Hiss from aftermarket audio upgrade?
03-12-2016, 03:48 PM | #1 |
Rep 9
I'm trying to upgrade the audio system in my E91 with the HiFi option. Got a harness for p&p connected to Alpine PDX-5 that was causing a very noticeable hiss from the tweeters. Those amps being fairly famous for the noise, I picked up a PDX-V9 recently and still have the same issue.
Amp is plugged in to the battery and grounded to the factory spot on the left rear wheel well. Hiss is there on each and every RCA connection (front/back + left/right) and minimum gain setting. Plugging in a ipod/phone to thet amp directly results in barely audible hiss at nominal gain. Any ideas what could be the culprit? Perhaps the head units output is just garbage? |
03-12-2016, 05:44 PM | #2 |
1923
Rep 13,131
You could try injecting another source into the amp
You could try injecting another source into the amp to see if the radio or idrive is the problem. You don't have the gain turned up to high do you?
If you are using the stock speakers which are 2 ohm you pretty much can't have any gain on the 2 ohm door speakers with an amplifier that feeds them aftermarket power. There was a run of radio's that had noise problems. Generally that would show up with the stock setup. |
03-12-2016, 06:10 PM | #4 | ||
Rep 9
I just installed the MB Quartz speakers, hiss is still present. Quote:
I believe so. I think it's quite a popular amp upgrade here. The first version had a bad run with some hissing by themselves, but the second gen should be all good according to google. |
03-12-2016, 07:29 PM | #6 |
Rep 9
Yes. No hiss whatsoever w/o RCA.
Doing a bit more googling suggest the issue might revolve around "balanced differential inputs" that the Alpine doesn't seem have. Would a LOC help? |
03-13-2016, 12:41 PM | #7 |
Rep 145
So it is the input signal. It could either be a bad head unit or that the PDX cannot accept a differential-balanced signal. The first thing to do is hook the hi-fi amp back up and see if the noise is still present. If it isn't, then your PDX is having trouble processing the signal.
A regular LOC will not help as they are designed to simply step-down voltage. They do not have the circuitry to process the signal. Rockford Fosgate did sell some line driver stuff (three-sixty?) that might work. Call them first to make sure it will do what you want it to do. I believe the hi-fi output from the head unit is 5 volts. |
03-13-2016, 02:13 PM | #8 |
Rep 9
I was thinking about getting the Audiocontrol Matrix Plus for the job if I can find it somewhere in the EU.
I checked the RF and the base unit has only 2 outputs, which might be a limiting factor at some point and the higher level ones add quite a bit of complexity and cost that I don't need at this point probably. |
03-13-2016, 02:35 PM | #10 |
Rep 9
I remember reading a post about BMW switching HU manufacturers (to Alpine?) in 2009 or so that resulted in quality issues, but mine is 2006 and I think made by Harman (old school Business Navigation with arrows) so thought I'm in the clear.
Might push me into looking for a CIC retrofit... |
03-13-2016, 03:14 PM | #11 | |
281
Rep 4,121
03-14-2016, 01:35 PM | #12 |
7
Rep 95
I've got the same amp (PDX V9) and have a hiss as well, my gains are set pretty low. When the volume is turned up there is some sort of ticking as well.
I had a JL 700/5 previously and had the same hiss as well. From my understanding I thought both of these amps accepted balanced differential inputs. |
