04-13-2018, 01:24 PM | #1 |
195
Rep 178
Suspension clunks, thinking about coilovers. Opinions?
Hey all,
When I picked up my CPO M235i, I noticed that the front suspension made a soft clunking noise when going over uneven bumps or dips. After reading dozens of threads on almost every BMW forum, F20 forums and 2addicts in particular, it appears that this suspension clunk from the front end is common and labeled "normal" by BMW. Many owners have tried a variety of remedies to reduce the noise, such as replacing tophats and/or the steering rack. Unfortunately, in most of theses scenarios the clunk either isn't fully resolved or comes back. The only real solution seems to be replacing the entire strut assembly. In any case it doesn't seem to actually affect the car from a safety or reliability standpoint, I just don't want to hear it anymore. In addition to the annoying clunking, I'm just not pleased with my DINAN springs - although I like the way the M235i looks lowered a bit, I actually think I preferred the way the car handled prior to this modification. I have also changed my opinion on the adjustable suspension: to me, it's all novelty. It's not right in comfort mode and it isn't right in sport. I just want a suspension that feels great all the time (I know, that's a lot to ask). As a solution, I'm very close to pulling the trigger on coilovers. I've looked at a variety of brands, namely options from Bilstein and KW, but I don't like the idea of coilovers that compromise piston stroke for lowering. In this case, it seems my only options are BC's BR coils and Ohlins, both of which are height adjustable via the shock body. Of course, I'll code out the EDC. I really like BC's offering from a cost standpoint considering they can be spec'd with Swift Springs (amazing), rear valve adjustment extenders, and come with camber plates. Ohlins, on the other hand, makes some of the best dampers on the market and they are still cheaper than the KW V3 Plug and Play kit. While I'm in there I'll also install powerflex LCA and FSB bushings. What do you all think about this plan? I really hope coilovers fix the clunking issue. Never know though, I could end up making the problem worse. |
04-13-2018, 03:24 PM | #2 |
5593
Rep 5,389
My guess is the clunking is related to the Dinan springs not seated correctly in the perch or hat and/or a failing top hat bearing or incorrectly torqued strut/top hat nut.
You'll likely be quite disappointed with the coilovers as they will likely be noisy, especially if they use their own top hats.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
04-13-2018, 04:21 PM | #3 | |
195
Rep 178
I'm a bit worried about the BC camber plates making noise, but as I noticed on other BMW and Porsche forums, they seem to be nearly silent. I'll have to check and see if OE tophats can be used. |
04-13-2018, 06:11 PM | #4 |
284
Rep 566
You are looking in the wrong direction. All the things proposed in the OP, individually and especially in combination, are likely to increase the clunking/noise, your primary concern, and decrease comfort. Especially and definitely the camber plates.
04-13-2018, 07:09 PM | #5 |
195
Rep 178
I'm confused... The coilovers I've used in the past haven't been noisy, if at all? Is this just a BC issue? A few members on the forum that have Ohlins, KW and other brands have had no noise problems at all.
04-15-2018, 11:09 PM | #6 | |
650
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I have Ohlins with Vorshlags on my M140i and they are pretty noisy. Not clunks or anything, just a fair bit more road noise. |
04-16-2018, 01:33 AM | #7 |
Rep 10
I was just reading through an explanation on the suspension and came across this:
"When this plate, or the springs get worn, a loud "clunk" is usually heard at full lock (the steering wheel turned as far as it will go in one direction) as the spring frees itself from the proper place on the plate and then snaps back into place. " Think this could be it? http://www.team-integra.net/forum/bl...-i-basics.html |
04-16-2018, 07:57 AM | #8 |
250
Rep 281
I have Ohlins with Ground Control plates. Yes there is more noise than stock. If I didn't track the car and was primarily focused on comfort, I would just go with stock. And yes, they were installed correctly by arguably the best race shop in TX.
04-18-2018, 06:37 PM | #9 |
1330
Rep 2,214
KW coilovers with the KW supplied top hats do NOT make noise, or at least I've never heard this feedback from any of the BMW members, within these forums.. The same can't be said for the rest, though, especially when crossing over different branded hats and coilovers. Never had or heard of noise complaints coming from KW's, and have run V2/3's on my VW/Audi's for years, without added noise or knocking sounds. But they're a bit more pricey than the rest. Also heard fantastic things about Ohlins R&T, again never heard of complaints on those for noise, either. Either way, usually when you go from OE to aftermarket, you get better handling/feel, with the clause of other "pronounced" noises or sounds due to the reduced travel and increased damping. Things like bushings, links, etc become the next weak point after that, but unless you're running a really sticky tire and driving hard all of the time, you shouldn't hear much additional noise, if any, by simply installing coilovers...
I'll be installing my KW's which have the top hats (Clubsport model), and can provide feedback in a couple of weeks once the roads have been swept, here. Cheers, D
04-18-2018, 10:04 PM | #10 | |
650
Rep 2,601
If you reuse stock they should be quiet, I used Vorshlag camber plates and there is a noticable increase in road noise transmitted. |
Dylan861330.00 |
04-19-2018, 12:13 PM | #11 | |
195
Rep 178
Dylan861330.00 |
04-19-2018, 01:13 PM | #12 | ||
715
Rep 1,541
My buddy has them on his M2. Uses OEM top hates. No noise.
04-19-2018, 02:29 PM | #13 |
195
Rep 178
Just got off the phone with my favorite BMW specialist, RRT in VA. They are aware of the issue I am referring to, having experienced it with an M235i and multiple F8X cars. Their theory is that the OEM Top Mount design is the culprit. While I don't entirely understand why this is the case (something about minimal tophat rotation in comparison to previous BMW designs and the shock body), I suppose it can make sense when considering that I have not heard any noises from the rear... despite the entirely different suspension design.
In their experience, the installation of aftermarket suspension with camber plates seems to totally solve the problem. I think I may attempt purchasing camber plates first and see what result I get. After all, this would provide more camber adjustment up front and help me retain the EDC. I also need to redo my brake rotors within the next 5k miles, so maybe I'll just do a close-to-50k miles spa day. Last edited by Sail Boat; 04-19-2018 at 02:44 PM.. |
04-20-2018, 10:45 AM | #14 | |
715
Rep 1,541
04-20-2018, 11:14 AM | #15 | |
195
Rep 178
After researching the forum, specifically the K-MAC thread, this sounds like an awful idea hahaha. I've done quite a bit of research on the manufacturer of the EDC shocks, Monroe (called "intelligent suspension"), which spreads into VAG and other manufacturers... the consensus is that they aren't well liked. Going with the BC BR's w/ Swift Springs, sounds like the best option! Last edited by Sail Boat; 04-20-2018 at 11:23 AM.. |
04-20-2018, 11:31 AM | #16 | |
715
Rep 1,541
05-06-2018, 09:15 AM | #17 |
583
Rep 1,117
Drives: 2015 BMW M235i
I had BC coils on my prior car and noise was definitely pretty bad. They rode good and made the is350 lackluster suspension much better but they weren't the best quality overall. I think I needed a rebuild at around 50k as well.
05-08-2018, 08:50 AM | #18 |
195
Rep 178
In conjunction with a two-month production delay for the BC system and advice from RRT (my preferred BMW shop), I've canceled my BC order and instead ordered the KW V3 Coilover Kit.
Since I'll be unplugging and coding out EDC, I went for the cheaper non-EDC version (great way to save a few hundred $). In regards to achieving an ideal amount of neg. camber, based on advice from my track-hound friend, I'll start with OEM strut mounts and upgrade from there... Perhaps M3 LCAs and camber plates, in that order. Will post an install video later on! Last edited by Sail Boat; 05-08-2018 at 01:09 PM.. |
Dylan861330.00 |
05-08-2018, 01:35 PM | #19 |
1330
Rep 2,214
First impressions with my KW CS's w/50 lbs lighter springs are that they're very tight, no clunks or noise from top hats whatsoever, even over speed bumps and driveways. Got rid of the famous Dinan "click". Pretty happy camper, here.
I'd definitely run the KW Top Hats over the other options. Hoping you have the same experience!
