Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions G20 EU spec Welcome Light
      09-03-2023, 12:29 AM   #45
Calvindubois
Calvindubois's Avatar
42
Drives: 2023 BMW 330e LCI M - Sport
Talking Thank you
Looking forward to the discovery! I need this on my US 330e LCI
      09-04-2023, 11:54 AM   #46
the3mw
the3mw's Avatar
80
Drives: 330ix
I tested
I exactly copied and pasted staging 1 and staging2
to FLM2 left and right.
and now it is long ass welcome light that I would even forget it is still welcoming.
I do not understand why my welcome light is for about 40sec.
about at timestamp 0:24 it "does" the real welcome animation part(Left to Right) it supposed to do in the beginning.
and when i lock the doors, the animation is perfect.
I made compilation of all the presets that 2023 bmw 330ix has in cafd. hope it helps.. I still couldn't figure out which part to edit to make the outcome as what I want. But if we figure out the logic.. we can customize our headlight animation for sure..
it was pain in my ass to code every single items.. and test it out..
Appreciate 2
      09-29-2023, 01:18 AM   #47
Azni
Drives: F83 M4 Convertible
Subscribed
      10-04-2023, 09:22 AM   #48
BimmerCod
Drives: BMW X3 G01 M40i
There's no solution?
      11-17-2023, 10:00 PM   #49
alep85
179
Drives: 2011 335i, 2023 M340i xDrive
So far, no. MichaelNRW any luck with your research?
      11-21-2023, 12:26 PM   #50
RT1250Ryder
RT1250Ryder's Avatar
23
Drives: G20 LCI M340i
I'm subscribed to this thread as well. Really like the EU spec'ed welcome animation.
      11-21-2023, 04:36 PM   #51
the3mw
the3mw's Avatar
80
Drives: 330ix
Just watch the video up there and try it.
It works.
      11-21-2023, 05:05 PM   #52
alep85
179
It works.
People are looking specifically for the EU spec one (at least not without significant delay in start). While your research unearthed a lot of potentially interesting options, that is different than the original thread.
      11-21-2023, 05:12 PM   #53
the3mw
the3mw's Avatar
80
Drives: 330ix
I found out that’s just me. I don’t know why.
But for me if I don’t unlock from key fob,(opening by getting closer) it just works the same as eu without delay
You just gotta try it.
If you read the thread carefully, everyone has different outputs from the same coding.
Why don't you try it and share?
      11-22-2023, 02:22 AM   #54
MichaelNRW
B58 Power
MichaelNRW's Avatar
496
Drives: 05/2022 M340i xDrive Touring
Sorry, still had no time :-(
Currently the car is a garage queen.
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
      11-26-2023, 06:48 AM   #55
vet23
No_Country
Drives: G30 530D
I wonder if there's a solution for the g30
      12-31-2023, 09:44 AM   #56
Hyperion42
11
Drives: G21
Found myself some more free time to take another look at this, taking the BimmerUtility Staging1 preset values and your videos.
Starting with Wert_18, as it is dead simple. This one does not have any animations. Unlocking instantly turns on the low beams, and it switches them off after about 20 seconds.
Data looks like this:
Code:
Raw: 01 00 01 01 00
Section 01:
Definition 01: 0x01 0x00
Maybe this means "play animation 0x01 for 0x00 time units", or more plausible "fade to state 0x01 in 0x00 time units". There is not enough data in there to index any kind of light source.
Then, take a look at Wert_01. It is more complicated then Wert_18 for sure, but looks somewhat identical to Wert_18 in its effect. Unlocking instantly turns on the low beams, locking turns them off.
Code:
Raw: 01 00 01 02 0A 04 01 01 9B 00
Section 01:
Definition 01: 0x02 0x0A
Section 04: (Why 04? Where is 02 and 03?)
Definition 01: 0x9B 0x00
When applying the same reasoning as above, this means: "fade to state 0x02 in 0x0A time units". 0x0A is 10 decimal, and it definitely is not a 10 second animation. No animation is actually visible at all, either because 10 time units is too small (doubtful) or my interpretation of the data is wrong.
Moving on to Wert_3, where I actually started to count the frames. The video has 30 frames/second, thus 1 frame is about 33 ms.
Code:
40 frames / 1320 ms: No light visible
3 frames / 99 ms: animation to low DLR, inner tube only
3 frames / 99 ms: animation to full DLR or even lowbeam(?), all tubes
7 frames / 231 ms: animation to medium DLR, all tubes
170 frames / 5610 ms: stays the same
3 frames / 99 ms: animation to low DLR, all butes
1 frame / 33 ms: animation to medium DLR, all tubes
at least 80 frames, but cuts off: stays the same
This one also does not have any locking animation.
Taking a look at the data:
Code:
Raw: 01 00 0C 23 00 32 00 0A 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 05 00
Section 01:
Definition 01: 0x23 0x00
Definition 02: 0x32 0x00
Definition 03: 0x0A 0x64
Definition 04: 0x32 0x64
Definition 05: 0x32 0x64
Definition 06: 0x32 0x64
Definition 07: 0x32 0x64
Definition 08: 0x32 0x64
Definition 09: 0x32 0x64
Definition 10: 0x32 0x64
Definition 11: 0x32 0x64
Definition 12: 0x05 0x00
But I am stumped. I don't believe anymore that the animations are part of the Staging 1 data, but instead are an index and offset to where ever the animations are defined. Maybe not even in coding. I just can't make sense of the Staging 1 data right now.
If we say that for the first two definitions of section 1, we see 0x23 and 0x32 and use that as a time unit where no animation is visible, this would be 85 decimal time units. 1320 ms divided by 85 is about 16-ish, which is close to the magic number of 16.7ms meaning the animation would run with 60 fps. But, again, doubtful...
As a final one, Wert_02 has a very similar data to Wert_03 and looks kind of similar, but has more sections:
Code:
Raw: 01 00 0C 23 00 32 00 0A 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 32 64 05 00 02 00 04 01 05 2B 0A 2B 14 2B 1E 03 00 03 2B 14 2B 0A 2C 00
Section 01:
IDENTICAL TO Wert_03, see above
Section 02:
Definition 01: 0x01 0x05
Definition 02: 0x2B 0x0A
Definition 03: 0x2B 0x14
Definition 03: 0x2B 0x1E
Section 03:
Definition 01: 0x2B 0x14
Definition 03: 0x2C 0x00
Just in case anyone wants to frame count Wert_02...
the3mw79.50
      12-31-2023, 02:52 PM   #57
FRKNACKL
Drives: bmw 320i g20
Originally Posted by MichaelNRW View Post
Hi there,
as already discussed in other threads i had the opportunity to download the data of a G20 LCI EU spec.
I already had the data of a G80 and G82 EU spec and will share them aswell.
Some context for this.
BMW seems to made some difference between the EU and some US spec car regarding the Welcome Light or headlight animation when unlocking.
The G20 PreLCI can only control both DRLs as a pair while the G80 and G20 LCI can control them individually.
This was a side effect of developing the turn signal into the tubes of the headlight instead of having a separate turn signal above the tubes.
This side effect was used for the nice animation we know from the G20 LCI EU spec.
Now comes the good news, it´s not hard coded into the software!
You can code this with E-Sys.
I´m not sure about Bimmercode or other solutions, as you need to paste the data into the FLM2 ECUs.
1. G20 PreLCI EU spec - Welcome Light
View post on imgur.com
Code:
Staging1_Data
01, 00, 0F, 32, 00, 32, 00, 19, 00, 19, 00, 19, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 05, 32, 00, 32, 00, 19, 00, 0C, 14, 3C, 43, 03, 00, 03, 3C, 2B, 3B, 14, 0C, 00, 04, 00, 03, 32, 00, 0C, 14, 3C, 2E, 05, 00, 06, 32, 2E, 32, 2E, 32, 2E, 3C, 2B, 3B, 14, 0C, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
Staging2_Data
As you can see the animation is pretty boring and only needs a third of the first data field.
2. G20 LCI EU spec - Welcome Light
Code:
Staging1_Data
01, 00, 0F, 19, 00, 28, 00, 3C, 00, 3C, 00, 3C, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 0B, 5A, 00, 21, 1E, 05, 1E, 03, 64, 03, 1E, 0D, 1E, 03, 64, 03, 1E, 0A, 1E, 21, 64, 4B, 1E, 03, 00, 0B, 5A, 00, 21, 1E, 08, 1E, 03, 64, 03, 1E, 08, 1E, 03, 64, 03, 1E, 0D, 1E, 21, 64, 4B, 1E, 04, 00, 0B, 2D, 1E, 14, 1E, 08, 1E, 06, 1E, 09, 5F, 03, 62, 03, 64, 03, 62, 02, 60, 53, 00, 03, 00, 05, 00, 0A, 2D, 1E, 23, 1E, 06, 1E, 09, 5F, 03, 62, 03, 64, 03, 62, 02, 60, 4B, 00, 03, 00, 06, 00, 03, 41, 00, 32, 43, 80, 43, 07, 00, 03, 01, 43, 64, 43, 96, 00, 08, 00, 0B, 01, 00, 21, 1E, 05, 1E, 03, 64, 03, 1E, 0D, 1E, 03, 64, 03, 1E, 0A, 1E, 21, 64, 4B, 1E, 09, 00, 0B, 01, 00, 21, 1E, 08, 1E, 03, 64, 03, 1E, 08, 1E, 03, 64, 03, 1E, 0D, 1E, 21, 64, 4B, 1E, 0A, 00, 03, 01, 00, 32, 43, 80, 43, 0B, 00, 02, 01, 00, 05, 64, 0C, 00, 0B, 5A, 00, 21, 1E, 03, 1E, 03, 64, 03, 1E, 12, 1E, 03, 64, 03, 1E, 08, 1E, 21, 64, 4B, 1E, 0D, 00, 0A, 5A, 00, 21, 1E, 03, 64, 03, 1E, 17
Staging2_Data
1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 0E, 00, 0B, 01, 00, 21, 1E, 03, 1E, 03, 64, 03, 1E, 12, 1E, 03, 64, 03, 1E, 08, 1E, 21, 64, 4B, 1E, 0F, 00, 0A, 01, 00, 21, 1E, 03, 64, 03, 1E, 17, 1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
You can see that my PreLCI isn´t able to show the animation correctly, because the headlights weren´t made for this fast transition and they don´t share a common tact.
But this data should work for the G20 LCI US spec!
I would highly appreciate if someone could provide me the original G20 LCI US spec data.
3. G80 EU spec - Welcome Light
Code:
Staging1_Data
01, 00, 0F, 3C, 00, 3C, 00, 3C, 00, 3C, 00, 3C, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 15, 19, 00, 28, 00, 05, 00, 19, 0A, 05, 12, 05, 1C, 05, 2B, 05, 3A, 05, 4C, 05, 5B, 05, 64, 05, 64, 05, 59, 05, 4A, 05, 3F, 05, 3A, 05, 36, 05, 33, 05, 31, 04, 30, 04, 30, 03, 00, 15, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 19, 0A, 05, 17, 05, 2A, 05, 41, 05, 55, 05, 64, 05, 64, 05, 59, 05, 4A, 05, 3F, 05, 3A, 05, 36, 05, 33, 05, 31, 04, 30, 04, 30, 04, 00, 10, 19, 30, 32, 30, 0A, 37, 0A, 3C, 0A, 48, 08, 55, 08, 5E, 03, 63, 03, 64, 05, 64, 0A, 5F, 08, 4C, 08, 3A, 07, 28, 05, 19, 08, 00, 05, 00, 0E, 19, 30, 32, 30, 0A, 37, 0A, 3C, 0A, 48, 0A, 53, 05, 5E, 0A, 64, 0F, 62, 0A, 4B, 0A, 3A, 09, 26, 07, 14, 07, 00, 06, 00, 02, 96, 00, 55, 64, 07, 00, 08, 3C, 64, 3C, 64, 0A, 64, 2D, 63, 1C, 5A, 19, 4B, 23, 19, 05, 00, 08, 00, 13, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 05, 00, 19, 05, 05, 14, 05, 3A, 05, 55, 05, 64, 05, 64, 05, 5A, 05, 3C, 05, 1E, 05, 0F, 05, 05
Staging2_Data
05, 02, 05, 00, 09, 00, 13, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 05, 00, 19, 05, 05, 14, 05, 3A, 05, 55, 05, 64, 05, 64, 05, 5A, 05, 3C, 05, 1E, 05, 0F, 05, 05, 05, 02, 05, 00, 0A, 00, 10, 32, 00, 1E, 14, 0F, 28, 08, 3C, 09, 4D, 07, 5A, 03, 62, 03, 64, 05, 64, 08, 61, 05, 5A, 08, 4E, 07, 3B, 07, 27, 06, 14, 05, 00, 0B, 00, 0E, 32, 00, 1E, 14, 0F, 28, 08, 3C, 09, 4D, 07, 5A, 03, 62, 03, 64, 05, 64, 08, 64, 14, 50, 12, 28, 06, 14, 05, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
4. G82 EU spec - Welcome Light
Code:
Staging1_Data
Staging2_Data
The G80/G82 EU spec animation is identical and takes up almost the complete data fields.
This would be another option for the G20 LCI US spec drivers.
The next step would be an analyses of the data and how the animation is made.
Maybe we could write our own headlight animations?
kind regards
Michael
Hello. Is yellow drl a module or is it possible with coding?
      01-01-2024, 06:18 PM   #58
the3mw
the3mw's Avatar
80
Drives: 330ix
you have to swap out the board for the drl.
      02-07-2024, 08:26 PM   #59
polancd
Drives: 2024 BMW M340i
thanks for the info. I knew it had to be possible to recode the lights.
Appreciate 2
      03-04-2024, 09:33 PM   #60
alep85
179
Exclamation
Used the custom values in the Youtube video on my 2023 M340i xDrive and confirmed they work! No delays, it functions just like the3mw indicated and mimics the EU spec lights without any delay (although they still don't sweep left to right like the EU ones, it's more inside out).
Pasting below in case the video link ever breaks:
EU spec custom values:
Staging1_Data
Staging2_Data
Need to paste into both FLM modules using a tool like BimmerUtility.
      03-05-2024, 09:41 AM   #61
the3mw
the3mw's Avatar
80
Drives: 330ix
Used the custom values in the Youtube video on my 2023 M340i xDrive and confirmed they work! No delays, it functions just like the3mw indicated and exactly mimics the EU spec lights without any delay. Thanks for figuring it out!
Staging1_Data
Staging2_Data
It is all from MichaelNRW !
      03-05-2024, 09:50 AM   #62
alep85
179
Well cheers to you both for figuring this one out!
I have a friend with a G80 M3, curious if it works for all of their cars.....I'd assume the laser lights option would not work for this, right?
      03-05-2024, 11:09 AM   #63
Calvindubois
42
Has anyone managed to make it function correctly instead of both headlights mirroring each other? I want it like EU where it’ll swipe from one side to the other?
      03-05-2024, 03:48 PM   #64
alep85
179
Sadly, no. There some kind of time delay for the driver's side headlight, but not sure how it's coded to do that on EU-spec cars. MichaelNRW was researching, but no dice thus far.
      03-06-2024, 10:32 AM   #65
MichaelNRW
B58 Power
MichaelNRW's Avatar
496
We never found a way to make it sweep from left to right and back.
Maybe we need to have a look at other ECUs involved like the BDC?
Something has to give the tact so left starts before right.
Can someone with an US spec LCI send me a complete backup of all ncd´s?
I can try to compare them to the EU spec LCI.
Maybe there´s more than we currently see.
      03-06-2024, 11:06 AM   #66
Calvindubois
42
Here you go! https://www.dropbox.com/scl/fo/466v2...xeys0h6gv&dl=0
I doubt my matrix high beams function 100% like EU, I’ve done everything I can. They work great but don’t seem like a sharp cutoff. If want to take a peak at that too 🤭
g20
