DIY: BMW Short Shift Kit (SSK) for 335i
12-21-2007, 07:52 AM | #24 | |
550
Rep 6,563
http://www.e90post.com/forums/showpo...8&postcount=49 I did this as well and could have used your DIY back then when trying to remove the shift lever and pivot bearing. Also, on my 05 330i, I do not have the foam pad, I only have the carpet and I did not see the need to remove the carpet.
under construction! |
12-21-2007, 10:42 AM | #25 | |
Certified Purveyor of the High Life
63
Rep 260
Correct, you don't have to remove the carpet, but it takes about 5 seconds, and one less thing to get grease on, or screw up with the tools. Cheers! |
12-21-2007, 11:44 AM | #27 | |
Fear knocked, Hope opened, but no one was there...
Rep 56
In "step 26" you are showing two different angles. With the angle you chose as "correct", are the gears fully engaged in R, 1, 3, 5? I am asking because from the looks of the pictures in "step 26" mine is in the "incorrect" angle which in turn makes sense why people are hitting their hand on the wood trim in 2, 4, 6 gears. Take a look at my pictures post here and see the one that is in 2nd gear (third picture down): http://www.e90post.com/forums/showpo...&postcount=107 Here is one: |
12-21-2007, 12:08 PM | #28 | |
63
Rep 260
Bingo: Your shift lever is installed backwards!!
(Unfortunately) You'll need to: 1) Get under the car and remove the circlip 2) Disconnect the shift lever from the selector lever 3) Rotate the shift lever 180 degrees 4) Reinsert it back into the selector lever 5) Reinstall circlip 6) Pull off and reinstall the shift knob in the correct position! Except step 6, you MAY be able to do this all from the bottom of the car, or have someone on top help out. Worse case is you simply follow the directions in the DIY - THERE IS NO NEED TO remove the shift lever and bearing from the shift arm though!! Quote:
12-21-2007, 12:16 PM | #30 |
63
Rep 260
Your second question: Actually no, in the pictures in step 26, the shift lever is still in "flop around" mode, and not reconnected to the selector lever yet. The correct orientation is the "accute angle" should be toward the front of the car, not toward the back.
The best graphics for how the shifter should look in all the gears, is at the very end with everything installed. Basically, in neutral, the lever should pretty much point straight up... Looks like you have a little project this weekend! |
12-21-2007, 12:21 PM | #32 |
Rep 56
12-21-2007, 08:33 PM | #33 |
137
Rep 8,067
Do you think the BMW short shift kit will fit my 2008 335xi coupe? Some of the guys in the parts dept are telling me no. I really dont like the long throw on my xi model. I feel like im driving a mac truck
12-21-2007, 11:01 PM | #34 | |
63
Rep 260
The parts people told me the exact same thing for my 335i => this kit is NOT compatible - still scratching my head - its fine! I hope someone who has access to the BMW parts catalog or direct experience can weigh in on this! Even if its the same part, no guarantee that the DIY will work to the letter with the xi, since I'm not familiar with the driveline... |
12-22-2007, 12:28 AM | #35 |
33
Rep 496
This ssk works for the xi. I had it installed last week and it works great. Its dead in the center...my shop said they had no problems installing it. lata
Manny : 2008 335xi sedan : SG, Terra, Alum, 6mt, SPP, PP, 162s Mods; Procede V4 | Remus Quads | UR catless dps | H&R coilovers | Modified CDV | Injen Intake | Spearco IC | Forge DVs | Defi Boost Gauge w/controller | Vorsteiner CF Hood + Front Lip | OEM M-tech Body kit | Hamann eyelids | Predator Ice Angels | 19" Volk Progressive Me's | Rotora BBK | 18" Rota Torques w/Blizzaks |
12-22-2007, 04:46 AM | #37 |
33
Rep 496
Rudnters Racing....its in Freeport. www.RudntersRacing.com
12-22-2007, 10:36 AM | #38 |
2067
Rep 5,373
Excellent writeup. Thanks.
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
12-23-2007, 12:23 PM | #40 |
99
Rep 990
Excellent writeup Jahwerx.
- only 2 cents I would add would be to remove the trim surrounding the shifter so it can't get marred if a tool slips or something.
BMW : Sine qua non
Mods: Blacklines | Rear Seat Power Outlets | Rear Fog Lights | Ashtray Garage Door Opener |
12-23-2007, 03:36 PM | #41 |
Rep 32
I put my 335xi up on a lift today just to explore what it was going to take to get to the clip on the shifter. After removing the plastic panels and bending the heat shield away I still couldn't even see the clip let alone get to it. The transfer case for the AWD is right in the way. I would be interested in knowing from someone who has actually done the shifter change on an 335xi what needs to be removed. It looks like dropping the exhaust and heat shield might work but I would like to know before I go to that trouble. Any information would be appreciated as this car really needs something done to shorten up the shift throws. Thanks.
12-23-2007, 04:29 PM | #42 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
Thanks for the excellent write-up! Since I already have a shorter shift knob/boot (oem M knob) I can just order the shorter shifter, bearing, and clip... nice! I'm going to check out how much those parts cost now...
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
12-23-2007, 10:00 PM | #43 | |
Do, or do not. There is no 'try'.
12
Rep 328
Drives: 2011 X5 50i M Sport
That is exactly what TurboFan and I ran into when whe got under his e90 335xi. We could not find the clip or the bottom of the shifter. I think on the sedan, you probably have to drop the transfer case and I have NO idea how hard that would be. I wonder if the coupe xi is any different? Supremo, can you ask your shop if they had to do anything special to get to the shifter in regard to the transfer case? More updates from any Xi people would be great....otherwise this is a great DIY, thanks!
2014 E63 S Model. Palladium/Black/Night Styling.
DOB 10/17/13; DOA 11/11/13; DOD 11/14/13! 2011 BMW X5 50i M-Sport: Gone but not forgotten |
12-24-2007, 01:48 PM | #44 |
Moderator
132
Rep 6,775
Can anyone confirm that the install on an E92 is the same as the E90 that this DIY was written for?
I just ordered the SSK, and would like to confirm this if I could before I get under the car.
-Michael.
