12-04-2014, 07:19 AM | #1 |
Rep 80
Dust-less or at Least Less-Dusty Brake Pads
I suspect some of the brake pad manufacturers have now caught up with street pads for the F80/F82. I am now very tired of the huge amount of dust generated by the stock pads although I am pleased with their performance and lack of any squeaking.
Has anyone found a replacement street pad that they like that is as close to dust-less as possible and does not squeak? Last edited by celler; 12-04-2014 at 09:05 AM.. |
12-04-2014, 06:14 PM | #3 |
11
Rep 239
They are as dusty as ever with the exception of the Carbon ceramic ones. For the OP, it's too early to have a wide aftermarket pad selection but when available, the Akebonos Ultra Premium pads are mostly dustless.
12-05-2014, 09:47 PM | #5 |
23
Rep 115
Drives: 2015 M4 6MT
Went with the Centric Posi-Quiet semi-metallic about a month ago. So far, so good. Used them on my last M, and they worked very well. Little dust, reasonable cold friction, and no noise. Zeckhausen has them. Do not use these on the track.
12-08-2014, 12:05 PM | #6 |
1860
Rep 2,104
I've read that as well. I'm planning to try the Akebonos when they have an option available. Too bad these brakes are still so dusty. With the older BMW's, took about 1 day. Maddening. And I even had the wheels coated.
That's what I remember reading somewhere. |
03-23-2015, 01:31 AM | #8 |
1538
Rep 1,665
Bumping this thread to see if anybody has found a solution to the super dusty stock brake pads.
Also, what are people using to clean their brake dust coated rims? Any spray on wheel cleaner that won't damage the clear coat, yet can get the dust off rims w/o wiping and scrubbing? |
03-23-2015, 08:10 AM | #9 |
1943
Rep 1,552
For street use im installing centric pads from zeckenhausen later this week..I'll report back after
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
04-02-2015, 09:20 AM | #10 |
1943
Rep 1,552
installed the centric semi-metallic pads in the rear, and centric ceramic in front last night. obviously if i track the car we'll throw stock back on, but i was excited to try these for the street for dust reasons.
overall im pleased. I've only driven normally so far but i'd say they had 85-90% of the bite of stock, although im sure testing would say stopping distance is a lot worse. ill do some more spirited driving this weekend and report back with more impressions.
04-02-2015, 09:53 AM | #11 | |
328
Rep 1,450
04-02-2015, 10:25 PM | #12 |
Supreme Allied Commander
3887
Rep 54,530
Drives: F80 M3
Just be very careful with the Stoptech Ceramic pads, they have much less friction and provides much less brake torque than OEM pads. The semi-metallic version is on the same level as the OEM pads as far as friction level and brake torque goes. Their Street Performance pads will have slightly more friction and brake torque along with less dust. The Street Performance line is the best all around pad, although not low dust when comparing to other Stoptech offering, it is lower dust than OEM.
04-03-2015, 09:39 AM | #13 |
1397
Rep 3,152
damn it, after driving for 4 days after a wash, it looks like they haven't been washed in 6 months. But the stockies do stop beautifully.
