How to adjust headlight angle?
01-31-2010, 10:40 PM | #221 |
What
141
Rep 9,325
i am also trying to find out how to adjust the headlight left and right
E92 328xi Space Gray
Aero Lip | M3 Side Skirts | CF Performance Spoiler | ACS Roof | Gloss Black Grilles | LUX H8 Angels | BMW Performance Exhaust My E92 Photos |
02-18-2010, 12:16 PM | #223 |
Rep 6
For the left / right adjustment, does anyone know whether to turn CCW or CW to move the beam 'out' and away from the vehicle?
03-13-2010, 10:29 AM | #225 |
Rep 27
06-14-2010, 02:22 AM | #227 |
14
Rep 1,044
so my passenger headlight is aimed like 2 ft higher than my driver when against the wall. I have an e92 and tried adjusting and nothing happend. turned like 1x, then 5x, then 10x in each direction with a screwdriver and it didnt seem to move the light. i also tried adjusting the driver light even tho it was already good and still nothing. do i need the special tool or i am doing it wrong?
07-03-2010, 11:56 PM | #228 | |
155
Rep 11,639
my lights are hitting lower than usual and read this and gave it a try.... i adjust it CCW and didnt do much....move me up like 1" and goes back down... the most it moves up is like 1"..doenst help or do much... |
07-14-2010, 03:43 PM | #229 |
dirigir é a minha paixão
Rep 153
Drives: e93 328c N52 3.0L cabriolet
bias compensation...
The screw that you are trying to adjust is for bias compensation only, i.e. its adjustable level is within a certain limit; the real leveling is done within the assembly unit of the Xenon lights. Do it after properly setting tire pressures, and fill you gas tanks full otherwise it won't be accurate. Mine doesn't got side to side adjustment for I got active headlight.
Sou fanático por conversíveis... |
09-23-2010, 12:40 PM | #231 |
11
Rep 181
Drives: 2000 Audi S4, 2008 E90 335i
Sorry to bring this up again. i lowered my car on coilovers and and the height with motors just wants to bring the beams down again. is there a way to manually set? height? and not left and right? or am i not understanding something?
19" LE 37-D2 Coilovers-E90 M3 body-JB3-DCI
09-23-2010, 01:30 PM | #232 |
Rep 153
Turn the adjusting (bias) screws the other way. Do it slowly with full tank of gas and properly inflated tires on a level surface. I know only how to make limited adjustments on those Xenon HID lights. May be someone else got better experience in making larger adjustment as after a body collision damages.
11-15-2010, 08:39 AM | #235 |
Rep 153
It is to my understanding this is applicable to all bmw's HID headlights with "lens pods". The adaptive feature affects horizontal axis not vertical alignment, so the adjustment procedure is same with the adaptive feature. The apparent "low" feeling you got for Xenon lighting is illusion, but if you really feel it is "low" adjust it with the bias screws aimed at a white wall in a dark area, with proper tire inflation & full gas tank. The left headlight (in LH vehicles) is typically lower than right headlight, you will see the "zee" jagged line on the wall. I don't know how to adjust the HID headlights after major body damage requiring larger vertical compensations, the bias screw is for limited vertical compensations.
12-08-2010, 05:16 PM | #236 |
64
Rep 781
just turn down mine a little, this is the spot for the xi i think, because i cannot find it using the pic EVO S4 provided, thanks for both all you guys.
02-13-2011, 08:16 PM | #237 |
Rep 97
What if it's empty where the screw is supposed to be? My drivers side is fine and has the screw but my passenger side is low but there is no screw where the screw is supposed to be? Is it possible to buy one to put back in or am I "screwed"?
02-14-2011, 09:34 AM | #238 | |
550
Rep 6,563
under construction! |
03-28-2011, 04:08 PM | #239 |
139
Rep 804
do i have ot use a "BMW Screwdriver" or will any philips that fits in work fine? JUst worried that i might break the threading in side or something.
03-28-2011, 08:11 PM | #240 |
47
Rep 1,160
A slotted head will work also
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
04-10-2011, 01:15 PM | #241 |
I used to be conceited, now I'm perfect.
570
Rep 1,826
Drives: 2018 M3 CS
I have tried everything to level my lights but with no luck. They do the "test" at startup but the passenger light always starts off and settles lower then the drivers side. Much lower. I've tried adjusting with the screws under the hood but that's as far as it will go. It will go a little lower but not higher. I don't know what to do anymore. Here's some pics of the left and right lights. You can clearly see the beam is way lower on the left. And the zoomed in photo shows the gap above the light. HELP!!!
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
04-19-2011, 12:04 AM | #242 |
Driver
38
Rep 372
Drives: E90 ///M3
Just got done with a test drive after adjusting my lights 2 full turns counterclockwise , Perfect .
