For Help with NCSExpert Errors
02-22-2013, 04:43 PM | #89 |
19
Rep 177
Drives: 2011 335i E90 LCI
02-25-2013, 07:20 PM | #91 | |
19
Rep 177
03-03-2013, 03:50 PM | #92 |
33
Rep 648
What can't you do with it? I haven't tried it yet because I'm waiting for a new cable but everything seemed to install fine on my laptop and with the patched NCS Expert you can edit profiles and such and even get most of it in English with the replacement .txt file he included.
03-05-2013, 04:51 PM | #93 |
259
Rep 400
Drives: 2006 M5, 2012 X5d, 2008 E91
I am having the same issue (using v4.0.1). Where can I get my hands on an older executable version?
03-05-2013, 05:55 PM | #94 | |
19
Rep 177
Edit: seems like the profiles I have in the directory are from older NCSExpert versions. Therefore won't work on v4.0.1. |
03-05-2013, 07:31 PM | #95 |
259
Rep 400
Is there a fix???
03-05-2013, 07:41 PM | #96 |
33
Rep 648
To edit profiles you need to get the patched version which is provided in a subfolder in that link posted above, then load default profile and edit it so that the same functions are enabled as in the profiles in the older versions and you can save the edited profiles under different names and they will work.
03-08-2013, 09:27 AM | #97 |
Rep 9
I'm running the 64 bit version of NCSEXPER and I'm trying to add to my vo to change stereo from base to HiFi ($676), but I can't find the lma module anywhere so while I can write it to CAS that alone doesn't help much... Any ideas?
03-08-2013, 09:54 AM | #98 |
442
Rep 18,331
YOu dont have a LMA module! You have to use the NFRM module...I think you should go back and do some more research and learn how to code before you start VO coding
03-08-2013, 09:58 AM | #99 |
Rep 9
Ok thanks. I had done some research and the document I was using had said to just code the second ecu after CAS, so I did some looking online andshe only document I had found said to use LMA... Are there any links you could recommend for VO coding? I already know how to change settings with the .MAN file in NCSEXPER/WORK, however VO is a little different
03-15-2013, 06:33 AM | #100 |
49
Rep 347
You need proper profile EXPERT PROFILE. I can provide it to you if you want.
To add new VO you have to do FA_WIRTE to CAS and NFRM module in your car, doing the same way. Download this: http://chomikuj.pl/trandolf/INNE/USI...,641060277.pdf Click on a green button: POBIERZ. You should choose NFRM instead of LMA. Last edited by pweber84; 03-15-2013 at 06:39 AM.. |
04-07-2013, 11:27 AM | #101 | |
102
Rep 1,903
Drives: e92 335i 6MT
04-07-2013, 05:18 PM | #102 |
73
Rep 1,375
got this error ? "The following feature is the vehicle contract invalid" when ncs-expert tool any idea
Current 2008 M6 e63 v10 6mt Current 2012 e70 x5 35i -jb4 2008 335xi e92- Sold 2007 335i e90 - Sold 2002 Taig / Red / / / M3 - SOLD |
04-08-2013, 02:34 PM | #103 |
Rep 106
Drives: E90 06 320D
Canīt read kombi module
Hi
Iītrying to read the kombi module on my e90 06, but always get error: ERROR! Modul: LFCDHDIA.CPP (A_PL2KMB.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei BIP-0009: BEST VERSION ERROR >> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000 CODIERINDEX_LESEN >> ERROR! Modul: COAPI.CPP, Proc: coapiReadCodierIndexFromSg, LineNr: 05, ErrorNr: 2000 CODIERINDEX_LESEN: A_PL2KMB >> ERROR! Modul: LFCDHDIA.CPP (A_PL2KMB.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 BIP-0009: BEST VERSION ERROR >> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000 CODIERDATEN_LESEN All other modules reads without problem. Know it must be something wrong with the daten files, but don`t know how to fix it. tried several versions ( 46.3 , 48.1 , 49 ,) Any ideas? |
04-08-2013, 03:20 PM | #105 |
Rep 106
Drives: E90 06 320D
3.1.0 running on Win XP and on Mac Vmvare fusion win xp
04-09-2013, 08:53 AM | #107 |
Rep 106
Drives: E90 06 320D
04-09-2013, 09:26 AM | #108 |
49
Rep 347
04-09-2013, 11:01 AM | #109 |
Rep 106
Drives: E90 06 320D
04-13-2013, 07:12 AM | #110 | ||
33
Rep 648
