Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Quick question regarding NCS Expert
      04-23-2024, 09:33 AM   #1
Benjiman
Drives: E93 335i
2009 E93 335i  [0.00]
Hey guys, real quick one here.
I'm trying to code a replacement SMC for my left side headlight, I've read I should code both left and right, and also the NFRM.
This is the procedure I have found;
1) Start NCSEXPERT
2) Load Expert Mode
3) Press F1 VIN/ZCS/FA
4) Press F3 ZCS/FA f. ECU
5) Select your CHASSIS (E89 in your exmpale)
6) In this step you will see 3 options (CAS/NFRM/FRM) - Choose CAS and click OK
7) Your VIN should be determined now
8) Press F6 (BACK)
9) Press F4 (Process ECU)
10) Select RSMC and click OK
11) Press F2 (Change Job)
12) Select SG_CODIEREN
13) Press F3 (Execute Job)
Then the same for the LSMC, then NFRM.
My question is, I have seen a few threads with the procedure posted, however some differ at step 6. Some say to choose CAS, some say there will only be one option and to choose that one. Mine has all three options.
Is it correct that I choose the CAS option?
Car is a 2009 E93.
Thanks
      04-23-2024, 04:42 PM   #2
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
CAS
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      04-23-2024, 06:13 PM   #3
lowrydr310
Robot
1691
Drives: 2006 330i, 2007 E93 335i
Short answer, it shouldn't matter which one you choose. The VIN and VO are stored in those modules, and that's all NCSExpert is reading at that step of the coding process, to get all the options so it knows what to use when default coding the other modules.
There could be some weird cases where your car was coded in the past and someone didn't do it correctly; maybe someone changed the VO or replaced a FRM and never updated the VIN, but that's extremely unlikely. If you're ever permanently changing the VO, make sure you write those changes in CAS and FRM/NFRM.
      04-24-2024, 12:01 PM   #4
Benjiman
Drives: E93 335i
Thanks guys, all sorted. Appreciate the explanation lowrydr310 now I understand it.
