11-01-2017, 06:26 PM | #1 |
64
Rep 13
U-Haul Auto Transport Measurements
I have found this forum very, very helpful to me selecting the right M4. I picked up an off-lease 2015 M4 Coupe with the DCT about a month ago after looking at 440i's for a bit. A used M4 had all of the equipment I wanted for around the same as a lightly used 440i. I'm super happy.
Anyways, the Air Force likes to move us around pretty frequently. I found on here that their trailers have a decent lip, so I was at least able to arrive at U-Haul semi-prepared. Here is a much better look at the dimensions you might want to take note of if you ever need their equipment: Front Lip/Bump Stop height: 6" Front wheel cradle length: 21" I had no clearance issues with regard to the break-over angle or the doors and the fenders. I used a stacked block of 2x4 that was screwed together as chocks to lift the bumper over the front lip. It worked really well. Also, the tire straps do not touch the wheel when properly configured. *Photo Note: My car is 100% stock Last edited by kevin4052002; 11-01-2017 at 06:56 PM.. |
08-16-2018, 09:06 AM | #3 |
225
Rep 490
Resurrecting an old thread... but did you have any issues driving up on the ramp?
Also, did you do anything to protect the front from rock chips?
2020 M2C.
10-29-2018, 11:56 AM | #4 |
1478
Rep 2,672
Thanks for sharing OP!
I'm having Race Ramps make me some custom ramps to use instead of wood blocks for the front wheels as I plan to tow my F80 fairly regularly on a Uhaul trailer. Will post more details once we get there. More measurement photos for reference:
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
11-17-2018, 03:00 PM | #5 |
1478
Rep 2,672
Custom race ramps came in and should work well for my purposes with stock ZCP suspension. Happy for now though I may have to re-evaluate when I eventually lower the car.
Trial towing run is a few weeks out still, will report back.
M_Torx332.50 |
11-19-2018, 09:14 AM | #7 |
1478
Rep 2,672
That's correct, the dimensions are attached for reference. Of note, with the coating process the vertical dimension ends up closer to 4".
08-03-2022, 07:19 PM | #10 |
246
Rep 513
Bumping an old thread, the last resort chains forward and aft on the uhaul trailer… where did you all attach these too? The only viable place in the front is the control arms which I will not use.
11-30-2022, 06:32 AM | #11 |
1478
Rep 2,672
About to start towing again but with my e92 m3 this time, will use a similar setup as before.
In terms of the rear tie downs, I don’t know the best answer but I like what the person did in this video. Entertaining video also. |
12-01-2022, 09:11 AM | #12 |
1478
Rep 2,672
Feeling quite lucky that it appears I can re-use these custom ramps with my e92 m3 at its super low ride height. I did replace the undertray with the Mporium version, that is key here!
12-01-2022, 01:56 PM | #13 |
278
Rep 372
So I’ve towed the M3 several times across the country (military). I’m lowered on H&R sports and the uhaul auto trailer works but it’s sucks. It’s is extremely heavy and based on how it is made it suffers when traveling above 60 MPH. The front will absolutely hit if you’re lowered and have a front lip. I used Tomioka Racing Super Slopes to help load the M3.
I used 4 ratchet straps all around to tie the M3 secure to the trailer. Little over 2000 miles one way and no issues other than the front lip and having to go slow. If you can get a nicer trailer definitely go for it but this is cost effective.
F80 M3/ 6MT / Sakhir Orange on Sakhir Orange
01-05-2023, 03:01 PM | #14 |
131
Rep 173
I’m about to do this with a lowered 2015 M4. Looks like I’ll be okay if I bring some extra boards right? I’ll
Probably hit Home Depot and bring my saw and drill and finagle them so not to wreck my front lip or bumper |
01-05-2023, 05:45 PM | #15 | |
5491
Rep 5,178
These things work great to drive up and get my big old jack under the front lift point for oil changes. I stapled some rubber sheeting on the bottom so mine don't slip.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
TractionControlDelete4599.50 ashutoshkotha38.50 |
01-05-2023, 06:46 PM | #16 | |
131
Rep 173
I was also planning on using something like that to back up my rear truck tires onto to get a better angle for the car to get on (essentially lowering the trailer). Hopefully will be all good! |
TopJimmy5491.00 |
02-10-2023, 01:28 PM | #17 | |
39
Rep 191
TopJimmy5491.00 |
02-10-2023, 03:59 PM | #18 |
131
Rep 173
I did this recently. Pita. I’m lowered with a carbon lip. Took like 45 mins to get it on and maybe 20 mins to get it off. Putting it on I removed the wheel stops on the trailer, and had to take the car back off the trailer 3x to adjust everything for clearance. It did work tho
02-13-2023, 01:30 PM | #19 | |
39
Rep 191
But needed the wood clear the front while the car was sitting on the trailer though. |
04-25-2024, 12:51 PM | #21 | |
43
Rep 1,219
For those of you putting wood under the front wheels, do you notice the front wheels sliding sideways and slipping on the wood?
I recently used a UHaul trailer for my E46 M3, and used two 2x8 screwed together, and after about 20 miles, noticed the front wheels shifted enough so that the the edge was almost over the side lip of the ramp/trial (it was centered before). The way that the straps are secured, it allows lateral movement of the front wheels, like sliding on the wood. I ended up removing the wood, pulling the front bumper and reinstalling the bumper after it drove onto the trailer. Quote:
04-28-2024, 06:06 PM | #22 | |
22
Rep 79
