01-30-2024, 05:27 AM | #1 |
30
Rep 502
Superglue removal
Does any detailer have recommendations for getting super glue off car paint. 2 days ago I was working in my garage and I must somehow got a little super glue on my car what’s the best way to remove it?
01-30-2024, 08:57 AM | #2 |
1116
Rep 1,313
I'd try 3M Adhesive Remover (spray then let soak in for a bit), then hit with some moderate heat, then try scraping with something like a bondo spreader. None of this should damage paint if done carefully
01-30-2024, 10:46 AM | #3 |
1941
Rep 876
Don't be foolish and try to do it yourself. It'll be worth the hundred bucks or so have it professionally done.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
01-30-2024, 05:36 PM | #4 |
344
Rep 556
Drives: F82 M4 BSM
Rubber eraser wheel! Can get at autozone.
17' F82 BSM - Current Built Motor/PS2+
16' F82 Silverstone - Totaled FBO |
01-30-2024, 10:33 PM | #5 |
287
Rep 270
Stoners Tarminator. You can pick it up at O'Reilly. Spray it and let it sit for a minute or two and a clean microfiber towel should do the trick. It took every bit of adhesive off when I removed the 7 year old factory spoiler. Just make sure to rinse everything with water afterwards to clean it
