BMW X5
      02-11-2024, 02:56 PM   #1
Titocosta
Titocosta's Avatar
Spain
Drives: BMW X5 LCI
Hello! This friday i got my new brand bmw x5! So happy but… i have a question:
Do you know if it’s possible watch how many horsepower are you using when you drive(live in Os7 my old BMW X3)
Thanks in advance
      02-14-2024, 08:21 AM   #2
bagd0003
bagd0003's Avatar
82
Drives: 2014 BMW i3, 2020 BMW X5
It's called Sports Display in the iDrive, will should you HP, torque, G-meter and some other metrics. Or you can keep pressing the BC button on the turn stalk until the HP and Torque meter shows up on the right side of the gauge cluster over the Tachometer.
      02-14-2024, 02:21 PM   #3
Titocosta
Titocosta's Avatar
Spain
Drives: BMW X5 LCI
Thank so much what i have a question!! this works on OS 8.5?? ( my x5 is LCI)
      02-14-2024, 03:29 PM   #4
JoeAyalaM
JoeAyalaM's Avatar
Mexico
174
Drives: 2024 BMWX5 M60i / Audi S6 V8TT
BC button?
      02-14-2024, 03:45 PM   #5
TurtleBoy
General
TurtleBoy's Avatar
13642
Drives: 2019 X5 40i,2021 M340i
Originally Posted by JoeAyalaM View Post
BC button?
Bottom button on the turn signal stalk.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
JoeAyalaM174.00
      02-14-2024, 04:24 PM   #6
lackland
21
Drives: BMW iX M60 2024
Also, look at setting the home screen to live vehicle instead of the map. (Home > use the controller or sweep with a finger to pull out the right side hidden menu > select live vehicle.) Then tap on the live vehicle to pull up the left side menu. Then set the display options to whatever displays the huge, bright red set of gauges. Lots of interesting choices are available but not prominently documented.
      02-15-2024, 08:42 AM   #7
Titocosta
Titocosta's Avatar
Spain
Drives: BMW X5 LCI
Thanks lackland! But… it’s working on OS 8.5? I can’t find the option that yo’re talking. Btw i agree that it’s really bad description of the options! 😔
      02-16-2024, 03:46 PM   #8
lackland
21
Hi Titocosta -
As far as I know it only works in Sport Mode. Does work in operating system 8.5.
So:
Select Sport Mode on the drive console...
Pull out the right hand menu on the screen and select Live Vehicle...
Tap or click the Live Vehicle display on the screen to pull up the left hand content menu...
Select adaptive content.
      02-16-2024, 03:49 PM   #9
Titocosta
Titocosta's Avatar
Spain
Drives: BMW X5 LCI
Wow lackland! Thanks so much for your time to show me how it works! Tomorrow i’ll do it🤗🤗🤗🤗🤗
      02-16-2024, 03:56 PM   #10
lackland
21
This adaptive content feature is badly documented but amazing in use.
I was equally surprised to discover that content settings for Live Vehicle depending on the mode could display an elaborate incline meter for off-roading.
One of the mysteries of the Live Vehicle display is why the initial display has to be tapped or clicked to bring up these options - and why the Options Button, per usual, doesn't.
      03-03-2024, 12:02 PM   #11
rohitkalra90
rohitkalra90's Avatar
Drives: BMW M440i Gran Coupe 2024
Cool, can you see the meters on the home screen in sports mode? Any pictures you’ve?
I see adaptative screen widget on left side vertical scrolling list as well. Can you these HP and Torque meters there as well?
Thanks
Originally Posted by lackland View Post
Hi Titocosta -
So:
      03-03-2024, 04:25 PM   #12
lackland
21
As far as I know...
The meters seem to only appear 1) in Sport Mode, when 2) the Home Screen option is set to Live Vehicle (we all think of the Map as the "Home" screen, but in fact that's only the shipping default screen since Home can be set to Navigation, Live Vehicle, or Music (or Media? whatever) by the menu on the right, and then 3) once in Live Vehicle, the image of the vehicle is clicked or tapped to 4) bring up the options on the left and the correct one selected.
Complicated!
I've never noticed an adaptive widget appearing for Sport Mode. Maybe I wasn't expecting to see it and didn't look. It isn't there in Hybrid mode.
If you experiment or somehow discover more clear documentation and find other choices or procedures, kindly post!
      03-03-2024, 04:55 PM   #13
rabbit1986
83
Drives: 2005 M3, 2016 D3 biturbo
What I find more annoying: why is there no option to see oil temp somewhere else then the “adaptive data” menu.
I mean that is such an important metric and it’s hidden deep inside idrive and only available in sport… ffs BMW
      03-04-2024, 02:46 PM   #14
lackland
21
Just a couple of days ago it occurred to me to see what would happen if I asked the Voice Assistant what my oil temperature was.
She told me!
I was worrying about oil temperature especially since nearly all my trips are local and so almost purely electric. Just how badly was I wearing the engine when suddenly flooring it? How long was condensed water and other vapors lingering in the old oil?
The power meter/tachometer/whatever when the car is shifted into Sport mode so the engine is explicitly started does show a limit on available power when the engine is cold out of the garage, and the limit takes a minute to climb to full power, but what happens in Hybrid mode?
As it turns out...even in Hybrid mode and no apparent engine use the oil temperature was almost immediately double the ambient temperature and after a few minutes was at 170F. Apparently the car does heat the oil one way or another so that suddenly bursting out of the pure electric range into ICE range doesn't blow the engine.
Still, yes, would like an oil temperate choice in the content settings for the driver's instrument screen. If only for fun.
xbimmers
