Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Bavarian Tech Code List
      01-14-2011, 12:37 AM   #23
Rayitoveloz
Puerto Rico
Drives: 335I M-Sport 08'
Code 2FC7 ?????
Anyone Know this code 2FC7 and the carr still in Transport Mode and this code no delete
Heeelppppp?????
      01-25-2011, 09:38 PM   #24
D.B.S
D.B.S's Avatar
No_Country
30
Drives: '11 X5 35i / '13 S5
Got a few codes I need resolution on:
2C90 (11408)
2774 (10100) This is a Tuner Code: "air mass too high in relation to model" So N55 owners keep a watchful eye for this one
2778 (10104)
277A (10106)
2BEF (11247)
Any ideas on what these are? (besides the one that I recently found out about)
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi)
2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune
      01-29-2011, 05:35 PM   #25
BlkNWhite
Drives: 2007 bmw e90
Originally Posted by Mr. 5 View Post
BT Code List.
If you have any more then please contact me and I will add it to the spread sheet.
Make sure you SAVE this to your hard drive first and then rename the extension from .txt to .xls.
I repeat...change the extension to .xls so you will be able to see the spread sheet that is meant to be viewed.
I have sorted everything by the code but the good thing about this spread sheet is that you can sort or filter everything by the way you want.
Again, if you have any more codes then PM me and I will add them.
.....i began to get frustated that it wasnt opening up a spread sheet till i reread what u wrote and specifically said ...RENAME FILE ..lol thanks
      03-23-2011, 10:04 PM   #26
JETBLK335i
25
Drives: 2008 335i
code error
Originally Posted by Kelvin1000 View Post
I got code 2F80 a couple of times... any idea what it means?
i know this is motor shutoff time, but is this related to HPFP? i am bone stock, but did a little coding to remove front parking signals when i turn on the lights, keyfob. E90 2008 sedan.
i cannot see the spreadsheet.
please help. thanks.
      04-27-2011, 09:18 PM   #27
7VR46
7VR46's Avatar
Drives: E92
I got this code, anybody know what this is. What is a Diagnosis module tank.
2A17 DMTL diagnosis module tank leakage, system failure
      09-06-2011, 09:11 PM   #28
Frosty
Frosty's Avatar
780
Drives: M240i - 2021 - 6MT -
I just threw these ...
2F67:
2F67 Clutch switch, signal
Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption
A10A: EWS4 timing challenge/response error Error will not cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold
A468: No LVDS signal Error will not cause a warning light Error is not currently present Test conditions have been completed
A379: Error in Bluetooth-Interface (Error_BT_INTERFACE) Error will not cause a warning light Error is not currently present Test conditions have been completed *
D68E: Although a shutdown command was send, the light doesn't shut off (Error_Light_Not_Off) Error will not cause a warning light Error is not currently present Test conditions have been completed *
D691: Too long or/and too many unlocks (Error_Unlock_Long) Error will not cause a warning light Error is not currently present Test conditions have been completed
A0B1: SG input P N Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017)
335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016)
Prelude (5MT) (1995)
      11-29-2011, 06:14 PM   #29
JDrillingJ
Drives: 2008 335i
Anyone have any experience or knowledge with the code 29D3?
On another code note, what in the world would cause codes 2AAD (fuel pump emergency off) and 29F3 (fuel pressure sensor) to be thrown? Tuning issue? Anything to worry about? On this same note, last time in the dealer they did replace my HPFP and a couple of injectors......could it be related to this?
Thanks in advance fellas.
2008 BMW 335i Coupe - 6AT w/ Paddles - Black on Black - Dark Burl Walnut - 19"s - Aero -ColdWeather - Premium - Sport - Navigation - iPod - JB4 - BMS DCI - Michelin PSS - Dual Exhaust Mod
      01-04-2012, 02:46 PM   #30
OfficialBOLO
OfficialBOLO's Avatar
Russian Federation
37
Drives: 2013 F30 335i X-Drive MSport
epic list, thank you so much.
2013 F30 335i X-Drive / AW / CR / MSPORT / PREMIUM / TECH / HK / Heated Seats / Sport Auto / PDC / M Performance Grills and Spoiler / 20% tint (sold)
1995 Toyota Supra Single Turbo (for sale)
      07-30-2012, 07:59 AM   #31
motorcyclerider
Drives: 2009 335i
anyone know code 2F7F ?
      12-19-2012, 10:42 AM   #32
Ammo335xi
Drives: 2008 335xi
Code 29CC
I took my US spec car into a dealer here in Germany for a SES light. Turns out they had to replace 3 fuel injectors, charged ny 1/2 price for the parts and full price for labor??? Should the labor been free too since the injectors were under the SA? Anyway a month later i took the car back and they read my key and printed out the CBS info (in German) and it says i have a DTC Code 29CC. After translation i came up with Air intake temp sensor. Is this somehthing a half knowledgeable grease monkey can replace or will i need the computer re coded?
Thanks for any help.
      12-22-2012, 10:06 AM   #33
sofresh
sofresh's Avatar
48
Drives: slow
need help with a code P16B7
      12-28-2013, 09:16 AM   #34
wfo_180
Drives: 335 x drive
2009 335i x drive
I did not see a fix listed for 2A2D, I also get 2AAF coming up.
The one I am trying to fix at present is 93B1, Not Present, MRS:Head airbag, right.
We are getting the typical airbag light on with the seat belt light. Could this be the airbag sensor / pad in the passenger seat.
      12-28-2013, 06:48 PM   #35
Sethro
Drives: 2007 335i
I cant find a list of codes and what they mean on this forum, my 2007 335i had these codes in the cobb tuner
P2EA1
H2FDB
H2D25
H2AAF
H2D25
H2FDB
does anyone know what they mean??
Thanks
Sethro
I repair iPhones, smartphones, Tablets and laptops
www.tecrehab.com
      03-07-2014, 10:31 AM   #36
kiteboy
kiteboy's Avatar
France
12
Drives: E92 Stage 2 BR Performance
with Bavarian Technic Professional Cable, it is possible to diag bmw serie3f30, serie 5 gt f07 etc...???
335i Pack M Stage 2 BR Performance 403,5 hp 582n.m/Bilstein B14 pss/R&B PVC2 valve/K&N air filter/Spearco FMIC/pre cata empty/EBC Redstuff,aviation hose, BMW Performance exhaust, Charge pipe Evolution Racewerks, Forge DVs
      03-14-2014, 10:39 AM   #37
kiteboy
kiteboy's Avatar
France
12
the responss is yes with last sotware version bavarian 1.9.x.x
i had test on 535i GT F07 N55 and no pb
      02-16-2015, 07:37 PM   #38
God666
Drives: E92
All,
I have created a spreadsheet with an assembly of all the fault codes (that I had access to) and placed an input sheet on front so that you can type in your JB4 code and it will convert it to a fault code and then return for you, the fault description. If you already know the fault code, you can type that directly into the bottom section to get the description of the fault. You will note that I have left an example entry into each section.
Happy to get some feedback on this. There are 790 individual fault codes in this list.
Note, when you download the attached file, make sure you rename the extension from .txt to .xlsm or it won't work for you.
Happy to receive edits to this list or additions as it is likely to be a far from exhaustive listing.
Note, it is a protected worksheet in order to prevent accidental deletions of formulas etc however, if you want to customise it for your own use/reasons, the password to unlock it is blank ie. no password.
Cheers,
Gary
      03-15-2015, 03:21 PM   #39
Air Drop
Air Drop's Avatar
36
Drives: 08 E92 335i
Awesome data gents, thanks.
-Mike
2008 335i 6MT Coupe
Sapphire Black Metallic / Saddle Brown
      04-15-2015, 12:52 AM   #40
firemanjust1
32
Drives: Audi S3/03 350z
Any help with figuring out 2FC2/9F22/9e22 would be greatly appreciated thanks guys.
      06-10-2015, 12:50 PM   #41
n3Joke
Drives: supercharged
Trying also
      01-23-2016, 11:43 AM   #42
kiteboy
kiteboy's Avatar
France
12
Question
Hi i meet some problem with bavarian tool pro and particularly with actual value menu..
when i want monitor actual value on my car all are false or unbelievable ????
like example
and car started battery voltage ????????????
      04-29-2016, 04:26 AM   #43
jzchen
12
Drives: '08 335xi E90
like example
I recently did an oil change and brake fluid change on my '08 E90. I updated the Bavarian Technic software to the latest version, and when I tried to reset the CBS for oil change, brake fluid service, and vehicle inspection, I was only able to reset the oil change. In the past I had trouble resetting and contacted them. Their response was to install an older version, I think 1.8.6.0. I started with the next older one, and then the next. Luckily I still had some older software in my downloads folder. 1.8.6.6 did not work, but finally 1.8.6.0 did. Maybe if you can try this, find the older version in your download folder and try to see if the Bavarian Technic works properly again?
      02-23-2017, 06:01 PM   #44
chambr
Drives: 2007 335i
Fault Codes ....
Found this thread while searching ... it is a bit aged but maybe someone knows .....
Here is a quick list of some codes found using the Bav tech cable and SW ...
Unfortunately I cannot find a single one of these codes in any thread or website ....
Any thoughts on where I can get this info so I understand my car better?
Thanks in advance ..
-Mike-
MSD80/MSD81 Engine module for N53/N54
Module Identification
Hardware Number 121221F0B79A
Hardware Version Number F1
Coding Index 12
Diagnostic Index 61F0
Variant Index 644F
Date Of Manufacture 74045200
System Supplier BMW
Message Catalog Version 70.83.0
Software Version 0.128.7
OS Version 189.116.4
Current Fault Codes
F0B7
Error will cause a warning light
Test conditions have not been completed
F112
Error is currently present
F064
Timeout
7404
5300
8007
Timeout
7404
0400
00E1
0005
1212
F0B7
F112
F064
Timeout
7404
5300
8007
Timeout
7404
0400
00E1
0005
1212
F0B7
F112
F064
Timeout
7404
5300
8007
Timeout
7404
0400
Instrument cluster PL2
Hardware Number 6300C4821212
Hardware Version Number 21
Coding Index F0
Diagnostic Index B79A
Variant Index F112
Date Of Manufacture 61F06444
System Supplier
Message Catalog Version 4.82.0
Software Version 0.70.82
OS Version 0.0.128
Current Fault Codes
F0B7
F112
F064
Timeout
7304
5200
8007
7404
0400
00E1
00B6
2012
Timeout
FFFF
Timeout
8612
30C1
Timeout
FF00
AB83
