MY N53 (NOX, Injectors, rough run, sooty exhaust) Is running badly how do I diagnose
02-09-2024, 06:32 AM | #375 |
211
Rep 462
02-12-2024, 01:55 PM | #378 | |
Rep 24
Went back couple weeks later armed with the relevant page for the N53 from the emissions manual 19th edition. Went back a few hours later, pass cert received showing the car passed against the 'standard' limits it had previously failed on. Didn't get to speak to tester but will certainly do so next time I present the car just to 'remind' them. |
02-12-2024, 03:41 PM | #379 |
211
Rep 462
Doesn’t surprise me I have had more than one argument about labda readings and fail on first check. One once suggested it must be because of a leak in the exhaust.
What is the document you are referring too mot 19th? I usually take the bmw printout about emissions and lamda readings now just incase. |
02-15-2024, 06:03 AM | #380 |
211
Rep 462
aha found it!!! very useful if your MOT tester wants to debate Lambda!!
https://assets.publishing.service.go...th-edition.pdf |
03-27-2024, 07:57 PM | #381 |
211
Rep 462
i fitted a new tensioner and measured the spring force
chain tensioner old spring force fully deployed =25lbs new bmw genuine fully deployed 29lbs +- 2lbs |
03-27-2024, 08:02 PM | #382 |
211
Rep 462
some paint on the rear bumper, front wing & new bmw performance sill covers.
all running well, currently have 216 motorsports on, like the 18" on this car. sump gasket / rod bearing check coming soon nox decat - comming soon |
