10-14-2013, 06:30 PM | #1 |
Rep 14
2013 F30 Rear Window OneTouch/AutoUp Problem
Had my dealer program the car so that Auto Start/Stop retains the last chosen setting. In the process of doing this none of my windows would operate up or down in OneTouch mode (single press to roll up or down). I went through the simple procedure of holding the button all the way up and down for 5 seconds after the windows opened/closed. Fronts work fine now.
The rears will roll down with OneTouch but will NOT roll up with OneTouch. This isn't a huge deal but it is annoying. Called the dealer and they told me to try what I had already tried several times. Are there any techs who know the proper procedure to enable this feature? Thanks, Kerplunk Last edited by kerplunk38; 10-20-2013 at 07:37 PM.. |
11-11-2013, 03:07 AM | #4 |
129
Rep 166
My cars driver side window has the same issue
How ? What was the solution ? Winder ? Switch ? Or a simple programming issue ?
BMW F30 328i (A/T) | Toyota Fortuner 4x4 (M/T) | Toyota Hyryder Hybrid (e-CVT) | BMW G20 M340i | Skoda Kushaq (A/T) | Kia Seltos (DCT) | BMW E46 328i (M/T)
12-04-2013, 07:03 PM | #5 |
Stormtrooper
57
Rep 244
I need a fix too...all my windows EXCEPT drivers works with one touch up and down. On drivers, down works fine, but up doesn't...interesting.
07-17-2019, 06:00 AM | #6 |
A family of bimmers
2747
Rep 7,742
I just had this happen to me as well. Both my rear windows lost their one touch up feature after being at the dealer and the dealer programmed the car because i had a broken cooling fan replaced (apparently programming is required) I have tried the manual reset but it wont stick. Any ideas? Is there programming i can just do to fix this with esys?
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-18-2019, 07:58 AM | #7 |
A family of bimmers
2747
Rep 7,742
Dealer had to recalibrate the pinch sensors for me. I tried doing the manual reset but they had to hook it up to some software to reset it. They are working now
