03-04-2011, 11:48 AM | #23 |
331
Rep 1,149
here you go. I bought a new drive and copied everything off of the old one on to this new one and its a bit faster but I don't think it's at the full potential yet that's why i want to reinstall OSX to see if my minds fucking with me or this is how it should be. But I could swear when I first got it, it was much quicker wiht less hard drive noise. Also this drive seems to be quiter.
I booted off of the old drive if that makes a difference here. Also this was at idle with just safari open. Code:
$ export PS1="$ " $ sar -g -p 2 10 13:15:01 pgout/s 13:15:01 pgin/s pflt/s vflt/s 13:15:03 pgout/s 13:15:03 0.0 13:15:03 pgin/s pflt/s vflt/s 13:15:03 0.5 0.5 66.5 13:15:05 pgout/s 13:15:05 0.0 13:15:05 pgin/s pflt/s vflt/s 13:15:05 0.0 0.0 5.0 13:15:07 pgout/s 13:15:07 0.0 13:15:07 pgin/s pflt/s vflt/s 13:15:07 0.0 0.0 29.0 13:15:09 pgout/s 13:15:09 0.0 13:15:09 pgin/s pflt/s vflt/s 13:15:09 0.0 0.0 13.0 13:15:11 pgout/s 13:15:11 0.0 13:15:11 pgin/s pflt/s vflt/s 13:15:11 0.0 0.5 88.0 13:15:13 pgout/s 13:15:13 0.0 13:15:13 pgin/s pflt/s vflt/s 13:15:13 0.0 0.0 45.5 13:15:15 pgout/s 13:15:15 0.0 13:15:15 pgin/s pflt/s vflt/s 13:15:15 0.0 0.0 12.5 13:15:17 pgout/s 13:15:17 0.0 13:15:17 pgin/s pflt/s vflt/s 13:15:17 0.0 0.0 1576.0 13:15:19 pgout/s 13:15:19 0.0 13:15:19 pgin/s pflt/s vflt/s 13:15:19 0.0 0.0 12.0 13:15:21 pgout/s 13:15:21 0.0 13:15:21 pgin/s pflt/s vflt/s 13:15:21 0.0 0.0 20.5 Average: pgout/s Average: 0.0 Average: pgin/s pflt/s vflt/s Average: 0.1 0.1 186.8 $ Code:
Mach Virtual Memory Statistics: (page size of 4096 bytes, cache hits 0%) free active spec inactive wire faults copy 0fill reactive pageins pageout 1108K 171378 144981 62700 84491 1512697 48870 932733 0 43311 0 1108K 171355 144981 62700 84491 1601 0 1585 0 0 0 1108K 171442 144981 62700 84235 1702 1 1685 0 0 0 1108K 171454 144981 62700 84235 1626 0 1614 0 0 0 1104K 174563 144977 62927 84688 6200 0 5614 0 3 0 1104K 174553 144977 62927 84688 1606 0 1582 0 0 0 1104K 174524 144977 62927 84688 1592 0 1581 0 0 0 1104K 174521 144977 62927 84688 1591 0 1580 0 0 0 1104K 174513 144977 62927 84688 1601 0 1582 0 0 0 1104K 174513 144977 62927 84688 1591 0 1580 0 0 0 1104K 174530 144977 62927 84688 1638 1 1621 0 0 0 1104K 174563 144977 62927 84688 1645 0 1632 0 0 0 1104K 174587 144977 62927 84688 1628 0 1616 0 0 0 1104K 174587 144977 62927 84688 1736 0 1705 0 0 0 1103K 175118 144977 62927 84728 3418 162 2265 0 0 0 1104K 175104 144977 62927 84728 1593 0 1582 0 0 0 1103K 175053 144977 62927 84728 1591 0 1580 0 0 0 1104K 175053 144977 62927 84472 1597 2 1583 0 0 0 1104K 175060 144977 62927 84472 1598 0 1587 0 0 0 1104K 175060 144977 62927 84472 1591 0 1580 0 0 0 1104K 175059 144977 62927 84472 1595 0 1583 0 0 0 |
03-04-2011, 12:31 PM | #24 |
you know he kills little girls like you
388
Rep 892
^The above looks fine. Were you experiencing the problem when you took this sample? If not, I'd suggest you try it when the problem occurs. If so, then it probably isn't a memory issue. Be aware that if it is a memory issue, the chances are it won't be so noticeable immediately following a reboot.
03-04-2011, 01:37 PM | #26 |
331
Rep 1,149
I did this while copying the other hard drive and opening simple apps like mail itunes etc to show you. and it was under a crazy load
Code:
$ export PS1="$ " $ sar -g -p 2 10 15:04:28 pgout/s 15:04:28 pgin/s pflt/s vflt/s 15:04:30 pgout/s 15:04:30 0.0 15:04:30 pgin/s pflt/s vflt/s 15:04:30 0.0 2.5 1033.0 15:04:32 pgout/s 15:04:32 0.0 15:04:32 pgin/s pflt/s vflt/s 15:04:32 0.0 1.5 1032.0 15:04:34 pgout/s 15:04:34 0.0 15:04:34 pgin/s pflt/s vflt/s 15:04:34 10.5 243.0 2198.5 15:04:36 pgout/s 15:04:36 0.0 15:04:36 pgin/s pflt/s vflt/s 15:04:36 185.5 272.0 1870.0 15:04:38 pgout/s 15:04:38 0.0 15:04:38 pgin/s pflt/s vflt/s 15:04:38 93.0 96.5 2413.5 15:04:40 pgout/s 15:04:40 0.0 15:04:40 pgin/s pflt/s vflt/s 15:04:40 89.5 250.5 3506.5 15:04:42 pgout/s 15:04:42 0.0 15:04:42 pgin/s pflt/s vflt/s 15:04:42 9.0 31.0 3546.0 15:04:44 pgout/s 15:04:44 0.0 15:04:44 pgin/s pflt/s vflt/s 15:04:44 14.0 34.0 1481.5 15:04:46 pgout/s 15:04:46 0.0 15:04:46 pgin/s pflt/s vflt/s 15:04:46 15.5 76.5 3712.0 15:04:48 pgout/s 15:04:48 0.0 15:04:48 pgin/s pflt/s vflt/s 15:04:48 101.5 104.5 3457.5 Average: pgout/s Average: 0.0 Average: pgin/s pflt/s vflt/s Average: 51.8 111.2 2425.1 $ vm_stat 2 Mach Virtual Memory Statistics: (page size of 4096 bytes, cache hits 0%) free active spec inactive wire faults copy 0fill reactive pageins pageout 1726 374501 1024K 79884 91757 4435729 64085 3019796 90 64485 223 1585 374769 1023K 79885 91632 2769 0 2713 0 1 0 2000 374400 1024K 79887 91649 1903 0 1835 0 1 0 2000 377528 1020K 79887 91620 5021 0 4971 0 0 1 1832 377674 1021K 79887 91603 1929 0 1782 0 0 0 2000 378717 1019K 79904 91526 3116 2 3014 0 0 0 2080 377926 1019K 79905 91355 2995 6 2880 0 1 0 1858 377414 1021K 79906 91338 1799 3 1753 0 3 0 1848 377483 1021K 79906 91348 2008 0 1956 0 0 5 2000 377108 1021K 79907 91453 2333 0 1956 0 1 0 1928 377863 1020K 79908 91498 3097 0 2612 0 0 0 2022 377007 1020K 79908 91702 2622 0 2262 0 0 0 2546 377937 1019K 79908 92005 4452 0 3664 0 0 0 1793 377501 1020K 80021 92215 4437 0 3678 0 4 0 2295 373960 1022K 79775 93268 3472 252 2470 0 0 0 1875 374859 1022K 79505 93632 3304 409 1959 0 265 0 1851 376309 1020K 79554 93783 4079 36 3590 0 154 0 2122 378001 1018K 79567 94092 5421 83 3181 0 1244 0 2014 379460 1016K 79639 94361 5464 164 3098 0 807 0 9530 384260 1003K 80233 94663 15669 89 14621 0 520 0 1942 384822 1010K 80286 94691 5708 2 5451 0 145 0 Mach Virtual Memory Statistics: (page size of 4096 bytes, cache hits 0%) free active spec inactive wire faults copy 0fill reactive pageins pageout 1655 384860 1010K 80293 94837 4519525 65131 3091228 90 67662 229 1727 384733 1009K 80296 94853 1768 0 1700 0 0 0 1833 384829 1009K 80304 94861 1875 0 1820 0 0 0 1925 388071 1006K 80308 94867 4991 0 4952 0 0 0 1842 388213 1006K 80320 94538 1954 0 1889 1 0 0 2079 388288 1006K 80339 94540 2295 0 2246 0 10 4 1833 388441 1006K 80373 94264 1910 0 1864 0 11 0 1833 388691 1005K 80401 94633 2167 0 2116 1 13 0 1626 388882 1006K 80422 94331 2031 0 1983 0 14 0 1677 388990 1006K 80440 93870 1891 0 1844 0 13 0 1668 389135 1006K 80457 93654 2616 169 2136 0 13 0 1823 389253 1006K 80479 93429 1899 0 1853 0 12 0 1937 389458 1007K 80498 93144 2023 0 1965 0 14 0 2079 389590 1006K 80298 93056 1830 0 1794 0 0 0 2000 389582 1007K 79832 92888 1666 0 1632 0 0 0 1829 389516 1007K 79833 92856 2161 0 2123 0 0 0 1663 389978 1007K 79872 92879 2708 6 2372 0 137 0 1767 395089 1001K 79988 93305 13222 41 7380 0 723 0 1798 395926 1000K 80060 93519 3784 725 2142 0 202 0 5701 396118 996230 80156 93591 8129 255 6710 0 88 0 2313 398259 997451 80262 93705 6175 36 4455 0 205 0 |
03-04-2011, 02:06 PM | #27 |
331
Rep 1,149
I benched both drives using a disk speed app
Old - 10.9 seconds New - 5.2 seconds Ok here is what I think is happening tell me if this makes sense. The old hard drive was on its way out which is why it slowed down the computer. It also corrupted some files maybe and those are being copied over to the new one. Also some of the permissions are messed up because after repairing them I check it and they're still there. This is why I want to reformat and do a clean install. But like an idiot i threw away the install CD |
03-04-2011, 10:25 PM | #30 |
14
Rep 158
$29 from Apple Store - says it is for upgrade only but I have done fresh installs with mine!
03-05-2011, 01:55 AM | #31 |
331
Rep 1,149
yup i bought it and installed it. My mac is good as new again. Off to installing programs
03-08-2011, 01:45 AM | #32 |
Networking Geek
24
Rep 334
Drives: 2014 Subaru STi 5dr
time machine is your friend
