09-05-2011, 09:34 PM | #1 | |
51
Rep 1,792
1M 2000 kms/1200 Mile Service Oils
Hi guys,
This seems to be fairly common place here - the dealer completely stuffed up this service on mine. I actually flew to another state to pick up my car - do the break in and have it serviced, as I did not trust the one dealer in my state to do this and they messed up anyway. Wrong Gearbox oils & didn't even bother with the Diff Oil. They did get the Engine Oil correct though, to their credit. Pics, if anyone is interested; http://www.1addicts.com/forums/showthread.php?t=576032 I have searched and it there are plenty of threads about it but I think we need a final thread with consensus & perhaps a sticky on which oils are required. Correct Oils; Engine - 5W30 LL-04 (LL-01 for the US guys) Gearbox - MTF-LT-5 - 2L Bottle - BMW PN: 832 221 569 69 Barrel - BMW PN: 832 221 806 97 Diff - Castrol SAF-XJ + FM (SAE 75W140 GL5 BMW) - 1.2L Oil Filter - BMW PN: 114 275 663 27 Below are some alternatives; Quote:
09-06-2011, 02:20 AM | #2 |
51
Rep 1,792
No I will ask the Independent Service Center that works on my 993 to carry out the work. Just sourcing the oils at the moment - I live in a fairly rural part of Australia - pretty hard to come by a lot of things!
09-06-2011, 05:20 AM | #5 |
132
Rep 1,898
09-06-2011, 05:23 AM | #6 |
Rep 114
09-06-2011, 05:41 AM | #7 |
156
Rep 475
Drives: 1///M Coupe & ///M2 CS DKG
what do you think abaout the 10w60 Edge for ///M Engine?
I used it for my 335i it's better than the 0w30 Castrol ....
- Série 1 ///M BSM - |
09-06-2011, 07:35 AM | #8 |
262
Rep 5,018
Drives: VALNCYA
why wouldnt you let the dealer do this for free maintenance?
09-06-2011, 08:46 AM | #9 | |
51
Rep 1,792
I am most probably going to purchase a 20L drum of this directly from the distributor. EDIT: Dackel tells us that this is completely wrong! 5W30 is the way to go it seems! Last edited by alik01; 09-06-2011 at 09:06 AM.. Reason: Wrongness |
09-06-2011, 08:49 AM | #10 | |
51
Rep 1,792
The dealer up here is terrible and has been known to misplace cars! So I'm a little doubtful of their ability to do anything, let alone change the oil on my differential. |
09-06-2011, 08:58 AM | #11 | |
European Editor
10607
Rep 22,992
That is 100% the wrong oil (TWS) to use in a 1M!!!! The 1M uses the same oil that a 135i uses, namely BMW's full synthetic 5w30 LL1 oil. BMW NA has even put a decall under the hood stating the correct oil to use! Here is a picture of M3 Adjuster's decall. Dackel |
09-06-2011, 09:00 AM | #12 | |
European Editor
10607
Rep 22,992
YES, the above oil specs are correct! |
09-06-2011, 09:05 AM | #13 | |
European Editor
10607
Rep 22,992
This is one reason I buy the expensive German Castrol RS Edge 0w40 (LL-4) oil for my 135i. Dackel |
09-06-2011, 09:06 AM | #14 |
51
Rep 1,792
Thanks Dackel. Dodged a bullet there!
09-06-2011, 09:21 AM | #16 |
European Editor
10607
Rep 22,992
I even asked the guy at the Welt delivering M3_Adjuster's 1M. He said(the SA at the Welt) that the 1M only shares the rear end... so the diff fluid is the same. He said for the trans fluid... it doesn't need to be changed as per BMW NA... but IF it were driven in Germany... it would be better to change the trans fluid at the first service (1,200 miles). And the engine oil uses the same oil as say a 135i, the BMW LL-1 Castrol full sythentic oil.
09-06-2011, 06:17 PM | #18 |
581
Rep 1,170
Drives: M2 Competition, E30 M3 DTM
So it s better to use the castrol edge 0w40 LL04 in a 1M then the 5W30?
For track use the 0W40 wil be better i quess? |
09-06-2011, 06:22 PM | #19 | |
European Editor
10607
Rep 22,992
I would not get too caught up in the oil viscosities. Really, with any sythetic its a moot point - I think. Just make sure the oil is of the correct LL-1 rating for USA fuels. |
09-06-2011, 07:10 PM | #21 |
51
Rep 1,792
1. Also my car is exposed to very temperatures - 30C-40C.
