Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Transmission Limp Mode in D but not D/S or M
      04-24-2014, 07:00 PM   #1
just_dirty
69
Drives: RR Sport, F10 550, F450, E92
The transmission after being driven around in (D) for a short while will give the warning light with the gear indicator and will then be in limp mode. It will go out of limp mode right after restarting the car. The odd thing is that I can drive in (M) mode all day long and there are no issues. I have even done a handful of track days and no trans limp mode at all. I'm not getting any slip or any indication of a problem in (D) either. Hoping some of the more knowledgeable members can chime in here. Cheers.
      04-24-2014, 07:17 PM   #2
DesertDude
Drives: 2013 335is E93 DCT
Are you running a tune?
      04-24-2014, 07:37 PM   #3
just_dirty
69
Nope, Bone stock
      04-24-2014, 10:05 PM   #4
AK 335i
AK 335i's Avatar
48
Drives: black 335i E90
Originally Posted by just_dirty View Post
Nope, Bone stock
try the alpine flash.
maybe add a cobb flash or jb5?
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
      04-24-2014, 10:23 PM   #5
just_dirty
69
I wish I could add an alpine flash! Mines an 06 build date . Do jb5 and Cobb flash the trans?
      04-24-2014, 10:27 PM   #6
AK 335i
AK 335i's Avatar
48
No :/
But can't hurt. You can run mild tune and also be able to check codes and log and see why is happen mayhap by watching throttle and rpmS etc.
      04-25-2014, 01:05 AM   #7
Hai-tek7
Drives: E90 xdrive LCI - stock
Check your fluid. Had the same thing and dealer said fluid was alittle low. I didnt try DS or M though
      04-25-2014, 01:37 AM   #8
Kenu8187
Drives: E90 335i
Check fluid and have the dealer reinstall the trans software if the fluid level is normal. Seems odd that the issue is only in D which should also happen in DS/m if it were fluid, logically
I think the software reinstall is just like 1hr worth of labor so ~150ish
      02-09-2017, 08:36 AM   #9
nbravo
nbravo's Avatar
Drives: 2007 e92
What ended up happening? I have the same issue. Not any signs of trans issues besides a harder shift down from 2-1 which is supposed to be the solenoids in the transmission. And I was told that issue wouldn't even kick a code. So if I drive in manual its fine and even if I drive the auto trans its mostly fine. It did have a fault code from going into limp but my tech has not called me about it in over a week. So annoying. Anyway I was curious of your end result. Thanks!
      02-24-2017, 05:51 PM   #10
just_dirty
69
I swapped the Fluid with Redline D4 and it seemed to help the trans a fair bit (in terms of feel). Then I dropped the pan and swapped the filter and did another fluid change and it made a pretty drastic improvement. My problems seemed to go away after that but I really didn't drive in D a whole lot. The car was converted for full track duty about a year ago and the transmission gave up the ghost about 8 months ago. Not too bad considering that was after 2 seasons of Autox, 1 season of HPDE, and another season of Time Trials.
Frozen Black Widebody E92 : VRSF CP, N54Tuning Downpipes, Tial BOV, DCI, MHD Flash, Aquamist HSF-3 Meth kit Dual Nozzle, Megan Racing Toe Arms,Megan Racing Camber Arm, Megan Racing Trailing Arm, IND Delrin Subframe Bushings, M3 Control Arms,Fortune 500 Series Coilovers, Square 18x11 Apex Ec7 w/ 315/30/18 Hoosier R7's
