BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
Mporium BMW
      06-24-2013, 12:42 PM   #45
RBB
RBB's Avatar
22
Drives: E92 M3
Originally Posted by signes View Post
I ordered a stubby 7mm hex from them for brake changes and it makes life a lot easier. Pricing is a ripoff but couldn't find it elsewhere.
Thanks to the OP for posting this, going to do next weekend.
Yeah, I also picked up one of those while I was on there. I agree....the pricing isn't the greatest, but they do have some hard to find items that'll save the BMW DIY'er a lot of frustration.
      07-06-2013, 09:26 AM   #46
Sean1933
31
Drives: E92 M3
      07-14-2013, 01:27 PM   #47
kawasaki00
kawasaki00's Avatar
233
Drives: SG-E92 ESS-650 BPM Tune
Just as a follow up I have been running the Mobil 1 75w-140 with the LS additive in it and have had no troubles or chattering or grinding out of the diff. Cost 40 bucks for two containers.
**Follow up, after 500 miles the diff started to chatter bad on right hand turns so I went back to the FM boosted bmw fluid and within 20 miles the noise was gone. I know other guys running alternate fluids without issues but it dod not work out for me**
Electronics Junkie, Engine Builder.
a5m617.00
      09-23-2013, 09:00 PM   #48
happos2
Dingleberries
76
Drives: Gray E92 M3
Where did you buy this? Did you replace the plugs as well with new ones? I just changed my oil and found out the dealer stripped the drain plugs and luckily I bought new ones to replace.
      09-24-2013, 08:32 AM   #49
kawasaki00
kawasaki00's Avatar
233
Advance and auto zone carries it. Plugs have orings so no need to replace anything. Just a FYI after 500 miles my diff started to make noise, I ended up having to change over to the bmw with fm booster. I guess I need to update the original post
      09-24-2013, 08:35 AM   #50
happos2
Dingleberries
76
Drives: Gray E92 M3
So the added LS additive the Mobil didn't do the trick? I think I might go with Redline as a lot of people have liked that. I also believe they make an additive you can put in after the fact.
Thanks for the info.
      09-24-2013, 09:10 AM   #51
kawasaki00
kawasaki00's Avatar
233
Correct, the Mobil with LS additive was still not enough. If you want to try something else I would go with the Royal Purple. Realistically I would say all the big ones, valvoline, mobil royal and redline are all going to be the same. If one works they will all work, if one doesnt work then the only option is going back to the FM bmw stuff. I am not a fan of adding booster on top of the original oil unless it is made by the same manufacturer. Most additives will never mix with the original fluid and will just sling around inside the diff as 2 different fluids.
      10-11-2013, 02:12 AM   #52
EarthboundMisfit
EarthboundMisfit's Avatar
Australia
28
Drives: E92 M3
Anyone tried Red Line 75W140 gear oil in their diff?
      02-23-2014, 11:04 AM   #53
BaseM3
BaseM3's Avatar
42
Drives: 2011 Space Grey M3
I had similar clearance issues with the e36 M3 Diff plugs. I got a 14mm hex wrench from sears and used a grinder to make it a stubby one. worked perfectly.
11 Space Grey, M-DCT Base M3
      04-12-2014, 01:45 PM   #54
DavidZ
DavidZ's Avatar
83
Drives: '11.5 E90 M3 6MT
Originally Posted by Sean05 View Post
6. THEN YOU HAVE TO SQUEEZE THE BOTTLE CAUSE ITS PRETTY THICK..(DO THIS YOU WILL ONLY NEED 2 1/2 BOTTLES. I HAD 1/2 OF 500ml LEFT...
So about 1,250 mL? Does anyone know the capacity specified by BMW for a service fill? I'm trying a different brand of fluid, need to add 10% LSD additive and would like to calculate how much LSD additive I need to put in beforehand.
Thanks
-David
      04-25-2014, 10:47 PM   #55
edwinm3
edwinm3's Avatar
980
Drives: F82
TIS copy
Here you go guys, Screenshots of my old TIS copy. OP feel free to add these to your initial post
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
a5m617.00
      05-06-2014, 02:25 PM   #56
kaotik182
kaotik182's Avatar
29
Drives: 2011.5 IB E90 M3 ZCP
Is there an issue going back to regular/ non-FM fluid? At 1200 mile service, dealer put in the regular/ non-FM fluid. At 30k mile service, the same dealer put in the fm fluid, but I never had an issue with noise. I did not know they put the fm fluid until the work was done and I saw the work invoice. I told them about it after but it was too late. They said it is the only fluid they carried/ dealer excuse. I will be doing my 60k mile service soon. Thanks in advance for the response.
2011.5 IB E90 M3, 6MT, speed cloth, carbon trim, ZCP, shades, ipod, alarm, and bluetooth. No sunroof. No nav.
2004 Mystic Blue 330CI ZHP - Sold.
      05-06-2014, 06:45 PM   #57
SoTempted
SoTempted's Avatar
20
Drives: Incompetently
subbed
      06-19-2014, 01:05 PM   #58
///Mangler
///Mangler's Avatar
336
Drives: E30 M3 Darth Vader Trackcar
2000 E39 M5  [9.00]
How much does the FM modifier reduce the effectiveness of the LSD? This was answered before in another thread but wanted to get it in this DIY thread.
http://www.m3post.com/forums/showthr...ange+%24468%3F
T
      08-26-2014, 05:26 PM   #59
Hujan
Hujan's Avatar
569
Drives: M3
Considering swapping out my diff fluid. Can I re-use the factory drain and fill plugs, or do I need to order new ones? Do they use crush washers like the oil plugs?
      08-26-2014, 05:35 PM   #60
marksae
marksae's Avatar
36
Drives: ///M
No. The plugs have o-rings on them. If only they sold just the o-ring so we wouldn't have to buy a new plug each oil change. The plugs are around $7 each, so they're not that much.
04 E46 M3 6MT - AW / Cinn
93 FD RX-7 Base Manual - BB / Blk
IG: @gearheadtwins
      08-26-2014, 05:40 PM   #61
Hujan
Hujan's Avatar
569
Drives: M3
Thanks. So it's recommended to replace both plugs? Do you have part numbers by chance?
      08-26-2014, 05:46 PM   #62
marksae
marksae's Avatar
36
Drives: ///M
I replaced both the drain and the fill plug. P/N's are listed in link below. IIRC, the drain and fill plugs are the same. The link below states the same thing.
http://www.ecstuning.com/BMW-E90-M3-...tial/ES205597/
IG: @gearheadtwins
      08-26-2014, 11:00 PM   #63
Hujan
Hujan's Avatar
569
Drives: M3
Much appreciated. The local dealer near my work has several on hand, so I'm going to grab a couple.
Does you happen to know what the exact amount of fluid is? I'm seeing conflicting info in this thread.
      08-27-2014, 09:35 AM   #64
marksae
marksae's Avatar
36
Drives: ///M
I think it's 1.2 qts.
IG: @gearheadtwins
      08-27-2014, 10:30 AM   #65
VictorH
433
Drives: '09 M3
Yes, have about 15,000 miles on mine now. No problems and no noises at all. I previously had diff noise, they (dealer changed) and added modifier and it helped but still has occasional noise on tight corners. That's gone now with the Redline (make sure you get the limited slip version as there are two kinds).
a5m617.00
      09-13-2014, 05:57 PM   #66
dbyrd
DSC Off!
dbyrd's Avatar
307
Drives: 2012 E92 M3 6MT ZCP
I've been using the Redline mentioned above for the last 45,000 miles with no noise or problems - easiest DIY ever. I replaced the drain plugs - don't forget they have metal washers as well.
m3post
