08-25-2020, 07:08 PM | #67 | |
1166
Rep 2,180
I was expecting that this MEC-Analog would automatically show as the only inputs of the woofer channels outputs in the DSP Tool, not that you had to figure it out on your own. Those are the only channels in the RAM that have bass (~200Hz and below), other channels are high passed (~150Hz and above) -that is the reason that you were noticing a lack of bass. |
08-26-2020, 06:25 AM | #68 |
209
Rep 310
What should AUX L&R be? For what are these outputs ?
08-26-2020, 08:34 AM | #69 | |
209
Rep 310
Attaching a screenshot of input scheme from standard Limousine sound setup |
08-26-2020, 09:28 AM | #70 | |
1166
Rep 2,180
The 7BMW is set for the HiFi system of the F30 - the OEM HU outputs 4ch, low level full range signals. Those are the 4ch inputs of the 7BMW, so there is bass in all channels. The HiFi system in the G20 has an OEM HU that outputs its audio signals via Ethernet to a RAM module in the trunk. The RAM power the speakers via 7ch high level outputs -5ch are high passed (front, rear, center = mid and tweeters), 2ch are low passed (woofers = bass). No full range channels. The 7BMW or the 7DSP require full range signals as its inputs. As there are no full range signals in any of the channels of the RAM so that's where the MEC-Analog module add-on comes in -it adds two extra inputs to the 7BMW or 7DSP so a 6ch input configuration can be created. These 6ch inputs are required for the 7BMW/7DSP to internally create a full range signal from front/rear/woofer RAM signals - front + rear + woofer = full range. The MEC-Analog inputs are the woofer outputs of the RAM. I would suggest to use all inputs (F/R/Aux) as the sources of all outputs so a full range signal is available at all speaker outputs, you can go lower or higher in the frequency range than the non-full range OEM signal for better tuning. |
Calamari208.50 |
08-26-2020, 03:38 PM | #71 | |
Rep 15
Maybe still some tweaks and someone else to verify if the settings are right. |
08-26-2020, 05:10 PM | #72 | |
1166
Rep 2,180
Line Out inputs should be AUX (L/R), (trunk sub via RCA). |
08-27-2020, 03:20 AM | #73 |
Rep 15
08-27-2020, 06:48 AM | #74 | |
209
Rep 310
It's all clear now. The main difference between 7BMW and 7DSPw.MEC-Analog is the MEC-Analog that allows the amp to get full-range inputs. Encanto please correct me if I'm wrong, but this would lead me to conclusion that adding a MEC-Analog module to 7BMW amp, and using the PP-BMW-1.7RAM adapter can make the 7BMW amp work with G-series BMWs with RAM units. Am I right? Last edited by Calamari; 08-27-2020 at 06:56 AM.. |
08-27-2020, 11:30 AM | #75 | |
1166
Rep 2,180
Calamari208.50 |
08-27-2020, 06:04 PM | #77 | |
Rep 15
Calamari208.50 |
09-12-2020, 08:06 PM | #78 |
80
Rep 222
Hi all, I've done a quick write up on this amp with the Bavsound speaker setup.
https://g20.bimmerpost.com/forums/sh...3#post26676623 |
Calamari208.50 |
09-13-2020, 07:55 AM | #79 |
209
Rep 310
Thanks for the write-up AustraliaG20.
I ended up replacing OEM woofers, too. I couldn't resist :-). Now with the Focal iSub2 woofers, the low range is much tighter, more precise and the system is perfect for rock, jazz, reggae, and other types of music where bass guitar and kick bass drums run the show. Last edited by Calamari; 09-22-2020 at 05:06 AM.. |
01-30-2021, 07:24 PM | #80 |
14
Rep 74
I thought the HiFi didn't have tweeters in the rear doors (as Calamari said)? Also, what did you use for a remote-on lead? I didn't see a wire connected to it on the 7UP DSP photo in post #32 (there's a yellow "+12V" wire and a black "GND" wire but not a blue "REM" wire).
01-30-2021, 07:28 PM | #81 | |
14
Rep 74
01-31-2021, 11:40 AM | #82 |
1166
Rep 2,180
01-31-2021, 01:55 PM | #83 |
14
Rep 74
02-01-2021, 07:12 AM | #84 | |
209
Rep 310
03-20-2021, 03:57 PM | #85 |
15
Rep 6
I just installed the match-up 7 DSP amp with Ram in my BMW G20 and it's day and night with the HIFI system.
The OEM amplifier of Ram modul is clearly undersized for the original Hifi speakers. I am just starting the fine tuning with the equalizer. honestly the sound produced with the 10 OEM speakers drived by the match up 7 dsp is similar to the Burmaster that I had on my old mercedes W205. good upgrade. |
03-22-2021, 02:49 PM | #86 | |
539
Rep 853
Drives: 2020 BMW M340i xDrive
2015 Kia Optima SX Turbo -> 2017 Infiniti Q50 Red Sport AWD -> 2018 BMW 340i xDrive -> 2020 BMW M340i xDrive
Hey Google, play "Who Am I" by Beenie Man |
helmet91303.50 |
03-22-2021, 03:40 PM | #87 | |
235
Rep 424
04-02-2021, 09:46 AM | #88 |
Rep 16
(BIG TIME POST EDIT)
(EDIT) First things first: I found that the head unit CLIPS and introduces distortion with an SMD-1 by pulling out the bare wire on the center channel (unused) and putting the meter on it. Want a clean signal to start with? Turn the volume absolutely full and then back up 10 clicks on the volume dial. This is your clean signal MAXIMUM so NEVER go past that. Hey guys, does anyone have any clue if you can somehow code off the automatic bass reduction when the volume is increased? I have a 2020 X3 with the 676A RAM module and I've done the MATCH UP 7 DSP upgrade and added a PPI i650.1 sub amp for a small sealed 12". I upgraded all the speakers to the Bimmertech Alpha One series, including the 8" floor woofers. But after spending thousands of dollars I soon realized, I'm still throttled. You're stuck with the factory crossovers outside of the line out (external subwoofer) and deciding where you want the 8" mid subs to start. The 4 "full range" speakers are locked with no bass by the RAM unit and trying to get a smooth transition between the 8" mid woofer and the 4" speakers is tough. The problem is, the fucking volume increase and decrease CHANGE the EQ's in the RAM unit. You could have something sounding great, turn it up to 85% and it sounds like absolute shit. The uppermids get cranked and the low end is automatically throttled. I'm guessing this is to protect the tiny shitty speakers that come factory installed. I decided to EQ with the pink noise a bit louder to combat the dynamic EQ that gets triggered at higher volume. This is a compromise as at low level it may sound a little bassy but as you increase it starts sounding really good. The Bimmertech speakers. (HUGE EDIT HERE) - I was not impressed because I couldn't get an EQ that I was happy with. I just re-EQ'd the truck speaker by speaker but this time I measured 3 TIMES in a row for 20 seconds each time and set EQ after every time out. This finally put the EQ very close to my curve. I used a 150Hz high pass for the FL/FR/RL/RR with a 12db roll off and bypassed the upper frequencies. I set the SUBL and SUBR one at a time crossed over at 60Hz to 300Hz although I'm pretty sure they roll off at 250Hz regardless. I set my SUB (LINE OUT) to 25Hz to 60Hz. For the sub I'm using 24db roll off and the rest of the system is 18db roll off. I'm happy to say, the speakers are finally sounding good. There are huge dips in the 160Hz range that the EQing has applied so I'm guessing the factory has this frequency range pumped to try to make it sound like it's got low end in the 8" underseats. The mids are finally not killing me like my previous runs with the DSP. I think the problem is, you see these dramatic dips and want to manually tune the hell out of them but you have to resist. I can't explain now important this is. Yes, you will have to still do a little bit of adjusting but I find it's only at the bottom and top of the spectrum. Everything 8Khz and over needs to be tamed by 3-5db and the low end for my external sub needed a bit of a boost in the 32-40Hz range so you can feel it thump when it needs to. I would love to be able to 100% skip the RAM module but it looks like it's impossible. Also, adding AUX L and AUX R into the "full range" I/O does add the bass back into the little speakers but the internal fuckery you're causing by doing this is actually worse for the system once you start measuring. I'll post the build pictures for you guys so that you can fit all the amps in the side panel back there later on. Last edited by copene; 04-25-2021 at 03:30 PM.. |
