10-27-2015, 11:19 AM | #23 | |
592
Rep 3,870
For those who choose to drill... Didnt you think BMW actually cover that area with a cowl in order to prevent water from going down where it can rust stuff below and damage electrical wiring? Good luck with your OCDs.
11-06-2015, 04:49 AM | #24 | ||
21
Rep 61
11-12-2015, 08:09 AM | #26 |
683
Rep 1,123
Look at the 2016...they have the holes from the factory
06-27-2018, 03:34 AM | #27 | |
22
Rep 44
On a right hand drive car the plugged holes in question will be open with wipers attached. Therefor there should not be any electrical components under that spot. This leaves the open question, Is there an official fix to the pooling water problem? If not I will drill some small holes, as I park on a slight incline which makes the pooling problem worse, I end up with muddy water marks in those spots. |
06-27-2018, 07:30 AM | #28 |
No 55mph
1622
Rep 8,476
Same on my 2015 435, noticed when it was 1st delivered
I'm not drilling any holes, you think BMW would have made (2) design cowls - (1) for LHD (1) for RHD that would not have the extra swimming pools present But that would mean xtra $$ and xtra inventory The Service Information Bulletin everyone talks about (SI B51 05 14) was NOT related to this issue - it was to fix a grommet that is located behind front PS wheel liner @ bottom of inner fender (E-box). This grommet is to drain water from above allowing it to go to ground. Apparently the grommet was designed with slit/flaps, it eventually gets plugged with crap & doesn't drain - hence routing the water into the cabin area. The fix is to totally remove the grommet
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-27-2018, 04:26 PM | #29 |
989
Rep 2,200
Our 2013 F30 is similar. Don't know if they added a drain hole on the LCI.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
07-02-2018, 04:13 AM | #30 |
118
Rep 303
My 2016 F32 has this issue as well. The first thing I do after I wash the car is pop the hood and just use a dry towel to absorb the water that pools in those areas. When I first noticed this way back when, I almost decided to drill holes to allow it to drain, but didn’t because I didn’t want to get water in an area that this cover was designed to protect. It’s just now become a step I do when washing the car.
