      08-29-2010, 01:08 AM   #23
blingers
blingers's Avatar
Australia
25
Drives: Pre-LCI 130i
finally got the sharkfin antenna painted and installed:
remove the plastic pins from the roof lining:
open the lining from the tailgate end and squeeze your hand in to loosen a nut under the antenna. for my car i had to squeeze a wrench in there to unbolt it(5 year old car). but other owners have unscrewed it with their fingers.
under the antenna base are 5 torx screws to unscrew to release the cap. It was recommend putting a metal contact to where the antenna stick attaches so i just used a keyring and slot it in contact and electrical tape to isolate from other electrics. I have no idea if that keyring will improve reception because my radio reception was already good without it.
screw the bolt back under the antenna and attach the sharkfin on top with double sided tape
      08-29-2010, 07:19 AM   #24
Discotheque
Discotheque's Avatar
Australia
Drives: Mazda 3 Neo
Very nice! Looks neat.
      08-29-2010, 09:03 AM   #25
blingers
blingers's Avatar
Australia
25
thanks disco. i had doubts on the look with the fin antenna but then i saw some prototype shots of the new F20 1er that has a sharkfin antenna.
an update on the led licence plate lights... last night i got the bulbout error on the obd for the license lights. both lights were out so i replaced them with the stock halogen bulbs... still NO light?!
so i spent an hour checking the fuses (didn't know what the license plate light symbol was in the legend!) but fuses were fine.
I then replugged the leds and one worked! the other light was dead so reinstalled the halogens and they worked as normal! no more obd error
I couldn't find an explanation for halogen lights not working the first time (fuses were OK) but one of the led lamps (the working one) was very hot to touch and smelt like melting plastic this warped the connector (right side):
so it could be heat-related? or a CANBUS safety system? still confused... i hope the car wiring wasn't damaged from this but things are good so far with the stock lights.
the ebay seller was really nice and gave me a full refund so I'll invest in the OEM LCI leds. I'll miss the brightness of the ebay ones but don't want to risk it with another set
      09-13-2010, 08:58 AM   #26
blingers
blingers's Avatar
Australia
25
ordered a new ignition lock from germany for 50 euros (compared to AUD245 at the local dealer) and installed it myself. took about 15minutes and that was my first time dismantling a beemer! the dealer wanted at least AUD160 to install but no surprise there...
the original lock
when ordering the part i noticed the lock changed part numbers two times so i ordered the newest one. the only difference i noticed was that in my original lock you can push the inside of the slot with your finger whereas you cannot with the new one. only when you insert the key it will push in.
bought a bmw jack kit and a pair of footwell lamps. lci led license lamps are on the way.
      09-13-2010, 11:36 AM   #27
Metralha
Metralha's Avatar
Drives: BMW 120d E81 - 2007/09
Nice work with the ignition lock...
also with the antenna.. i made the some but in my case i have removed the intire piece so my "shark" is totally empty inside...
after 3 years I'm facing now some captation problems in some areas and same FM stations...next mood will instal an internal antena in the front windshield and connect the wire direct in the radio. (disconnect the original)
cheers.
      09-14-2010, 08:16 AM   #28
blingers
blingers's Avatar
Australia
25
cheers.
thanks!
interesting that you removed the antenna. it didnt fit under your shark fin cover? there is another antenna in the rear window too but i guess thats not effective by itself. i have no problems with radio reception at the moment but i live close to the city. i'll have to drive into the country to test the antenna.
today i received the lci led license lamps:
installed them with no problems but a little disappointed with the colour... its not as white as the ebay ones.
      09-17-2010, 10:40 AM   #29
blingers
blingers's Avatar
Australia
25
hmm...
started retrofitting the footwell lamps following smithys diy. I need to find a suitable double leaf spring contact to fit in the footwell module. genuine bmw contacts only come in 25 pack for 11 euros. i just need one.
      10-02-2010, 03:32 AM   #30
blingers
blingers's Avatar
Australia
25
no progress made but took some photos and played with photoshop
      10-02-2010, 12:52 PM   #31
comar1979
130i Treiber
comar1979's Avatar
Germany
119
Drives: BMW 130i
Hey Mate,
--> Click!! --> i like it
Greetz
Marco
# BMW 130i /// + SPARCO Assetto Gara 8x18 bronze + KW + PP SteeringWheel II +PP Exhaust +PP Kidneys + PP AirFilter + PP Style Flaps + PP SS Kit + AC-Schnitzer Gear Knob + MorVision Diffusor + LCI Blacklines high + GroundZero-Audio #
      10-03-2010, 10:59 PM   #32
blingers
blingers's Avatar
Australia
25
haha thanks mate.
i'd like to add the performance stripes just to be different, but i got nothing to show for it especially under the hood.
next is high version lci taillights but not blackline... regretting it
      10-09-2010, 02:24 AM   #33
blingers
blingers's Avatar
Australia
25
finally finished the footwell light retrofit! no photos yet but its on stock halogens to match my stock interior light. i have a pair of white led bulbs but it might look weird.
      10-09-2010, 11:49 PM   #34
blingers
blingers's Avatar
Australia
25
      10-10-2010, 09:45 AM   #35
blingers
blingers's Avatar
Australia
25
added the "white" led t10s in the footwells
      10-17-2010, 03:26 AM   #36
blingers
blingers's Avatar
Australia
25
http://i54.tinypic.com/11wg03s.jpg
http://i54.tinypic.com/121wzvc.jpg
http://i55.tinypic.com/2w6s0a1.jpg
http://i55.tinypic.com/20i6hl.jpg
      10-23-2010, 07:57 AM   #37
lito_22
lito_22's Avatar
Spain
Drives: 220i F23
Nice change!!!
      10-25-2010, 06:38 AM   #38
blingers
blingers's Avatar
Australia
25
thanks lito!
No success with getting someone to recode the taillights yet.
next is changing the air filter. at the moment i just washed the grey cover in a bucket of water and the water turned black after that.
not much else to do to the car. maybe door light retrofit in the future.
      11-06-2010, 10:20 AM   #39
blingers
blingers's Avatar
Australia
25
im thinking of having a piano black interior by using gloss black vinyl from www.bmwshadowline.com but also a gloss black roof?!
here is a photoshop:
i wonder how scratch resistent is the gloss vinyl? and if i can get it that glossy. the more shine the better imo like a glass roof.
      11-07-2010, 12:05 AM   #40
Discotheque
Australia
Drives: Mazda 3 Neo
if you can by any chance match it with the tints then yeah it'd look sick! good luck with it!
btw thanks for the link for the air box!
http://forums.5series.net/topic/9695...iendds-aw-e87/ <-- looks good!
      11-07-2010, 01:34 AM   #41
blingers
blingers's Avatar
Australia
25
no worries
not sure if ill do it but these pics from bmwshadowline is what got my attention
      11-07-2010, 07:00 AM   #42
Discotheque
Australia
Drives: Mazda 3 Neo
Well they're stating that it's not going to ruin your paint so give it a go?
      11-08-2010, 05:12 PM   #43
lito_22
lito_22's Avatar
Spain
Drives: 220i F23
I prefer that you change front bumper to ///M before that vinyl on the roof!!!
      11-08-2010, 05:15 PM   #44
lito_22
lito_22's Avatar
Spain
Drives: 220i F23
Look this:
http://cgi.ebay.de/M-Technik-Stossta...item3f049fcb42
1addicts
