01-05-2019, 08:10 PM | #1 |
588
Rep 467
Changing wheel hub
So pulled a wheel off for the first time after getting installed by shop and I've got a stripped lug. How hard is this to change myself? Special tools? Other options? I don't want to just re tap.
01-05-2019, 08:27 PM | #2 |
360
Rep 500
If it's a front probably not bad. Remove all brake components. 4 bolts probably too swap the hub assembly. Reinstall brakes.
For the rear add axle nut removal and possibly one bolt from the suspension. May need a puller tool too in order to get the axle pushed out of the hub assembly. |
01-07-2019, 12:48 AM | #3 |
1973
Rep 2,711
Damn, sorry to hear this. You just got those wheels! Unfortunately, a lot of non-specialized tire shops freak out when they see a fast Euro car, and tend to over torque the lug bolts to hopefully minimize the risk of the wheel coming off the hub.
Hope the links below help, but you should really go after the tire shop for compensation. Front https://www.newtis.info/tisv2/a/en/f...kle/1VnXx2PqWu Rear https://www.newtis.info/tisv2/a/en/f...heel-bearings/ |
01-12-2019, 06:08 PM | #5 |
588
Rep 467
Not to difficult job at all. Can post up a DIY if anyone's interested.
Edit: see more here. https://f80.bimmerpost.com/forums/sh....php?t=1572940 Last edited by GuyLedouche; 01-12-2019 at 09:41 PM.. |
