2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F10 5-series KW Variant 3 (V3) Review
      02-06-2011, 01:09 PM   #1
LACSTER
761
Drives: Hybrid
Thumbs up F10 5-series KW Variant 3 (V3) Review
Bavarian Exclusive did all the installation, as I'm not a mechanical person and have no clue what to do. I went with the KW's variant 3 because I needed something lower then my current spring setup with RD Sports. I've always wanted a full coilover suspension and with my new F10 what better time is it for me to do it
I'll keep this first post as my "reaction" to the new set up, and post drop measurements, pictures, etc. later in the review.
WOW!!!!!! is all I kept saying on the ride home from Bavarian. The car is completely different. The car "feels" lighter, like it lost a lot of weight. Body roll? Whats that? The F10 now tackles corners like a BMW should and not the boat feeling I had for the first month or so with the stock suspension. The RD Springs helped reduce that but I was not completely satisfield. It feels so flat around a turn. It took some time to re-learn how to drive it, it's that different. Coming from completely stock to this, makes me feel like I'm back in my E92. Okay well not that far but 100 times better now
Ride quality. My settings on the KW's are the out-of-box settings. I have not messed with the rebound/compression yet. The ride quality is not bad at all. I'm lucky enough to live in an area where we have very nice smooth roads. The V3's are stiffer then stock, thats for sure, but it's not annoyingly harsh or rough, and I'm on 20's. But the suspension has a tiny bounce to it. And I mean a tiny bit, no where near the bounciness of stock or the RD's. My wife was following me in her SUV on the way home from Bavarian, She said she could see a slight bounce, but it was not really noticeable, that it looked like a race car. It's not a constant bounce, it only really happens when their is some sort of dip in the road, and it like bounces back into place (1 bounce). Does that make any sense?
"75" on the freeway feels like 30, the car feels so planted on the ground. The stock ride was boat-like to me, very "floaty" and I felt disconnected from the road. Now I feel like I'm in full control of the car. The steering feels tight, I feel like there is a new tighter steering rack on the car. The steering wheel snaps back into place after a turn. My braking feels tighter as well, no nose dive, and I feel the F10 stops faster for some reason.
The F10 now feels neutral and light. Like it's ready to fight.
Was it worth it? YES!!!!! I definitely recommend the KW's, if you want the ability to dial in your height and stiffness, and get awesome handling with out spending an arm and a leg, this your ticket.
As promised here are some before and after pics along with some install pics as well as the specs.
Before with RD Sport springs
After with KW Variant 3 slammed
Here are some pictures with the stock shocks and RD springs and some with the KW variant 3's
Some close up pictures after install of the front and rear
The drop for the V3's can go from 22-55mm front and 20-50mm rear.
Here's some info from KW's website on the V3's
KW Variant 3 inox-line – Perfect Street Performance
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
Damping technology with individually adjustable rebound- and compression technology
inox-line* stainless steel technology
Individually height adjustable
Adjustment parameters approved by the German Technical Control Board (TÜV)
High-quality components for long durability
Infinitely variable rebound damping adjustment
14-way adjustable compression damping
Unique, individually working damping force adjustment
Comprehensive documentation for easy use
Compression- and rebound adjustment
As far it is vehicle-specifically possible, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and also influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be adapted to the requirements of the driver. Moreover the driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics.
The compression phase adjustment is carried out at the lower end of the shock absorber via our patented multi-purpose valve. The large number of pre-set parameters of this valve allows for a wide range of adjustment for individual use. The unique low-speed compression adjustment significantly distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
      02-06-2011, 02:17 PM   #2
luigimaster24
luigimaster24's Avatar
Mexico
159
Drives: 2020 X7 M50i & 2021 X6M Comp
Great review!! Definitely some helpful information for us contemplating on going for some KW V3's for our F10.
      02-06-2011, 05:16 PM   #3
MF80
MF80's Avatar
Thailand
45
Drives: AW 2008 E92 335i
You used to have 350Z and GTR R35?
Nice F10 man.
      02-06-2011, 05:29 PM   #4
DimSum
202
Drives: SLOW
Wow.............. that looks so nice... I want a f10!
      02-06-2011, 05:34 PM   #5
new2the3
new2the3's Avatar
380
Drives: 2020 X3M Competition
Too low, raise it up to a classy drop and your car will look great IMO.
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB
      02-06-2011, 05:44 PM   #6
numba1guju
numba1guju's Avatar
27
Drives: 2015 VW Jetta
v3 is definitely best way to go...nice write up...get a bigger set of wheels...the wheel well doesnt seem to be full enough
SOLD: 2013 328i Mineral Gray ZMM/ZLP/Heated Seats
SOLD: 2002 325i Jet Black ZPP
      02-06-2011, 05:51 PM   #7
GOLFFRR
GOLFFRR's Avatar
10817
Drives: GOLFFRR cart
baller
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      02-06-2011, 07:07 PM   #8
Zulu Saffa
Zulu Saffa's Avatar
300
Drives: Them Wild
Nice. I am in OC too, will look out for your ride.
      02-06-2011, 07:13 PM   #9
LACSTER
761
Drives: Hybrid
Thanks Lui.
Nice F10 man.
Nope think you might have me confused with Alex aka 78mao
Thank you sir
Yes it has been raised since than. I only slammed it for SEMA 2010
Yeah its the only way to go
Originally Posted by GOLFFRR View Post
baller
You got to fake it before you make it.
You catch me in Irvine during the weekdays.
      02-06-2011, 07:54 PM   #10
Diver
Diver's Avatar
504
Drives: Black '12 135i - Sold
Looks a bit low for a 5 series.
      02-06-2011, 08:05 PM   #11
SamS
867
Drives: Tesla M3 Perf + '18 X3 M40i
Somewhere, in Germany, there is a BMW engineer crying a bit.
      02-06-2011, 08:07 PM   #12
BMWinNorthdakota
244
Drives: 2007 bmw 335i e90
Those wheels+ that drop=Ghetto fab.
Not diggin it.
      02-06-2011, 10:11 PM   #13
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
Lacster, that looks tight man.
I have a question though. What about road noise? Having 20" wheels, and a lower set-up; did the road noise increase, or remained the same as was the previous set-up?
      02-06-2011, 10:51 PM   #14
Makkasteez
1nt3n5ity
Makkasteez's Avatar
39
Drives: 08' 135i
beautifulll
      02-06-2011, 10:57 PM   #15
sti2bmw
sleek e90
15
Drives: 2009 e90 lci
Absolutely amazing ....to tell you the truth it OFF THE CHAIN!!! love it.
      02-06-2011, 11:01 PM   #16
ddigangi
'Murica
48
Drives: 2006 E90 330i
2006 E90 330i  [0.00]
lol thats an awesome setup but the gthaus 535i had the variant 3 coillovers back in september
Web developer at @ Apartments.com, digital media director, budding entrepreneur, technology guru and marketing nut with an affliction for the finer things in life.
I blog at http://ddigangi.com
      02-07-2011, 12:25 AM   #17
yoyeewee
yoyeewee's Avatar
109
Drives: 2007 BMW M6 coupe
Not diggin it.
LOL! It's not Ghetto fab but is Hellaflush! Ahahahaha!
2008 335i coupe Atlantic Blue with Black Leather Steptronic ZSP ZPP NAV PDC COMFORT ACCESS REAR SUNSHADE HEATED SEATS HD RADIO SIRIUS USB/IPOD 20" Klassen K5.1 3-piece wheels w/Toyo Tires Job Design Body Kit M3 Trunk Spoiler Eisenmann Exhaust Eibach Pro-Kit Springs
      02-07-2011, 12:25 AM   #18
yoyeewee
yoyeewee's Avatar
109
Looks great Kev...now you just need to get 22's and a Big Brake Kit
      02-07-2011, 12:57 AM   #19
Saigon
Saigon's Avatar
234
Drives: BSM E92 335i Coupe
nice man, always looking good
07' Alpine White E93 335i
M-Sport | BMW Performance | Beige l Piano Black l Sport l Premium l Heated l Navi | Steptronic l Comfort Access l Logic7 l iPod & USB |
      02-07-2011, 01:12 AM   #20
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25117
Drives: '22 Chalk Gray Porsche C2S
I agree with this.
      02-07-2011, 03:19 AM   #21
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
Great review, Kev. You need to show photos of your new set up and wheels, your car looks even better now.
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      02-07-2011, 03:39 AM   #22
hks786
2169
Drives: *
+1
5post
