BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
BPM
      02-25-2024, 01:04 PM   #1
imtylre
Drives: e92 m3
Tick on engine shut off after rod bearings
I just did the rod bearings on my 09 115k mile m3.
I removed both engine belts with anticipation of replacing them, but could not find belts locally so i threw on original pulleys and belt.
The car runs great but on engine shut off, 5-8 seconds later very consistently there is a singular clink noise.
I also have the code: P1748
Here is a link to the audio file: https://file.io/uuTwBxIgINY4
Any thoughts what this could be?
      02-26-2024, 07:51 PM   #2
imtylre
Drives: e92 m3
Seems pretty unrelated to bearings, have driven the car 50 miles so far and it sounds great overall.
I noticed going into accessory mode will create pretty much the same clink. Cleared the code and p1748 never came back. Pretty unbothered overall, but I wish i knew what it was.
      02-27-2024, 04:25 PM   #3
sergbaja5t
sergbaja5t's Avatar
62
Drives: 2011 E92-M3 Comp
I did a oilfilter housing gasket repair, and fired up the car with the plenium on, wide open itb's. After I shut off the car, the actuators do this twitch motion, a very loud "tick". Maybe this is your issue.
      03-01-2024, 09:26 AM   #4
imtylre
Drives: e92 m3
I'm not sure im following. You think shutting off the car and the clink is just the actuators doing their final close?
      03-01-2024, 02:55 PM   #5
sergbaja5t
sergbaja5t's Avatar
62
Yes I believe so.
      03-01-2024, 04:05 PM   #6
tdott
3956
Drives: M3
What does this have to do with rod bearings?
Sounds unrelated.
      03-05-2024, 08:16 PM   #7
imtylre
Drives: e92 m3
In my mind it's completely related to the rod bearing job I just did. New noise pops up after half the car is disassembled and reassembled, why would I not mention I did all that lol.
However I've just started ownership of this car so it could have always been there.
      03-05-2024, 08:17 PM   #8
imtylre
Drives: e92 m3
Yes I believe so.
I'll mess around with turning off the valves exposed and shut it off. A visual confirmation would set me at ease, thanks
m3post
