ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-17-2024, 12:46 PM   #1
wigwig
wigwig's Avatar
Drives: 2003 BMW Z4 3.0i
Any headlights that work on the e85?
My passenger headlight is in pretty bad shape, the plastic is cracked all over and the other day the low beams just stopped working. I looked around online, and it seems like buying replacement oem headlights is quite expensive ($1500 for new ones and 800 for used), so I was wondering if any off other cars are the same or close enough that I could wire them up? I’m not great at DIY but I’m sure I could figure it out if there is a pair that would need wires changed up or something
      03-17-2024, 12:51 PM   #2
Our03z4
1692
Drives: 2008 BMW Z4 3.0si Coupe,
You can buy headlights from Amazon, $300 for a pair. Just be prepared to do wiring as they come wrong from the factory quite a bit of the time. Quality isn't great but they'll work on a budget. Other option is a junk yard or from eBay or such.
wigwig4.50
      03-17-2024, 01:26 PM   #3
07ImolaRot
07ImolaRot's Avatar
130
Drives: 07 Z4M, 05 M3, 13 M3
You can get the clear lenses on ebay or amazon and swap them over. You can also replace the projectors while youre at it.
2007 Imola Red Z4M
2005 Phoenix Yellow M3 6MT
2013 Interlagos Blue M3 6MT ZCP CF roof
      03-17-2024, 01:28 PM   #4
wigwig
wigwig's Avatar
It’s not the lenses that are the problem, the back part of the assembly is cracked so water can leak in, I took it apart earlier and I’m pretty sure that’s why it won’t fire up the lights
      03-17-2024, 01:37 PM   #5
07ImolaRot
07ImolaRot's Avatar
130
How did it crack like that? old age and heat or previous accident? Sounds like its not salvageable. Its better to get a used OEM one than these cheap aftermarket chinese ones that will have poor output and probably leak or fade in no time. A new one can be had for less than $1500 for sure but you're still paying just over a grand. Look on car-parts.com to see if there is one at a junkayrd close to you. Or have a junkayrd ship you one directly which should be cheaper than a used one on ebay as sellers price them higher to offset the insane ebay/paypal fees.
2007 Imola Red Z4M
      03-17-2024, 04:00 PM   #6
pungo
pungo's Avatar
880
Drives: Z4MC-X3-35i-525i, Corrado G60
Headlights from "other cars" will not fit the Z4, fact. Aftermarket headlights suck. Just bite the bullet and either fix the existing headlight or find a good used one. JB Weld is awesome to fix cracks in plastic.
wigwig4.50
      03-17-2024, 04:02 PM   #7
wigwig
wigwig's Avatar
I was afraid that would be the case, oh well. Looks like I get to do some DIY after all, thanks for the advice!
      03-17-2024, 05:30 PM   #8
Steeler
Steeler's Avatar
2429
Drives: Built not Bought 04 Z4 VF
The Z4 does not share its headlights with other platforms.
As others have said, its aftermarket or used OEM.
Reach out to danbmw1 he is a good source for used bits for Z4's
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
      03-17-2024, 08:22 PM   #9
CJW2OO4
CJW2OO4's Avatar
148
Drives: E86M,M2,F13 E86&E85M,E86,2E46
Wonder if 3D printing housings would be possible?
      03-17-2024, 08:30 PM   #10
wigwig
wigwig's Avatar
Hmm, that sounds like it could be fun, the xenon’s wouldn’t get too hot though would they? I don’t know much about how they work, but I’ve heard some people say they get pretty warm.
      03-17-2024, 09:02 PM   #11
cbpip
cbpip's Avatar
151
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Car-part.com is a national junk yard search data base,
Should have your light.
https://www.car-part.com/cgi-bin/search.cgi
zpost
