New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      10-05-2018, 05:49 PM   #23
bryanhoag
44
Drives: 2013 Z4 sDrive 35i 6MT
So. Used the camera a little more today. And I will probably try a different one at some point. But what I have currently is better than no camera at all.
This is the camera I currently have:
Accele TLP100IRBL License plate frame backup cam with active parking lines
https://www.amazon.com/dp/B07CSF7KD1..._aB-TBbD711C12
The line width is determined by the camera but seems to closely approximate the width of the car. The large, dotted, multicolored lines are static. There are thin red lines that turn when you turn the wheel, you can see them in the photo in my prior post.
However, the thin red lines do not seem to approximate the turn of the wheel accurately.
The camera can be tilted up or down, which helps with it being mounted so low.
I haven't tried driving far in reverse using the camera. I only really need it for backing out of parking spaces and my short driveway.
I may try a more basic camera. I'd like to fix the image offset on the iDrive screen that I mentioned above. And, while I like lines that turn with the wheel, I'd rather have static lines only than turning lines that are inaccurate.
*Edit* — the larger lines also turn with the camera I have but again do not approximate the turn of the wheel particularly well.
      10-09-2018, 03:35 PM   #24
tommylotto
Drives: 2015 BMW Z4 sDrive28i
Thanks for the info. I think those cameras with active lines detect the actual physical turning of the car, not the turning of the wheel. So, the lines would be reactive not predictive, and would probably lag in reflecting the car's actual trajectory. I would imagine it would be better than nothing and better than regular static lines. But you seem to think it is worse.
      10-10-2018, 04:13 PM   #25
bryanhoag
44
You bring up an interesting point.
I agree that an aftermarket, non-OEM camera with turning lines would likely be reactive rather than predictive. However, with the camera I have... the thin red lines turn with the wheel even when the car is not in motion (albeit, inaccurately... they turn much more rapidly in when turning the wheel to one direction vs the other). This would suggest that they are predictive.
On the other hand, the larger lines only turn when the car is in motion, suggesting that they are reactive (and their reaction is not particularly smooth with frequent corrections).
Question for those who know more about this stuff.... Can information other than just video be sent via the yellow RCA cable? i.e. can predictive information based on the turn of the wheel be sent to the camera? Somehow the info is getting from the wheel to the camera and I can't imagine its via the 12v. I didn't give it much thought at first... but now I'm curious.
Regarding preference. My jeep with OEM curving lines is great. My gf's beetle with static lines is fine. This aftermarket system with choppy, frequently re-correcting, reactive turning lines is just distracting. Maybe other aftermarket cameras are better. Or maybe there are adjustments I could do to improve this one...
      10-15-2018, 01:18 PM   #26
briankreed
Drives: 2014 Z4 35is
Couple of questions
bryanhoag, able to use Siri for most things and mic works well? When you start-up the car, does it automatically go to CarPlay if it was the last thing on the screen when shut down? Last question, does it have another video input either composite or HDMI to use for a FireTV or such?
      10-15-2018, 02:14 PM   #27
bryanhoag
44
Yes, Siri works well. But, as mentioned previously, you do have to run a separate mic.
Unfortunately, when you start up the car, it defaults to the iDrive system, so you always have to switch to the CarPlay system upon start up (even if you were on the CarPlay system when you last shut the car down). However, the back up camera initiates automatically in either mode.
That is one of my few complaints about this system. You always have to switch to it on start up. And... if you start directions in CarPlay, then toggle to iDrive, then toggle back to CarPlay, you have to restart your directions. But, its not that big of a deal.
There is no other video input source. Only a yellow RCA plug.
      10-19-2018, 12:51 PM   #28
Dusty78
17
Drives: 2012 Z4 28i
Originally Posted by tommylotto View Post
I am not sure with your set-up. I am no expert. My car has the six speaker set-up. What I can report is that both installers told me that installing the Joying would require a complicated retrofit -- either rewiring the whole thing or installing a new amplifier. They were both telling me the amplifier is digital and yada, yada, yada, it will never work. However, once they installed the Joying with the German harness that I brought to them everything worked perfectly fine, including the stock speakers and stock amplifier.
Now, I could be wrong, but it is my understanding that the German harness somehow gets the audio signal properly from the head unit to the amplifier. So, it should not matter if you have a 6 speaker system or a 10 speaker system. Once the audio signal gets there, everything else is being handled by the amplifier. My amp would divide the signal 6 ways, yours 10. Like I said, I could be wrong. However, both my installers were definitely wrong. I'd insist that they try to install with just the harness to see if it works before I agree to anything more drastic.
Also, when ordering the harness, they ask you to send a picture of the Joying wiring diagram. Apparently, there are several wiring systems for the "no-name" Chinese head units. They need to know which wiring system your head unit uses to give you the right adaptor wire.
So I got all the parts in and the harness doesn't work. My car is wired up with fiber optic cable but they harness isn't. Back to the drawing board. Is your car also wired with fiber optic? I wonder if they sent me the wrong harness.
      10-19-2018, 03:57 PM   #29
tommylotto
That was the exact same thing my installer said to me. The BMW amp uses fiber optic cable and this harness didn't have fiber optics so it cannot work. In fact, I looked through my records, and they had me take a photo of the Z4's harness to prove to me that the harness I bought would not work. Here is the photo:
You can see the fiber optic connections in the lower right, and those areas were blank on the German harness that I bought. (Sorry, I do not have a picture of the harness that I bought.) They told me I was going to have to spend extra money and buy a new amp, because my harness would not work. BUT IT DID. An hour after I left they called me back and told me they hooked it up with my harness and it worked. I wish I could give you more technical information as to why, but I didn't ask. They said it worked without a new amp, and it worked. I didn't think to ask why what they told me earlier was wrong.
What I got from the Germans was a three-way harness that connected to the car harness (pictured above), the Joying head unit, and a black box that came with the German harness. The box box had two connections to it. One connection connected to the harness, the other connection connected to an adaptor cable they sent that was specific to the Joying radio type. I did find a picture of this adaptor cable:
That adaptor cable connects directly to the Joying to provide the steering wheel controls. This was not explained in the instructions. So, I had to contact the Germans to figure out what wire on the adaptor connected to which wire on the Joying. Here are their instruction:
Hi there,
you have to connect the brown (KEY1) with the red one from our adapter. Then connect the pink cable (KEY2) with the white one from our adapter. You don't need the black lose cable which is already on our adapter.
You only need the orange cable which is named ''back'' if you want to install a rear camera.
If I were you, I would ask my installer to humor me and try to hook up the Joying with the harness and see if it works. It worked for me, in spite of what the professionals were telling me... Maybe that black box performs some magic that circumvents the need for the fiber optic connection. I don't know. All I know is that it works.
Good luck.
      10-19-2018, 06:09 PM   #30
Dusty78
17
Drives: 2012 Z4 28i
Hi there,
Good luck.
[IMG]https://www.dropbox.com/s/2ujo0z5rc8...0197.jpg?raw=1[/IMG]
[IMG]https://www.dropbox.com/s/2rrn1ox9n9...1%29.jpg?raw=1[/IMG]
Hi there,
Good luck.
So my installer is pretty gung ho about the halo radio and trying that first. I have the automatic so the shifting won't be an issue. Did you ever install the halo with the German wiring and have it work? The way I see it I'm going to drop it down to the lowest point so it doesn't cover the HVAC controls too badly. The top open/close and heated seats will be obscured but I can still easily reach in under and activate the buttons. The top control buttons have little bumps for tactical reinforcement. I still have the Joying as back up just in case. The Germans asked me what radio I had and asked for the wiring. I sent them the halo wiring and this is the harness they told me to buy. I wonder is yours is different as the one they had me buy wasn't exactly the one you sent a link to.
      10-19-2018, 09:00 PM   #31
tommylotto
By Halo, do you mean the Alpine Halo. If you think you can get that to work, more power to you. It is a better more reliable unit all around. It will work as intended, because Alpine is a major company and cannot afford to sell crap. I just think that screen is too big, but maybe it works for you.
If you bought the harness for the Halo it probably will not work for the Joying. The site selling the harness was pretty particular about which head unit you had, and Alpine was a different product from no-name Chinese. Looks like your setup came with two black boxes, not one. So, it is definitely not the same thing I had.
Good luck.
      10-24-2018, 07:01 PM   #32
bryanhoag
44
A few brief updates re: UniChip SmartBox
1) There were some concerns early on about future support for iOS updates, etc. UniChip support sent me two update files recently to load onto USB drives and plug into the USB port of the SmartBox. Very easy to update.
2) Back up camera issue with image being shifted upward on the screen was not fixed by the update. Nor was it fixed by using a different camera. So it's an issue inherent to the SmartBox (perhaps mine is just a dud?). Still better than not having a camera.
      01-29-2019, 01:44 PM   #33
Go351
22
Drives: 2016 M4 Coupe Sakhir Orange
Originally Posted by airmarc View Post
Greetings all,
Here is an update. I opted for option 2. The unichip Smart Box from China.
I installed it last week and it works flawlessly. I am very impressed with the full apply car play functionality.
The installation was not the easiest but it is almost completely plug and play.
If anyone needs advice or has questions please send me a PM.
Heres the Pros:
-Seemless integration to Idrive
-Can use steering wheel buttons and Idrive controller for carplay controls
-Ask Siri functionality
Cons:
-You must use their aux in wire to plug into the jack under the arm rest, means hiding a wire
-Phone has to be plugged into their USB input wire
-Placement of smartbox is tricky. They state that it can fit behind the CIC unit but its tight. Alternatively you can remove the panel under the glovebox and wire back through there.
-You must use their mic, which is supplied, but that means another wire to hide
Hi
I'm thinking of going with Unichip carplay too. How has it been for you. Any issues after 6 months? Os or firmware Updates?
Thanks
      01-29-2019, 01:59 PM   #34
Go351
22
Hi
Do you have to press any buttons to get backup camera image on screen. Did you have to splice into reversing light wire or dies the carplay box take care of that?
Thanks
      01-29-2019, 08:06 PM   #35
bryanhoag
44
Originally Posted by Go351 View Post
Hi
Thanks
No... back up camera shows up automatically whether you're using iDrive or the CarPlay smartbox. Camera disappears after moving forward for a few seconds and goes back to whichever screen you had been on before backing up.
You do not have to splice into the reverse light wire. The carplay box does that for you (which is awesome).
Go35121.50
      01-30-2019, 09:41 AM   #36
airmarc
22
Drives: '10 BMW Z4,'14 BMW X3, '17 X1
Hi
Thanks
Awesome, no issues. Totally happy.
      01-30-2019, 01:23 PM   #37
Go351
22
Hi
Thanks
Thanks. I'm keen to install a front camera also. But not sure how to do it as the smart box only has one video in?
I thought about splitting the two camera outputs to the smart box but then that only work if the smart box has an option to turn on video feed when not in reverse?
Have you thought about a front camera?
Lastly, where did you route the camera cable to get to the rear number plate?
      01-30-2019, 10:17 PM   #38
bryanhoag
44
I've never considered a front camera. I'm not really sure how it would be done... Definitely beyond my level of expertise.
Regarding turning the smartbox video feed on... I have PDC and I can press the PDC button to turn the camera on or off regardless of which direction I'm moving. So, if you have PDC, that may solve that issue for you.
As far as running the cables... I ran through the armrest, through the ski pass through, into the trunk and through the battery compartment. Then I had to remove the big plastic rectangular piece of trim at the back of the trunk (with the little light in it). That is a bit of a hassle to remove because you also have to remove trim pieces on both sides of it to get it out. Once out, there was already a hole in the back metal that I was able to pass the cables through (but you could drill one if there wasn't one there). The only hole I had to drill was a small hole in the bumper immediately above the license plate. I taped the cables to a clothes hanger and was able to fish them through the plastic hole and the metal hole.
Hope that helps... have fun!
      01-30-2019, 10:35 PM   #39
Go351
22
Thanks for the installation tips. I do have pdc so it. Might work with a 2 input video splitter.
Cheers
      01-30-2019, 10:38 PM   #40
Go351
22
Hi
Thanks
Thanks. Ordered one.
      02-01-2019, 05:33 AM   #41
Go351
22
Cheers
Hi
I have spent half the day installing the system. Can you please give me an idea where in the metal back is the hole to the license plate. I have removed all the trim as per your post. There's a number of small holes, but they seem to only go into an inner skin of the panel.
My next step is to remove the bumper but want to avoid it if I can.
Also. Does your messages in CarPlay work? When I click on a message header, it wants me to send a reply. I can't view the message.
Does your system video image blink now and then.
I can find any info for the dip switches. I suspect they set screen resolution and size, which may be my blinking issue...
Thanks in advance.
      02-01-2019, 10:21 PM   #42
bryanhoag
44
Hey.. sorry the wire running has been such a hassle. It's been so long since I did mine, its hard to remember exactly what I did. But, the holes through the metal were at the midline. As I'm thinking about it, I think there may have been two holes through metal. I'm pretty sure I drilled my hole through the plastic bumper above the license plate and then poked a clothes hanger through that hole aimed upward and then looked down through the metal holes from above at the tip of the hanger and just moved it around until I managed to get it to poke through the first metal hole and then worked it through the second.
I know that's probably not the easiest to follow and I apologize that I'm trying to remember exactly how a project went that I did months ago.
But, I did not remove the bumper. That would be way more of a hassle that I'd want to deal with.
I honestly don't use iMessage/text in CarPlay. But, I do know that CarPlay in any car doesn't show you the actual message. Siri reads it to you and asks if you want to reply. Not sure if that is what you're asking..
I have not had issues with blinking. I'm sure you're right about the dip switches. I just left mine as they were when delivered and it worked correctly. But I'm sure if you contact UniChip support and tell them you have a Z4 e89, they can tell you exactly how the switches should be set.
      02-02-2019, 06:00 AM   #43
Go351
22
Hi
Thank you. I searched for an hour. No holes that goes outside anyways in the back of my 2013 car.
I ended up going though the gromet that carries the hose for the exhaust valve. Gosh it was a painful job to route the cables though the car. Well made car and I'm too old to twist that much
Re carplay. Thanks for the heads up. I hadn't use it for messages in a factory setup either. My Unichip ver doesn't read the message. It just wants me to dictate a message.
Appreciate your help. It's all done now and I'm pretty happy to have a reversing camera got the z4!
Cheers
      02-02-2019, 06:48 AM   #44
bryanhoag
44
Glad it worked out! Question... do you have the issue where the image is shifted up on the screen with part wrapped around to the bottom when you're using the reverse camera?
Tags
apple car play
zpost
