12-03-2020, 12:12 AM | #67 |
2826
Rep 3,701
See posts #42 & 44.
You’ll need the M235i v-brace, and then decide if you want to chop up the M2 brace or fashion your own bracing to connect the lower support points. |
02-20-2021, 02:49 AM | #68 |
437
Rep 485
. Any way you can take a picture ASAP of how you guys bent or made a new vacuum line that goes to the charge pipe. The Wagner pipe has the bung in a different location than the stock m2 line will reach to. Anyway you can help please?
This is the only thing that's holding me back on my install. |
02-20-2021, 06:36 PM | #69 | |
2826
Rep 3,701
02-21-2021, 12:28 AM | #70 |
437
Rep 485
Alright guys. So I got my evo3 installed today (labor done by yours truly!)
The OPs original post pretty much sums up about 90% of what you need to know. Here are the answers to what he's missing. You need to remove the lower plastic pieces that are vertical on the sides of the IC tank. You also ditch the lower IC shroud completely. The vertical pieces kinda attach to that and then clip into the upper frame rail and the upper duct. The piping- the white lettering faces the front bumper. The vacuum line. I didn't want to just crank it around to the new angle needed to meet the Wagner pipe so I slowly heated it with a heat gun and twisted it where I wanted it. Off the car. The IC bolts that connect to the bumper bar. Get yourselves to aluminum tube stock or a pipe, cut it at 2.25" and it's a perfect spacer between the IC and bumper bar. This will really make things rigid and solid. Sorry OP but how you have those bolts isn't doing a hole lot for support. I wanted my IC to have like zero flex. You HAVE to get the 235 v bar thing. And cut the shit out of your stock m2 brace to make little vertical lower braces. I used a 4" cut off wheel and flapper wheel. Made quick work of the aluminum. Also need 3/4" long bolts to bolt the 235 back to the frame rails. I think that's everything. Personally I though it was Pretty easy to do everything with the bumper off. Definitely make sure you have a good amount of tools and are handy with cars! |
ZM22826.00 |
02-22-2021, 10:04 AM | #72 |
BimmerPost Supporting Vendor
24331
Rep 191,093
@AWC-F87 Thank you for sharing
Do you have pictures of the intercooler installed?
02-22-2021, 10:24 PM | #74 | |
437
Rep 485
Definitely stoked to have it on! Appreciate your help! |
02-24-2021, 07:06 PM | #75 | |
333
Rep 390
The harder you push the better it performs. |
02-24-2021, 09:55 PM | #76 |
4045
Rep 877
Drives: ///M2
@GerardzM AmuroRay can we get a confirmation that the Wagner 3 is the best performing intercooler on the market currently?
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
02-25-2021, 11:02 AM | #77 | |
2311
Rep 4,172
All we know for sure is that it's a significant step up from the other 6" intercooler cores (size refers to depth)
Mods: Yes.
03-02-2021, 10:02 AM | #79 | |
24331
Rep 191,093
In my opinion, its the best balanced for heavily tuned cars with stock or upgraded turbo
03-02-2021, 10:45 AM | #81 | |
2311
Rep 4,172
I see a lot of people post about ICs throughout the years, most of it just ended up being hype.
Mods: Yes.
03-02-2021, 11:17 AM | #82 | |
55
Rep 147
This one works and it's not stepped, it is expensive tho |
08-21-2021, 05:29 PM | #84 |
2311
Rep 4,172
08-21-2021, 06:58 PM | #85 |
437
Rep 485
That's sweet they made that change! I think I posted about it before. The long bolts wouldn't do a ton for rigidity. But spacers definitely do. That's why I made my own spacers.
08-26-2021, 05:10 PM | #88 | ||
400
Rep 463
Evo 3 FMIC Install/Review
Just out of curiosity, what's your build date? |
