StrutBar for 335xi Sedan (E90)
01-25-2010, 01:55 PM | #1 |
325
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Is there a strut bar for our E90 xi? Looking to make my car more stable than its' already is at turn and high maneuver change lanes. With all the increase power my car has now, I'm looking to make it safer at turns. Brakes seems to hold up fine coming from a high speed.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
01-25-2010, 02:15 PM | #2 |
30
Rep 1,748
this should really be in the XI section or Suspension section, but I did a quick search and this thread might answer your question:
http://www.e90post.com/forums/showth...light=sway+bar Im sure you can find other threads that discuss this. Good Luck
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
01-25-2010, 02:29 PM | #3 | ||
"Booty Hole Bandit"
32
Rep 1,597
2008 Montego Blue E92 335xi - MT - Sport - Cold Weather - Nav - iDrive - PDC - Logic7 - CA MODS: Unknown |
01-25-2010, 02:40 PM | #4 |
325
Rep 2,663
Thanks. My car handles great stock. Just need a strutbar up top to handle better on high speed maneuvers. I would like to change suspension, but its a lease so don't want to put more $ in this.
01-25-2010, 04:20 PM | #5 |
161
Rep 7,377
wont the M3 one fit on XI?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
01-25-2010, 06:04 PM | #7 |
30
Rep 1,748
That's why I suggested sway bars, but not sure if that will help the OP much, specially a lease..
01-25-2010, 06:45 PM | #8 |
325
Rep 2,663
what will you recommend? i remembered i added a strut bar for camry and made night and day for car. less body roll.
01-25-2010, 07:41 PM | #9 | |
442
Rep 18,331
Lowering your center of gravity will make it handle like a go kart and create less roll on turns and thats what your looking for correct? Can't go wrong with these...cost about the same as strut bar only thing is you have to pay for suspension install and taking them out when lease is up... http://www.jlevistreetwerks.com/3-Se...duct_info.html |
01-25-2010, 07:44 PM | #10 |
Moderator
618
Rep 10,858
Strut 'bar' = brace that stiffens the chassis. Strut brace has no effect on body roll. Sway bars affect roll. But roll is not bad for handling. Messing with sway bars on an xi is not a good idea. Lowering springs are also usually not a good idea by themselves. I would suggest:
1) posting this thread in the correct forum (hence my moving it...) 2) contacting vendors that can provide good advice, e.g., Harold at HP Autowerkes or Jay at Ground Control.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-25-2010, 09:34 PM | #11 | |
40
Rep 818
01-26-2010, 01:58 AM | #12 | |
Gearing
86
Rep 3,962
The XI forum has a few threads with some of the details you are looking for and you'll want to look up Harold and Orbs repartee on some of the other suspension bits to replace on the rear and front end. Strut brace with the OEM shocks is pointless.
If at first you don't succeed ...
01-29-2010, 05:38 AM | #13 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
i put in a helix "Cross" front strut brace on my 2008 335xi. love it and it clears the stock air box.
