10-07-2015, 03:50 AM | #1 |
235
Rep 982
Why 19" front wheels, but 20" rears?
Surprised that they are running a 20" rear and a 19" front wheel.
People are always talking about rolling radius on this forum? |
10-07-2015, 07:52 AM | #2 |
Moderator
7515
Rep 19,368
Rolling radius is determined by the wheel radius plus sidewall height. So, for the 20" wheel, you just use a tire with less sidewall than the 19" wheel so that it has roughly the same rolling radius front to back.
10-07-2015, 08:21 AM | #3 |
867
Rep 6,248
And Mercedes making the 19/20" split available via the C63S. Gotta keep up with the competition!
10-07-2015, 09:04 AM | #4 |
235
Rep 982
10-07-2015, 10:06 AM | #5 |
410
Rep 1,025
A lot of manufacturers do this. Corvettes have had 19 fronts and 20 rears since last generation. Several Ferrari models have it. The reason is that increasing the length of the contact patch helps with straight line performance, but the only way to do this without significantly increasing sidewall is to go to a larger wheel diameter.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black 2022 BMW X5M MBB/SO Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
10-07-2015, 10:07 AM | #6 |
410
Rep 1,025
See above.
10-07-2015, 11:34 AM | #7 |
Moderator
7515
Rep 19,368
No real change in contact patch length.
Standard M4 rolling diameter: F: 255/35 R19 = 26" R: 275/35 R19 = 26.6" M4 GTS rolling diameter: F: 265/35 R19 = 26.3" R: 285/30 R20 = 26.7" |
10-07-2015, 10:07 PM | #8 | |
410
Rep 1,025
I'd imagine that the larger wheel diameter itself changes the length of the contact patch by adjusting where the weight rests. For example, if you rest a wheel on the ground (standing up as it would be when mounted) and then draw a line around the area where its weight rests (essentially a rectangle), you can see how the contact patch of a larger diameter wheel would be different than that of a smaller diameter one.
10-08-2015, 07:10 AM | #9 | |
Moderator
7515
Rep 19,368
I'm not necessarily convinced its about contact patch length when overall tire diameter stays effectively the same. For example, they could have went with a taller tire on the rear as well but they chose not to. Whatever benefit the 20" wheel itself may have on the length of the contact patch, increasing the tire diameter would have even more so. Clearance issues start to come into play, sure, but some of that can be mitigated with changes in the suspension or perhaps the fender lining. It could be that the 20" wheel is there to decrease sidewall height which should reduce flex when cornering. If it helped shave even a second or two off of the Nurburgring time then that would be justified. As you note, they clearly targeted ring performance as part of their business case and marketing of the car. |
10-08-2015, 07:44 AM | #10 | |
867
Rep 6,248
10-12-2015, 07:19 AM | #12 | |
13523
Rep 8,165
991 GT3 RS also have different rim sizes (F20, R21). There have to be some benefits, but on the other hand less sidewall usually means less comfort, too.
10-13-2015, 10:35 AM | #13 |
1397
Rep 3,152
Then why do it? Doesn't it just add weight? The 20" wheel has to way more than a 19, right?
10-13-2015, 11:56 AM | #14 | |
Moderator
7515
Rep 19,368
I don't think it has been answered with certainty yet, but some speculation appears above.
10-22-2015, 10:15 PM | #15 |
2135
Rep 5,011
Sidewall definitely plays a part on the rear wheel specifically.
I do think that the GT3 RS shares its rear wheels and rear hubs with the 918, which is a good thing. |
10-23-2015, 12:19 PM | #16 |
103
Rep 443
Why? It just means that 918 is undertired (almost 400hp more than RS) - Dodge Viper has wider rear wheels/tires and so do many other cars... RS' performance comes from similar tire setup as 918- if it had the same wheels/tires as base GT3 it wouldn't be much faster than a GT3(certainly not 5 seconds quicker at the ring).
10-23-2015, 12:29 PM | #17 | |
General
21117
Rep 20,741
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
10-23-2015, 12:38 PM | #18 | |
2135
Rep 5,011
Porsche built the 918 from the ground up and I am sure (in their eyes) the width is perfect, which is why its a great rear setup for the RS. |
10-23-2015, 12:54 PM | #20 | |
103
Rep 443
12-17-2015, 09:36 AM | #22 |
Kaskasero
55
Rep 345
I really can't see a reason that there is a 20 on the rear. Can't be for caliper clearance. Rake?
Rides:
BSM E53 X5 3.0i | Mods: 4.8is Style 168 wheels 1996 MB C280 Sport 2001 E39 M5 |
