07-14-2015, 12:53 AM | #1 |
23
Rep 84
Want to Flush Break Fluid
How many litter of Break Fluid do I need if I want to flush my Break Fluid for track use? And what Brand do you guys recommend?
07-14-2015, 06:07 PM | #3 |
432
Rep 887
Drives: Enzo F23 228i
Flushed mine and I had some air in the lines, much nicer now!
07-14-2015, 07:10 PM | #4 | |
23
Rep 84
Is this the best one? http://www.amazon.com/ATE-706202-Ori...eywords=ate200 http://www.amazon.com/Motul-RBF-Racing-Brake-Fluid/dp/B000AURZ08/ref=sr_1_sc_3?ie=UTF8&qid=1436919123&sr=8-3-spell&keywords=Hight+performace+Brake+Fluid Last edited by BBMMWW333; 07-14-2015 at 07:16 PM.. |
07-14-2015, 07:17 PM | #5 | |
1403
Rep 5,262
but RBF will suck water more easily than ATE200 |
07-14-2015, 09:01 PM | #6 | |
127
Rep 765
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
07-14-2015, 10:10 PM | #7 | |
153
Rep 446
07-15-2015, 08:26 AM | #9 |
153
Rep 446
I found the BMW branded fluid and it stated a wet boiling temp. of 311 F and dry boiling temp. of 446 F. Anyone please correct me if I'm wrong. I'm quite hard on my brakes (and so are a couple of my favorite tracks) so I didn't even attempt a single session with the stock fluid.
07-15-2015, 11:58 AM | #10 |
451
Rep 845
The stock BMW fluid isn't that bad. Could be worse. But switching it out is a cheap upgrade that helps fight fade quite a bit.
07-16-2015, 01:04 PM | #11 |
119
Rep 221
Has anyone physically flushed the brake system themselves? What process was used? I tried this past weekend without success. I used a vacuum system starting at the rear wheel, but was unable to pull any fluid through the system.
I've heard rumors about needing a diagnostic tool to actuate certain solenoids to allow fluid flow, but haven't been able to verify. |
07-23-2015, 09:25 AM | #12 | |
119
Rep 221
07-23-2015, 11:15 AM | #13 |
3074
Rep 5,577
I haven't done a brake bleed yet, I want to go a BMWCCA DIY tech session in Sept and ask the correct method. Since the m235 has the hill assist you could be right that the car needs special care like the SBC Mercedes system when doing BRAKE PAD replacement. You should chk if BAVAUTO has any tech info and think about doing PRESSURE BLEEDING as opposed to VACCUM BLEEDING. |
08-01-2015, 08:38 PM | #14 |
125
Rep 356
08-01-2015, 09:03 PM | #15 |
119
Rep 221
What method did you use?
I spoke with a BMW tech who stated a vacuum bleed wouldn't work unless used in conjunction with a diagnostic tool. The tool walks you through a process and activates the solenoids as needed to ensure all fluid is flushed. This is the route I ended up going. |
