07-01-2023, 03:38 AM | #1 |
Rep 7
Diy sport electric seats retrofit guide
I actually wrote this tutorial/schematic for myself to gain insight into how everything should be connected. I just made a DIY out of it to help others. I have to do this myself tomorrow, if my theory is correct it should be like this to come out.
If there are any errors, please let me know and I will correct them in the schematic pic upload regards, Edwin (loctite) |
07-01-2023, 04:11 AM | #2 |
41
Rep 161
Very nice writeup. Remember the coding.
Add 459 to VO for the electric adjustment with memory and 494 for seat heating driver/passenger if it is not already in the car. If no seat heating you will have to change the climate switch unit to one that have the two buttons. |
07-01-2023, 06:28 AM | #3 | |
Rep 7
Can we code with Bimmercode? |
07-04-2023, 10:28 AM | #5 |
Rep 7
Plugged everything in, everything works right away. Only haven't been able to check the heated seats yet because I don't have the module yet. 2 error codes for the airbags/belt of both seats. Have this reset at my garage and all errors are gone.
Strange that the error codes came, because I transferred the belt modules from my old seats. luckily everything was reset and everything works properly |
07-09-2023, 01:39 AM | #7 |
Rep 7
I haven't coded anything, everything works perfectly, also the memory! if you stick to my schedule everything will work right away. I would swap the old seatbelt modules from your old seats to the new ones. You may not get a malfunction afterwards, in my case I did get a malfunction of both seat modules and had it coded away at my garage
07-17-2023, 02:43 PM | #9 |
Rep 91
Can I tap from nearby wire or run to fuse box?
2013 F30 328i N26
02-23-2024, 03:30 PM | #11 |
540
Rep 817
Drives: bmw M3 F80
No
there is no (line) in the large module it's like the driver's side |
02-28-2024, 07:38 AM | #13 | |
243
Rep 499
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
02-28-2024, 03:12 PM | #14 |
540
Rep 817
Drives: bmw M3 F80
02-28-2024, 03:13 PM | #15 |
540
Rep 817
Drives: bmw M3 F80
02-28-2024, 03:41 PM | #16 |
243
Rep 499
I've heard of that, but seems super annoying to do. I've heard that the airbag restraint light can be caused by busted tensioners.
02-28-2024, 03:48 PM | #17 |
540
Rep 817
Drives: bmw M3 F80
04-21-2024, 06:56 AM | #18 |
Rep 1
Dear Loctite Initially, congratulations on the retrofit guide for the electrical connection of the seats. I recently bought a set of BMW F12 M6 650I seats to connect them to a vehicle from another brand. I need to make the connections so that the electrical controls work normally. Based on your experience, could you help me make the correct connections so that the electrical controls work? I transcribe below the information contained in the electronic unit: BMW 61.35 9 313 997.9 01 SM MF/M - HKLA BMW AG D - 80788 Munich A2 - C731 - 2900 - 6 - 00 SN - No. 00275070 I need to know the pin connections for the basic bench movements to work. I attach photos of the banks. I thank you in advance for any contribution. Yours sincerely Lindauto Last edited by lindauto@gmail.com; 04-21-2024 at 07:11 AM.. |
04-26-2024, 02:33 AM | #19 |
194
Rep 650
Drives: 2018 F48 X1 xDrive 18D
Does someone know here if Comfort seats from higher series would physically fit the F30? are the mounting points the same?
