound+Tech+Cold Weather+Top/Side Cameras+ BMW Apps
2012 Space Grey Msport 50 X5 Premium+ Premium Sound+Cold Weather +Soft Close Doors
      12-19-2012, 02:48 PM   #53
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
332
Drives: 2020 M8 & 2022 X& M50i
great write up
I may do a door just to try my abilities and move to the rest
      12-21-2012, 06:25 AM   #54
fsfikke
14
Drives: 330e
Originally Posted by Alan l. View Post
Is the soft close doors really worth it? I have the chance to order my f10 with it but debating if i want it. Another item that could fail over time and not sure if I would miss the solid thump you get from closing a nice solid german machine. Are the f10 doors really aluminum and harder to close? Do they not have the same solid thump when you close the door like older BMWs?
Thanks
Alan
Besides that I personally really like the effortless closing of soft-closing doors. I find it pretty classy when closing your passenger door after your gf (/wife/random chick) gets in, rather that smashing the door into her face
      02-23-2013, 10:31 PM   #55
Ducisco
Drives: BMW 520i
Hooray!!! I finally finished this retrofit. It's working great and definitely it's amazing that I have done it by myself in a day. Just one wondering that my car doesn't has th crashpad as itschase mentioned. I don't know why but with the space I got, 2 new crashpads cannot be fit unless I dismount the door so decided to left it as it is.
By the way, this is fabulous and I'm looking forward to retrofit my trunk.
      02-24-2013, 07:55 AM   #56
Luigi524TD
34
Drives: 2023 X5 45e MSport
Great write up - had I known in advance the F10 doors required a hard slam to close properly I'd have hunted one with this option too. It reminds me of one of me past cars (can't remember which one - it wasn't a BMW) that seemed "airtight". It helped to crack a window before you closed the doors or they'd seem to pop your ears and frequently required a second slam to close them properly.
In the case of the F10 I suspect it's necessary to slam them closed to overcome any pressure from wht door seals or tightly adjusted door hardware. Maybe over time they'll loosen up. Mine aleady has the comfort access for the trunk/boot. It's a GREAT feature though from time to time I have to remind people who aren't aware of the closing button that they don't have to push it closed.
My opinions are free - you'll get exactly what you pay for!
Current:
2023 X5 45e MSport
2013 X1 3.5 MSport
1998 Z3 2.8
      02-24-2013, 05:51 PM   #57
nabego
nabego's Avatar
Spain
Drives: BMW
Someone did this in the trunk?
      02-24-2013, 07:33 PM   #58
konasunset
registered
konasunset's Avatar
Drives: 535i titanium silvr 1/11 build
Good work! How much did it cost you? I got the convenience pack with my 2011 535i and that included the soft close doors, power trunk, and keyless entry at a list of $1700.
      02-25-2013, 03:02 AM   #59
Ducisco
Drives: BMW 520i
Hi,
$1700 for everything? wow, that's cheap cause this retrofit (only soft close door) takes me nearly $2000. I think this is the choice to those who don't have these options at the beginning and now they want to make it, also depends on the country where they live.
      02-25-2013, 10:16 AM   #60
5seriesHB
In The Game!
5seriesHB's Avatar
15
Post Soft close rock
They rock
I passed on the tech package in my new Msport X5 50
To get soft close doors
Passed on them in my 535 Msport "regret"
That cAr needs about 1000lbs of force to close a standard door in that car
Kids wake up from naps and all hell breaks loose
Not anymore!
Besides tech package gives HUD
I have a nav screen and speedometer.
Just sayin
      03-22-2013, 08:49 AM   #61
Tomcoding0803
Japan
Drives: F10
Hi everyone,
I got a Soft Close Automatic Retrofit kit in Bimmertech online shop at €1349.00.
http://www.bimmer-tech.net/shop/bmw-...close-retrofit
This kit includes these parts... (Parts No.)
1. Soft close automatic Front-Right (51217185690)
2. Soft close automatic Front-Left (51217185691)
3. Soft close automatic Rear-Right (51227154516)
4. Soft close automatic Rear-Left (51227154515)
Name:  2013-03-22 22.45.07.jpg
5. Crashpad, door, front left (51717196757)
6. Crashpad, door, front right (51717196758)
Name:  2013-03-22 22.45.46.jpg
7. Power cable with connector *4 (Bimmertech original?)
Name:  2013-03-22 22.38.48.jpg
8. Extension cable *4 (Bimmertech original?)
Name:  2013-03-22 22.38.16.jpg
My F10 is Right-hand drive car but It seems there is no difference in these parts from the Left-hand car.
I will report my retrofit soon.
Thanks all,
      03-22-2013, 11:35 AM   #62
Die Wolfe
Die Wolfe's Avatar
14
Drives: '12 535i Msport/'13 X5///M
Originally Posted by Tomcoding0803
Hi everyone,
I got a Soft Close Automatic Retrofit kit in Bimmertech online shop at 1349.00.
Attachment 834165
Attachment 834166
Attachment 834168
Attachment 834167
Thanks all,
That's awesome! Thanks for the link, I want to do the same to my wife's 535i!
      03-24-2013, 10:29 PM   #63
Tomcoding0803
Japan
Drives: F10
Hi everyone,
The installation of soft door close retrofit kit was completed!
Though it was not so difficult as a whole, the most difficult for me was that run the power cable from the door into the car through the rubber-made waterproof harness cover by using the wire guide.
After that, run the cable inside the front pillar and the side of the floor, finally to the battery.
Note, my F10 has no crashpad and its good to install.
It takes whole a day to complete.
I will recommend this retrofit to you!!
Itschase, Thank you for your information in this forum.
      03-25-2013, 10:04 AM   #64
Die Wolfe
Die Wolfe's Avatar
14
Hi everyone,
That's great to hear man, congrats! I think I may go this route with my wife's 535i too!
      04-02-2013, 02:07 AM   #65
528imsport
528imsport's Avatar
75
Drives: Msport
That a very cool DIY and write up, will do this mod when my warranty runs out in 1.5 years time.
      09-10-2013, 06:39 AM   #66
Mans
Drives: Black :-)
Additional info about Retrofitting Soft Close locks
Hi, for all of you with interest into retrofitting this kit :-)
OEM BMW uses the following fuses into the rear fusebox:
F110 = driver door.
F143 = RL.
F144 = FR.
F149 = RR.
The following crimping contacts should be used to plug-into the original 10+5pin connectors: BMW 12.51.7.548.500 (1mm˛ wiring).
When your car doesn't have the electrical rollo, aka rear window shade, nore the Soft Close, then you could be missing the blue 10+5pin connector to plug F110 into. You dealer could supply you thisone, ask for the blue coded connector (also used for the new F12 LED headlight kit).
10amps each should be used per motor.
I've installed all for 4 locks, electrics and completed the retrofit in +-10 hrs.
The most difficult thing about this retrofit is swapping out the crashpads inside the frontdoors.
I've ordered, before starting, the new crashpads, which are ready for the SoftClose motors and cutted the oldones into pieces so i was able to remove these from the doors. The newones are smaller and so easier to install.
100% happy with this update !
Best mod to my F10 till now.
Cheers !!!
5post
