Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede v5 User Maintained Owners Manual
      10-06-2011, 09:46 AM   #67
FirstBMWLA
FirstBMWLA's Avatar
187
Drives: 2007 335i Coupe
Procede newbie here, just swapped from JB4. Is it normal for the dash cluster to do the lightup scan thing on each start?
Also since I was running JB4 previously are there any adaptations or resets I should perform to ensure Procede works best?
Thanks all
      10-06-2011, 08:32 PM   #68
mikeith
mikeith's Avatar
35
Drives: 07 E90 335i. TiAG
as long as you reset back to stock map before uninstalling just to be safe you should be good. and on the center led sweep... totally normal. mine does it every time
      10-30-2011, 07:48 PM   #69
n54noob
n54noob's Avatar
Drives: 2008 335xi
2008 BMW 335xi  [0.00]
looking forward to getting mine in a couple weeks
      04-12-2012, 09:34 AM   #70
Themythx
Themythx's Avatar
Drives: 2008 335i
Originally Posted by mikeith View Post
Just want to say thanks to robert and shiv for helping me troubleshoot this problem even being as little as it is. Im not near as proficient as I should be for such a system but it will get better in time. Got everything up and connected!
Shiv if you are listening you should really look into outsourcing someone to make you an ois app that can run the user software and connect to the rev.3 v5... There are USB to iPhone/iPod adapters out there that will make it easy to connect it.
I would even pay $5-$10 for the app JUST to have that interface and I'm sure just about anyone else would too
Do you remember how they had you fix it? Im having same issue
      06-26-2012, 04:24 PM   #71
routenull0
routenull0
Drives: 2007 BMW 335i Sport
Any thoughts on putting together the steps post install for new users?
Something along the lines of "After a fresh install, the following things should checked and done within the Procede". Setting specific parameters in case it wasn't set at Vishnu prior to shipping? Double checking 6MT vs 6AT maps, proper max boost, boost gain etc
      06-27-2012, 01:02 AM   #72
tagon
yasmin3
tagon's Avatar
18
Drives: 2017 M3
^ +1
Current: 2017 M3 competition Pack.
Old:
2015 Audi S4
2011 335is
2009 Honda S2000
2008 328i
2007 Honda S2000
      06-27-2012, 06:03 AM   #73
messi
15
Drives: 2009 E92 335i MSport Coupe 6AT
would so love this as well.
      07-30-2012, 09:54 AM   #74
wat
wat's Avatar
Switzerland
Drives: 2015 M4
The meaning of flashing CEL would be nice too
Found this on another thread :
Procede Fault List
# of SES light flashes
1= Leanrun fault
2= Overboost fault
3= Wastegate overDC fault
4= Fuel pressure fault
5= Methanol Overflow/Leak
6= VIN mismatch
7= Map/Firmware incompatibility
2015 F82 M4 - Mineral Weiss / Black
2014 F10 528i - Jatoba / Black
      09-24-2012, 04:37 AM   #75
Ferruccio
Ferruccio's Avatar
40
Drives: 2010 335i
I have a simple question. I have been searching all over the site and cannot find the answer, even in the manual.
What is the user software? I know all about how to connect it to a computer, but nothing of the user software itself.
      01-17-2013, 10:50 PM   #76
YOU'VE JUST BEEN E90MTL
YOU'VE JUST BEEN E90MTL's Avatar
Drives: 2008 335i SPORT PACKAGE
Hi guys
I'm a newbie here... I just bought a 335i 2008 with the sport package, I'm looking to buy this Vishnu proceed rev3 for my car, do you guys know if it's VIN lock ?? and is all the parts are in the picture ??
thanks in advanced
      01-18-2013, 12:01 AM   #77
Laguna Seca Blue
Laguna Seca Blue's Avatar
261
Drives: N54 E92 | N55 F15 | N55 E70
Originally Posted by TeamRedlineMTL View Post
Hi guys
thanks in advanced
Depending on when the previous owner bought it, it may be Vin Locked. New units are not. Everything you need is in that picture, however a few of the pins look a little bent. Why not buy a new Rev2.5 for $500? Unless you're planning on maxing out your setup with a NLS, Two step, and running meth and a flex fuel sensor all at the same time, the Rev2.5 is functionally the same apart from the fact that you'll need to buy a good Serial to USB adaptor. Good luck!
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler
http://www.e90post.com/forums/showthread.php?t=782212
      01-18-2013, 10:10 PM   #78
the guys bought it last spring, I think he said to me in May, maybe this could help u
      01-19-2013, 02:23 AM   #79
Laguna Seca Blue
261
It's probably Vin Locked.
      04-27-2013, 08:10 AM   #80
tampaturbom3
11
Drives: 2013 BMW M6 Coupe
Uhg.. I've watched hours of video and read the manual over and over but still frustrated. At this point, it seems that pushing the DTC button twice while car is on but not running changes the MAPs.... and the Tach indicates which map. when you stop, does it ingage that map or do you have to do something more? also the SES light is blinking 5 times, pauses, then blinks it again and again. Does that go away once you start the car?
The cruise stalk goes to "Modes" and then "Commands" in each Mode. At least this is clear in the manual.
I wish the Maps part was clear. Also, can the MAP be changed on the fly or does the car need to be not running?
sorry for the noobie question but there seems to be a bit of info missing after install and prior to driving (ie: the maps)
Thank you,
      04-27-2013, 08:41 AM   #81
dbjb
I sweat pheromones
dbjb's Avatar
205
Drives: e92 335i, retired SLK55
Maps can be changed on the fly. If you're unsure which map you're in, press the CC stalk up once. The rpm gauge will indicate the current map.
      05-22-2013, 04:19 PM   #82
Allan335
Drives: BMW 335
Please help me out.
I have a rev3 with map 11-1 aggressive it said on the bag when I bought it. I must say that I am a little confused about what firmware I should use and which map?
My car has Bms intake filters and 5inch ETS intercooler.
I have noticed that the oil temp goes up so far that the car actually goes into limp mode 125 celsius. This is when i use map 1. If I drive it hard in valley mode (0) the oiltemp never reaches more the 115 celsius. Please help me out.
      05-23-2013, 08:41 AM   #83
tampaturbom3
11
I would recommend making a post in the regular section instead of the "sticky" section because most people won't see it here.
Unfortunately I'm new with the procede too, so I don't know the answer.
      05-23-2013, 11:41 AM   #84
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
The read me file shows you what u should be running.
In terms of maps/firmware.
Firmware is the devices software. This isn't changed often only during updates to maps.
(Maps)
Stage 0 is basically for stock.
Stage 1 93 octane DCI
Stage 2 93 octane, DCI, FMIC
Stage 3 FBO.
Methanol can be applied to any stage by changing the appropriate user adjustable fields.
Within each loaded stage there are 4 settings to change on the cruise control stalk.
Loading 1 is less aggressive
Loading 2 more aggressive
Loading 3 is basically a valley mode
Loading 4 is for methanol and only available once the perimeters have been changed
08' 335xi 6MT
Space Metallic Grey
Premium, Nav, Cold weather, Sport
Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts
      05-29-2013, 06:43 PM   #85
Allan335
Drives: BMW 335
Where do I get the newest maps and firmware?
Which ones are the newest?
      05-30-2013, 09:18 AM   #86
JETBLK335i
25
Drives: 2008 335i
Lambda / AFR reset on the command ctr. What do those mean in English? I tried searching but couldn't find details.
      05-30-2013, 11:43 AM   #87
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Go to proceed timings website. New maps are located under BMW>n54> downloads
08' 335xi 6MT
Space Metallic Grey
      05-30-2013, 11:43 AM   #88
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Lambada/afr is resetting the 02 values. Your lambada sensor is your 02 sensor.
08' 335xi 6MT
Space Metallic Grey
