ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      02-05-2024, 07:07 PM   #1
SepangZ4MC
Drives: Z4M Coupe
Question Replacement key fob housing to freshen up worn key
Hello,
My current key works fine. It is just worn from use and age. Are there any replacement key fob housings/shells available that I can transplant the innards to without needing to buy a whole new key with the electronics and programming?
If there's no housing options, is it possible to upgrade the key to a newer style BMW key?
      02-07-2024, 06:08 AM   #2
Aloyouis2
Drives: E85 (not E86)
There are all kinds of covers for BMW keys on Amazon and Ebay. Maybe that solves this?
      02-08-2024, 02:08 PM   #3
SepangZ4MC
Drives: Z4M Coupe
No, the key's plastics look faded and the BMW logo is discolored. A cover won't fix anything. Seems like the only solution is to get a new key. I guess it's not terribly expensive ~$180. Cheaper than most new keys nowadays.
      02-08-2024, 02:41 PM   #4
2one3E90
2one3E90's Avatar
2422
Drives: Bmw 330i and Bmw 328i
2010 BMW 328i  [10.00]
2004 BMW Z4   [9.67]
2006 BMW 330i  [10.00]
Can you just recopy the metal part of your key or you need the electronics inside it also?
      02-08-2024, 04:41 PM   #5
SepangZ4MC
Drives: Z4M Coupe
Everything about the key is perfectly fine. The metal shaft and electronics are functional. I was hoping to just get a replacement plastic body and transfer things over if that's possible.
      02-08-2024, 05:27 PM   #6
Huz-Z
Huz-Z's Avatar
851
Drives: Z4 3.0si, 328 XDrive, X5 35i
You can get a new key from a bmw dealer but not cheap - $250 and maybe a programming charge too.
      02-08-2024, 05:58 PM   #7
pungo
pungo's Avatar
880
Drives: Z4MC-X3-35i-525i, Corrado G60
They sell plastic shells that clip over the existing key, though still use the existing buttons.
      02-08-2024, 07:12 PM   #8
SepangZ4MC
Drives: Z4M Coupe
Apparently, key shells do exist. Here's an amazon listing for one https://www.amazon.com/beler-Button-.../dp/B07FJ781BH but they are uncut. After some research, original key shells are glued shut and the key blade is molded into the shell so transferring the key blade will be pretty much impossible. What I find interesting is that the BMW emblem on the keys can be separately ordered and that tiny little piece is ~$10 (part number 66122155753).
      02-08-2024, 07:25 PM   #9
pungo
pungo's Avatar
880
I've cut them open to replace the battery so it's doable, but not trivial. With that said, I would not cut open a perfectly working key.
      03-06-2024, 12:23 AM   #10
JdixonC
Drives: 2007 BMW Z4 Coupe
Key fob
How did you replace the battery? Did you have to break the FOB at all to get inside?
      03-06-2024, 06:27 PM   #11
SepangZ4MC
Drives: Z4M Coupe
You have to cut it open
      03-09-2024, 10:34 AM   #12
Efthreeoh
17309
Drives: The E90 + Z4 Coupe & Z3 R'ster
OP, do you have a second key that is not used or worn? If you only have one key, then you should have a spare key regardless of the condition of your daily key. You need a working key to program any new keys you buy.
      03-09-2024, 03:26 PM   #13
SepangZ4MC
Drives: Z4M Coupe
That's good to know since I'll probably get a new key eventually. I do have a second key in slightly better condition. Both are working so not in a huge rush.
      03-10-2024, 04:19 AM   #14
pokeybritches
pokeybritches's Avatar
479
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Great timing. Addressing my worn key fobs is next on my project list. I recently replaced both of my 996tt key housings with refreshed designs, and I’d love to do the same with the Z4.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 996 Turbo
3002 tii2284.50
      03-14-2024, 08:08 PM   #15
SepangZ4MC
Drives: Z4M Coupe
I've looked and don't think there are many options for a new or redesigned housing that fit our keys. I'd be a customer if there are new compatible key designs out there.
      03-25-2024, 10:37 PM   #16
tortillalazaret
Drives: Chevrolet Silverado
A new key can be obtained from a BMW dealer, but it will not come cheap—about $250, plus possibly additional programming charges.
phrazle
      03-27-2024, 08:28 AM   #17
CJW2OO4
CJW2OO4's Avatar
148
Drives: E86M,M2,F13 E86&E85M,E86,2E46
I’d love to upgrade to the F Style Fob. Has anyone done this yet?
      03-27-2024, 10:40 AM   #18
pungo
pungo's Avatar
880
My buddy did a flip key for his E46, didn't ask much about the details becuase I didn't want to do it since it's a much chunkier key fob, but for me, besides the cool factor, it's a downgrade since I carry the key in my pocket therefore smaller is better.
I use the original BMW leather holders, which are comfortable in pocket and my keys still look nearly new.
Name:  BMW key holder.jpg
zpost
