BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions M550 Wheel Bearing,,,, lil help
      11-13-2023, 05:50 PM   #1
murmur
59
Drives: 2017 SO M3, 17 X5M, 18 M550
Looks like I will be replacing the front wheel bearing on my 2018 M550. I downloaded the instructions from ISTA but am having a bit difficulty understanding the Torque spec,, attaching the screen shot below,, not sure what the sequence is recommended,, tighten plus angle than untighten ?? any help would be appreciated..
      11-14-2023, 07:37 AM   #2
clegg
87
Drives: 335i E92, 435i F32,X5 F15
No expert here but, that appears a spec to reuse the T60 bolts. I use new bolts and torque to 140nm and then 90 degrees.
Whenever there is an angle spec, they are stretch bolts.
      11-15-2023, 09:09 PM   #3
admranger
Retired Curmudgeon
admranger's Avatar
2985
Drives: ‘19 X3M40i, ‘18 m550i
Torque to 140nm, unscrew just a little, no more than 45 degrees, tighten to 120nm, then tighten 90 degrees more.
BTW, how many miles on the car?
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      11-16-2023, 08:57 PM   #4
n-hampt4
17
Drives: 2017 540i
Initial torque is just to seat the bearing. Then release the fasteners. And then final torque which which will also stretch the fastener.
admranger2984.50
      11-21-2023, 11:42 AM   #5
JuniorTech
22
Drives: F30 340i Msport & G05 X5 40i
dont forget replace bolt ...
F30 : Bowers Wilkins, ID6 Touch, RSE
G05 : 5AU, 2VW, 2VH, 5DN, 6F1, 610, 7M9
5post
