07-07-2014, 06:02 PM | #111 | |
18
Rep 82
07-08-2014, 10:02 AM | #112 |
European Editor
10589
Rep 22,992
F80 M3 / F82 M4 first service primer guide - what's required...
New M4/M3 first oil service... 1,200 miles or 2K kms...
Since a lot of you guys are starting to take delivery of your new M4/M3's... I thought I would put this PSA out for you. Basically the first service is just like on the old cars. The only thing that is new is that now BMW says you MUST replace the oil pan plug/screw and diff screw/plug with new ones! The crush o-ring is now built into the screw. F8x S55 engine... Oil filter: 11 42 7 566 327 Screw for engine oil pan/plug: 11 11 7 849 396 Screw for diff: 33 11 7 525 064 Oil engine quantity (6,5l) of 6.9 quarts. BMW LL4 engine oil: 83 21 0 398 504 (0w-40) or 83 21 0 398 507 (5w-30) Oil for diff/LSD (1l quantity): 83 22 9 405 462 (Castrol SAF-XJ ) API GL5, 75w140 NOTE: BMW says changing the transmission oil is not necessary. But if it were my car, and I was keeping the car for a long time - I know I would change it. Dackel original post... http://f80.bimmerpost.com/forums/sho....php?t=1007985
07-08-2014, 01:45 PM | #113 |
344
Rep 573
Will I have warranty problems if you do not adhere to the break in "rules"? Can BMW know if the car went 150mph or redlined while being broken in?
I'm doing an ED and going from Welt straight to the autobahn! |
07-29-2014, 02:16 PM | #114 |
www.facebook.com/weshowellcreative
59
Rep 623
Drives: 2015 AW M4 Coupe Project Car
I can't get mine to work reliably at all... the flag came on once (when my foot wasn't on the brake) I'm not so sure my car is working right.... Anyone having great luck getting the non-smoky burnout launch mode to work? Please share steps. turning off DSC completely and setting everything to aggressive / S3 and holding down the break and gas doesn't work for me. |
08-15-2014, 05:34 PM | #115 |
Rep 128
I'd like to see a poll of who followed Break in procedure and who doens't?
Seems like many ED people were hitting 150 MPH withing 20 miles of welt!! |
08-15-2014, 05:46 PM | #116 |
Rep 18
I'm wondering what constitutes "not following" break in procedure. If I redline it 5 times in the first 1200 miles I'm guessing no big deal...but how about 10 times ... or 20 times .... or 100 times. You get the point. Where is the line drawn? My dealer is insisting that they do a "preparation" drive before I take delivery, which I'm sure will cover the first 10 redlines (at least).
08-19-2014, 02:06 PM | #117 | |
Latvian Gangstah
84
Rep 570
Is it possible that dealer did not do the necessary software update at the service?
2009 E92 M3 Melbourne Red 6MT
[SOLD] 2015 YMB BMW M3 M-DCT [SOLD] 2010 Alpine White E90 M3 M-DCT [SOLD] 2002 TiAg E46 M3 manual |
08-19-2014, 02:28 PM | #118 | |
59
Rep 623
Hold down brake and push the gas as quickly as you can. Should work (I just wasn't stomping on the gas fast enough) Wes |
10-19-2015, 02:11 PM | #120 |
Rep 6
I am getting the car soon. I have been driving all my new cars very hard during the break in periods and replacing engine/transmission oil afterwards. None of them ever had engine or transmission issues in long term owning. Whereas, family member cars who have driven softly ended up with multiple engine/transmission issues.
Since this is an inline engine, I am not sure what to do, either do what I have been for past 15 years or follow the manufacture guidelines. The guidelines usually have always been to protect their end. They cannot recommend hard driving due laws and liability. First time BMW owner that I know. I have had an Audi and Mercedes. Audi driven hard as hell and no issues in the past 5 years. Mercedes driven softly and damn it has so many engine and transmission oil issues. |
03-25-2017, 06:39 PM | #124 | |
36
Rep 60
The SA guy put in 0w-30 (and not 0w-40 nor 5w-30). Also, the oil filter number that they used and put down on the print-out doesn't match what you show. Should I be concerned? Also, SA was completely lost when I asked him if screws for both oil pan and diff were changed. Mine's 2017 non ZCP M3. Any experience from you guys who recently got their 1200 mile service? I can take a picture of the service printout if that'll help. Thanks guys. Appreciate any info. S |
03-25-2017, 07:32 PM | #125 | |
European Editor
10589
Rep 22,992
Oil and filter numbers are probably a generic dealer made up part number and not BMW's actual part number. I would think your dealer used the correct oil and filter. You could always check those numbers on RealOEM.com though. Dack
03-25-2017, 07:46 PM | #126 | |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
Early M3/M4s up until late 2015 (I don't recall the exact month) had a titanium oil pan and used aluminum drain plugs that required an allen wrench and were not reusable. After this date BMW switched to a steel oil pan and uses the same standard hex steel drain plug used on many models and does not require replacement at every oil change. The part number on the oil filter box changed because it used to include a new aluminum drain plug. The oil filter in the box with a different part number is exactly the same but doesn't include the aluminum drain plug. So you don't have to worry about this. (Apparently Dackelone finished his post before I did...)
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
