Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      04-02-2024, 06:00 PM   #1
F80manz
F80manz's Avatar
54
Drives: 19 M4 Comp 6MT
Do I need timing tools to replace the exhaust cam ledge bolts?
As the title suggests, I need to replace my exhaust cam ledge bolts as I have a tap a few minutes into cold start which goes away when the car is warm. No sign of metal in the oil.
I was looking to DIY this and just replace the valve cover while I'm at it.
ISTA shows cam removal and requires timing tools to lock TDC in that procedure. However, I can't find anything on the cam ledge bolts alone. Would it be okay to just do each bolt one by one? (i.e. completely remove bolt 1, replace new bolt 1, torque bolt 1, move to bolt 2 etc).
Car is not under warranty and I do not want to shell out 3k in labor. Local BMW shop that I got my CH done at takes way too long.
Thanks!
Tags
cam ledge bolt, cold start, knock, tap, tdc, timing
f80post
