BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Andoid auto / carplay mmi box for g30 nbt eVo.
      05-03-2024, 02:20 AM   #1
antsgame
Drives: F30 2013
Hi Guys,
What's the best mmi box for g30s? Mine is 2018 model so no carplay etc.
Bluetooth oem connection etc.
I don't like the idea of aux I think it will be more cables and lesser quality on the audio.
I have this in mind: https://www.aliexpress.com/item/1005...b8c889-c815-41
      05-03-2024, 07:20 AM   #2
Sam_M550i
Sam_M550i's Avatar
273
Drives: BMW M550i
I think all these MMI boxes regardless of who is selling them are manufactured by the same company. I believe they are all connected via AUX which in return degrades the audio quality and in return you lose steering wheel functions for track selections.
2018 BMW M550i | BM3 stg 1 | Resonator Delete (X-pipe) | Dark Graphite Metallic
      05-03-2024, 09:27 AM   #3
antsgame
Drives: F30 2013
Hi Sam,
Thanks for that info.
What's the best method to get andriod auto then?
      05-03-2024, 09:31 AM   #4
Sam_M550i
Sam_M550i's Avatar
273
Drives: BMW M550i
Unfortunately it's not going to happen on an iDrive 6 model. I'm using an old iPhone without a sim and Carplay to accomplish what I want since I'm an android user. My Samsung connects to idrive for phone calls still and Carplay for Google maps and Spotify. Do a search, I explain in detail how I accomplished it.
      05-03-2024, 04:17 PM   #5
Sam_M550i
Sam_M550i's Avatar
273
Drives: BMW M550i
https://g30.bimmerpost.com/forums/sh....php?t=2052422
      05-03-2024, 09:58 PM   #6
antsgame
Drives: F30 2013
Wow that's a lot of messing about to achieve this. Highly commend the effort tho.
Im still debating the mmi.
I have tech pack in my car so don't know if the mmi box will effect it?
It's semi automous driving.
      05-04-2024, 02:03 AM   #7
mimoon
Drives: G31
If you use e.g. bimmercode, MMI may block the possibility of coding. I had MMI Andream, it worked fine, but I changed it to an Android screen, a larger size of 12"
      05-04-2024, 05:21 PM   #8
antsgame
Drives: F30 2013
Thanks for that info. Really helps 👍
      05-06-2024, 11:57 AM   #9
capese21
24
Drives: 5 series Msport G30 530e
I have a 2018 G30 fitted a mmi box from Droid UK which is excellent.
Full screen AA and the track selection buttons & volume on the steering wheel work perfectly.
The idrive controller works for all functions to. The BMW NBT works as normal just press the menu button for 2 seconds to switch between the two systems.
The audio through the AUX sounds pretty good and the box has a decent graphic EQ for you to play with!!
These boxes probably are made by the same factory but the software varies. The Droid is the latest version. Don't pay more than about £200. One well known vendor charges £700 and its the same box!!
      05-07-2024, 08:11 PM   #10
Sam_M550i
Sam_M550i's Avatar
273
Drives: BMW M550i
I can't get over the fact you run audio through AUX. Just not ideal for high quality audio.
      05-10-2024, 06:35 PM   #11
antsgame
Drives: F30 2013
So I've went for this: https://hifimaxnavi.com/en-gb/produc...31286588768350
Appears it uses Bluetooth for better audio quality.
Fingers crossed it's good.
Sam_M550i272.50
      05-10-2024, 06:38 PM   #12
Sam_M550i
Sam_M550i's Avatar
273
Drives: BMW M550i
Keep us posted on install and quality of audio.
      05-10-2024, 09:20 PM   #13
antsgame
Drives: F30 2013
      05-11-2024, 12:43 PM   #14
capese21
24
The way I understand it is if you want all notifications, messages Google Maps voice etc. to work then Aux is the only option.
The sound quality isn't bad through Aux certainly not on my Droid UK supplied box.
I really don't want to be switching inputs every 5 minutes. Set to Aux everything works.
There have been lots of firmware updates since these boxes were first available which has fixed most of the niggles.
5post
