10-26-2018, 10:23 AM | #45 | |
23
Rep 51
I don't want to do plates on my DD, I already have them on my track prep'd m3 and the NVH would drive me up the wall. |
10-26-2018, 10:50 AM | #46 | ||
518
Rep 891
I definitely wouldn't want them on mine either. Having ridden in cars with them before I knew they were not for me.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
Polo088161614.50 |
10-30-2018, 08:28 PM | #47 | |
391
Rep 449
If anyone wants the control arms, I haven't sold them yet. They only have about a quarter mile of driving on them lol. Not that it was challenged, but before I did it I talked to Turner and also FCP euro and neither thought there would be any problem with the xdrive, but I hope my little mishap saves others from having the same issue. For those who have done it on RWD, I've heard great things! Bryan |
BMW DIY Guy3088.50 Polo088161614.50 |
10-30-2018, 08:30 PM | #48 | ||
391
Rep 449
BMW DIY Guy3088.50 |
10-31-2018, 12:22 AM | #49 | ||
3089
Rep 3,033
Drives: 2019 M2 Competition
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
10-31-2018, 03:35 AM | #50 | |
72
Rep 192
If so shoot me a PM with pricing please, I'm interested in acquiring a pair of these. |
10-31-2018, 12:03 PM | #51 |
147
Rep 368
I just did this bc I needed new control arms but I wouldn't have otherwise. My car with 19X8 front wheels + 10mm spacers + Dinan Springs now rubs during hard cornering.
2016 340i XDrive: Bootmod3. And stuff.
10-31-2018, 08:51 PM | #52 |
Cheapskate
4455
Rep 4,995
so just to confirm, there's no way to fix the increased caster and get the wheels back center?
10-31-2018, 09:29 PM | #53 |
2467
Rep 5,457
Drives: F30
Other than the actual LCA's -
Are there are any other required or recommended parts or hardware that should be installed when fitting to an F30 ? Can someone confirm R and L part numbers? |
11-04-2018, 09:49 PM | #54 | |
650
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
-use spacers -press a F30 bush into the F80 control arm -wait for the control arm kit super pro is going to release early 2019 that is supposed to be plug and play. |
11-04-2018, 09:59 PM | #55 | ||
3089
Rep 3,033
11-05-2018, 01:59 AM | #56 |
650
Rep 2,601
11-06-2018, 12:00 PM | #57 | |
98
Rep 227
Drives: 2000 BMW E39 M5
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
11-06-2018, 07:07 PM | #58 | |
650
Rep 2,601
Not sure about x drive as we don't get them in Australia. |
06-09-2019, 08:29 PM | #59 |
403
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
F80 M3 Lower Control Arm Kits
There are several kits for this mod. Need a shop with an alignment rack.
<<<NOT COMPATIBLE WITH XDRIVE>>> FCP Euro has all the P/Ns and hardware https://www.fcpeuro.com/products/bmw...QaAuHQEALw_wcB ECS Tuning: 2 LCA + Headlight Level Bracket https://www.ecstuning.com/b-genuine-...31122284529kt/ ECS Tuning: TRW Full Kit https://www.ecstuning.com/b-trw-part...7142283867ekt/ ECS Tuning: BMW OEM Full Kit https://www.ecstuning.com/b-genuine-...7142283867gkt/ GetBMWParts probably has the best prices Cheers |
sspade2467.00 BMW DIY Guy3088.50 |
06-09-2019, 08:39 PM | #60 | |
1615
Rep 3,953
We did this and were within 0 degrees and 4 minutes off from the factory spec. It allowed us to drive 30 minutes to the alignment shot. |
06-10-2019, 09:20 AM | #61 |
3089
Rep 3,033
Absolutely NOT compatible with Xdrive, and seen what happens when you try.. its bad.
06-10-2019, 11:40 AM | #62 | |
3089
Rep 3,033
Thanks man.. fantastic references for sure. I am still trying to figure out if this is worth doing, granted the prices are pretty reasonable all things considered and also watched the DIYs on how to do it. My only concern would be reinstalling properly to then get it to an alignment shop to finish the work. *ponder* Maybe adding this to my bucket list of To Dos. Side note, using the parts list it looks like $408 from GetBMWParts
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread Last edited by BMW DIY Guy; 06-10-2019 at 11:49 AM.. |
06-21-2019, 08:57 PM | #64 |
67
Rep 210
Having just switched back to anF30 after several years in other car makes, I was really excited to learn about this alternative to camber plates. So I jumped in (apparently too quickly) and got a “kit” from a highly reputable vendor that sells both the F80 LCAs and tension struts as a plug and play for the F30. Well, the installer and I just learned tonight the F80 tension struts definitely don’t fit the F30. I wish I read this post earlier, notwithstanding the vendors assurances to me everything fits. Does anyone know where I can get spacers that will allow the tension struts to fit? I also saw some reference to trying to to push the larger F30 bushing into the tension strut of the F80. Based on bushing housing for the F80 v. F30, I don’t see how this would work right. Has anyone successfully done this?
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 |
06-24-2019, 05:09 AM | #65 | |
1615
Rep 3,953
https://f30.bimmerpost.com/forums/sh...1090804&page=7 I used the spacers linked by MacklinUSOB . |
06-25-2019, 08:27 PM | #66 |
67
Rep 210
Thanks!
