DIY - Euro Switch
07-25-2011, 06:38 PM | #70 |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
07-25-2011, 07:29 PM | #71 | |
///Multiple
2992
Rep 4,243
I ordered a 5-piece plastic trim removal set from Amazon. I'm a Prime member so two-day shipping was free. I started on the left side of the trim using the thinnest tool and worked the left side loose, then I inserted the tool between the trim and the dash and worked the right side loose. You don't want to pull the left side out too much or it will put pressure on the pins on the right side. Once both sides are pulled out a little you can insert the tool at the top and then just pull it straight out.
07-25-2011, 07:53 PM | #72 | |
14
Rep 170
07-20-2012, 04:49 PM | #73 |
Diesel Fitter
36
Rep 424
Drives: 335d m-sport LMB
anyone get a check-engine after installing this?
08-27-2012, 09:26 AM | #74 |
394
Rep 3,893
never. it shouldn't either. All the switch does is allow the blank button to become a press button. make sure you put the wires back right.
01-01-2013, 01:59 PM | #76 |
Rep 4
hi there i tried to follow this thread but i lost it i guess. i am german and have to move back to germany soon. its law to have a rear fog light in germany. can someone tell me the part number fo the switch who will fit my car? i have a 2008 e93 with hid and fog lights and rain sensor
thx |
01-01-2013, 04:56 PM | #77 |
15
Rep 157
Nice write up and pics. The US switch can be modified very easily to provide the same function for no cost, of course to switch will lack the proper symbology but that frees up your checking account for other mods.
01-01-2013, 05:00 PM | #78 |
170
Rep 1,843
[QUOTE=dermaiky;13236516]hi there i tried to follow this thread but i lost it i guess. i am german and have to move back to germany soon. its law to have a rear fog light in germany. can someone tell me the part number fo the switch who will fit my car? i have a 2008 e93 with hid and fog lights and rain sensor
thx[/QUOTE look it up on realoem.com - but when you input the specs of your car say ECE instead of USA. I got my switch from ECS tuning because they were the only source of the switch with the metal trim that I could find. (not sure if 2008 uses metal trim or black trim.) Works fine for me. Only weirdness is that apparently the rear fog can be turned on without the front fogs being on, which seems odd to me but it's not actually a problem... good luck! |
01-01-2013, 08:19 PM | #79 |
Rep 4
perfect found it!!
but another question... do u think this switch 61319169404 would work too? even it it says that i need this one 61316932796 ? who has a good deal for those? Last edited by dermaiky; 01-01-2013 at 10:03 PM.. |
02-19-2013, 09:38 AM | #80 | |
Rep 410
http://www.youtube.com/watch?v=WJfgikex5dc but removal of the trim makes things easier. I just installed the 61 31 9 169 404 switch and works perfectly. However, outside Europe, these switches are pretty expensive ~135 plus shipping.
Organized crime is alive and well: It's called auto insurance
02-15-2016, 12:50 PM | #81 |
Rep 13
confirmed 2012 335i convertible E93
Hello everyone,
Confirmed this works for free with NO additional parts or modification, using this guide http://www.m3post.com/forums/showthread.php?t=531296 I have a 2012 335i E93 convertible, and I cut the little plastic tabs off and the light works flawlessly. No need to buy the switch unless you want to. Don't even have to disconnect the battery, just pull, pull, cut, reassemble, viola'! Brand new rear fogs! |
03-10-2016, 08:57 PM | #82 |
494
Rep 1,416
I just did this tonight. So EASY! The E90 trims literally come off with your bare hands. Only used a flat head screw driver to start the prying before I realized the wood trim/vent comes off if you pull it and the lighting trim comes off by just lightly pulling on it.
I did NOT pay $150 for the switch ECS Tuning sells. Just scour eBay on the international search and you will find lots of these BMW Euro Spec switches for under $50. Only down side is shipping from Eastern Europe can take 2 weeks to a month to get stuff to the USA.
