ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      10-07-2015, 03:50 AM   #1
stranger
235
Drives: BMW M3
Post Why 19" front wheels, but 20" rears?
Surprised that they are running a 20" rear and a 19" front wheel.
People are always talking about rolling radius on this forum?
      10-07-2015, 07:52 AM   #2
mkoesel
Moderator
7515
Drives: No BMW for now
Rolling radius is determined by the wheel radius plus sidewall height. So, for the 20" wheel, you just use a tire with less sidewall than the 19" wheel so that it has roughly the same rolling radius front to back.
      10-07-2015, 08:21 AM   #3
SamS
867
Drives: Tesla M3 Perf + '18 X3 M40i
And Mercedes making the 19/20" split available via the C63S. Gotta keep up with the competition!
      10-07-2015, 09:04 AM   #4
stranger
235
Drives: BMW M3
does this give any performance benefit as I havent seen anyone else go with this stance on aftermarket wheels?
      10-07-2015, 10:06 AM   #5
TahoeM3
410
Drives: F-type R, GTR, X5 50i
A lot of manufacturers do this. Corvettes have had 19 fronts and 20 rears since last generation. Several Ferrari models have it. The reason is that increasing the length of the contact patch helps with straight line performance, but the only way to do this without significantly increasing sidewall is to go to a larger wheel diameter.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black
2022 BMW X5M MBB/SO
Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,...
      10-07-2015, 10:07 AM   #6
TahoeM3
410
See above.
2022 BMW X5M MBB/SO
      10-07-2015, 11:34 AM   #7
mkoesel
Moderator
7515
No real change in contact patch length.
Standard M4 rolling diameter:
F: 255/35 R19 = 26"
R: 275/35 R19 = 26.6"
M4 GTS rolling diameter:
F: 265/35 R19 = 26.3"
R: 285/30 R20 = 26.7"
      10-07-2015, 10:07 PM   #8
TahoeM3
410
F: 255/35 R19 = 26"
It's a complex issue with many variables, and I don't claim to have all the answers. But many manufacturers are doing it, and BMW clearly had good results if they stuck with it. I'm guessing it is a factor in the vastly improved 'Ring time.
I'd imagine that the larger wheel diameter itself changes the length of the contact patch by adjusting where the weight rests. For example, if you rest a wheel on the ground (standing up as it would be when mounted) and then draw a line around the area where its weight rests (essentially a rectangle), you can see how the contact patch of a larger diameter wheel would be different than that of a smaller diameter one.
2022 BMW X5M MBB/SO
      10-08-2015, 07:10 AM   #9
mkoesel
Moderator
7515
No doubt. There is certainly some benefit to a larger wheel or BMW and others would not go that route.
I'm not necessarily convinced its about contact patch length when overall tire diameter stays effectively the same. For example, they could have went with a taller tire on the rear as well but they chose not to. Whatever benefit the 20" wheel itself may have on the length of the contact patch, increasing the tire diameter would have even more so. Clearance issues start to come into play, sure, but some of that can be mitigated with changes in the suspension or perhaps the fender lining.
It could be that the 20" wheel is there to decrease sidewall height which should reduce flex when cornering. If it helped shave even a second or two off of the Nurburgring time then that would be justified. As you note, they clearly targeted ring performance as part of their business case and marketing of the car.
      10-08-2015, 07:44 AM   #10
SamS
867
^^ This is my guess.
      10-10-2015, 06:27 AM   #11
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
Just curious, is this the first/only BMW sold with mixed diameter wheels front (19in) and rear (20in) from factory?
      10-12-2015, 07:19 AM   #12
swagon
swagon's Avatar
13523
Drives: F80 6MT
I think it is.
991 GT3 RS also have different rim sizes (F20, R21). There have to be some benefits, but on the other hand less sidewall usually means less comfort, too.
      10-13-2015, 10:35 AM   #13
nbennettksu
1397
Drives: DV F80
F: 255/35 R19 = 26"
Then why do it? Doesn't it just add weight? The 20" wheel has to way more than a 19, right?
Originally Posted by JBasham View Post
Caddy ATS . . . finally, a decent rental car option.
Originally Posted by kchu221 View Post
the wheels make me mad...
Originally Posted by mhabs View Post
It's one thing for some buffoon to put an M badge on something that doesn't deserve it...it's another for a multi-billion dollar corporation to do the exact same thing and keep a straight face.
      10-13-2015, 11:56 AM   #14
mkoesel
Moderator
7515
Originally Posted by nbennettksu View Post
Then why do it?
I don't think it has been answered with certainty yet, but some speculation appears above.
Doesn't it just add weight? The 20" wheel has to weigh more than a 19, right?
The wheel weighs more, but the tire weighs less. I would guess that the 20" combination is slightly heavier than an equivalent width 19" combination, but not by much. Not necessarily confident in that guess though.
      10-22-2015, 10:15 PM   #15
Sean@PSI
Sean@PSI's Avatar
2135
Drives: 2021 IOMG M3 Sedan
Sidewall definitely plays a part on the rear wheel specifically.
I do think that the GT3 RS shares its rear wheels and rear hubs with the 918, which is a good thing.
      10-23-2015, 12:19 PM   #16
dgp
103
Drives: Bicycle...
Why? It just means that 918 is undertired (almost 400hp more than RS) - Dodge Viper has wider rear wheels/tires and so do many other cars... RS' performance comes from similar tire setup as 918- if it had the same wheels/tires as base GT3 it wouldn't be much faster than a GT3(certainly not 5 seconds quicker at the ring).
      10-23-2015, 12:29 PM   #17
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Not really. The electric drive on the 918 is split between the front and rear axles with 129hp and 156hp respectively. Further, the peak power of the electric motor is not necessarily at the exact same RPM as the 608hp from the combustion engine, so the two power number cannot really be added. But even if we do, the 918 has at most 264hp more than the RS at the rear wheels, not 400 .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      10-23-2015, 12:38 PM   #18
Sean@PSI
Sean@PSI's Avatar
2135
Undertired? - More power doesn't necessarily mean a need for wider tires.
Porsche built the 918 from the ground up and I am sure (in their eyes) the width is perfect, which is why its a great rear setup for the RS.
      10-23-2015, 12:49 PM   #19
dgp
103
Drives: Bicycle...
It sure helps
      10-23-2015, 12:54 PM   #20
dgp
103
Drives: Bicycle...
What I meant to say was torque- 338ft lbs peak for RS and over 900 ft lbs for 918 through the same tires. Which one is undertired?
      12-14-2015, 07:03 PM   #21
///Mpossible
125
Drives: BMW
It seems to be the new trend to have bigger diameter wheels at the rear, the C63 coupe also has 19s/20s combo!
      12-17-2015, 09:36 AM   #22
Savory
Kaskasero
Savory's Avatar
55
Drives: You Insane
I really can't see a reason that there is a 20 on the rear. Can't be for caliper clearance. Rake?
Rides:
BSM E53 X5 3.0i | Mods: 4.8is Style 168 wheels
1996 MB C280 Sport
2001 E39 M5
f80post
