Ok stupid vibration question
03-14-2013, 07:59 AM | #1 |
Rep 19
Should i be able to feel the engine in the car and through the steering?
Its only a very slight vibration - feels like a normal engine rotating but i can feel it in the car when stationary and the when moving i can feel it through the steering (only very slight) Is it normal? if not (i.e should be sliky smooth) what do you recon it could be? like i say its not a massive vibration. Cheers Sam |
03-14-2013, 09:02 AM | #5 |
704
Rep 2,015
Drives: '05 M3 6MT
Any noises associated with the slight vibration?? As benzo mentions, could be a wheel bearing...which are usually diagnosed by a constant humming.
'05 BMW M3 6MT (Weekend car) Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link! |
03-14-2013, 10:15 AM | #7 |
Rep 19
To be honest it feels like i can feel the engine turning over BUT should i even be able to feel it...?
Its due an oil change in about 3500 miles would that make any difference? Last edited by samjfm; 03-14-2013 at 10:20 AM.. |
03-14-2013, 02:37 PM | #8 |
Rep 19
Would I be able to feel a rough auto transmission through the steering?
Reason I suggest this is because if when moving you put the box into N and rev the car you don't feel any change in the vibration. Put it back into drive and and accelerate you get a change in the.vibration ( still only small) My tyres are worn and the roads are rubbish around here so it could tyre balance or alignment I suppose. |
03-17-2013, 12:51 PM | #11 |
Rep 19
Had the alignment done and tyres replaced and it still feels the same,
I checked the front wheel bearings by hand and there was no play I could feel It has to be something in the steering surely?(if something is.actually even wrong) I wouldn't feel mounts would I? |
03-22-2013, 01:31 PM | #12 |
Rep 19
Some more info -
The vibration seems to be at its worst driving around 1300 1600rpm at about 40mph or if you accelerate If I take the car out of drive it goes away? Prop donut? Mounts? Or maybe the torque converter is on its way out? |
03-22-2013, 01:59 PM | #13 |
300
Rep 4,040
Drives: 130i coupé ;)
I have a VRRRR noise when slowing down and having the wheel turning. It happends on rare occasions
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
03-22-2013, 04:05 PM | #15 |
1254
Rep 4,088
What if you are in neutral and keep the motor revved up to the trouble RPM? Could help isolate the issue further if the vibration comes back (then it's more likely motor/mounts vs. driveline)
03-22-2013, 05:02 PM | #17 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
Hmm.. I know I have a vibration issue, but mine is with engine running, at stop light in D mode I feel vibrations in steering wheel at 700 rpms. Then turn off A/C button and its smooth as silk.
Dealership said there's an issue but they don't now what it is? My 2 cents |
03-23-2013, 07:55 AM | #21 |
49
Rep 347
03-23-2013, 08:10 AM | #22 |
General
17364
Rep 18,759
Could be two separate things.
The stationary vibration could be the AC compressor; my car has been doing this recently with about 120,000 on the compressor (I had to replace it at 85K miles). Not sure why it is doing this. The steering vibration could be as simple as a slightly bent rim, but my guess, depending on the mileage could be the hydraulic bushings in the front suspension Thrust Arms, which is a common problem, but comes more into play under light braking. A good fix for this is M3 Thrust Arms, which are about $50 more in parts cost than the stock non-M parts. |
