02-09-2016, 08:58 PM | #67 |
840
Rep 2,402
Wow, tremendous response!
OK, I'll repeat myself, what basis do you have assuming that? Or, again, as you attempted to refute...is it just wishful thinking? Sad as it may seem, BMW doesn't care about how much headroom they give their customers for aftermarket gains. So again, while we all hope it's an up-sized snail...we have nothing to support that it is. In fact, because they've publicly mentioned all the other improvements over the standard N55, and haven't mentioned a larger turbo...one could argue that fact as evidence that they are the same. Certainly, it would go some way in protecting M4 sales. After all, an M2 with a stock turbo supporting 450 whp would certainly make a more compelling case vs. the M4. P.S. I say all of this...while too think it's a bigger turbo...but not based on anything but a guess/hope/wishful thinking. Moreso that I don't think they can sell the M2 alone a VERY underrated B58 M240 unless the M2 is underrated itself.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) Last edited by PrematureApex; 02-09-2016 at 09:19 PM.. |
02-09-2016, 09:52 PM | #68 |
1577
Rep 3,888
Take a look at historical precedent. 10% whp gain for each platform is the norm. A different turbo for each hp target is the norm. If an M235i turbo was used for this application, it'd be near the top of its operating range.
02-10-2016, 12:32 PM | #69 |
152
Rep 336
Tried searching the forum for this as well as on the tech PDF, does M2 have passive or active suspension?
In the technical PDF, it says "reversal-load damping" is affected by the different driving experience modes. Does this mean active suspension? |
02-10-2016, 01:12 PM | #70 | |
Moderator
29669
Rep 13,139
The suspension is matched to bespoke springs and dampers but there's no adaptive suspension. "The problem with adaptive dampers is you're changing the damper, not the spring, so you end up with a spring that is a compromise between two settings", explains Isenberg.Have a look at the thread about the M2 M Performance coilovers that will be made available this Spring: http://f87.bimmerpost.com/forums/sho....php?t=1220019
///M is art ↔ Artemis
02-10-2016, 01:44 PM | #71 | |
840
Rep 2,402
Let's see...N54 and N55 (let's use the normal version) are both rated at 300 bhp. The N54 has MUCH MORE headroom in the stock turbos. On a tune only, the N54 is good for 80+ whp. Much more on full bolt ons (stock snails are good for 500ish bhp). The N55 is good for about 60 whp, and maxes out quickly after that. Nowhere near one another in potential. And both of them are more than 10% whp gain. More like 20-50%, depending on N54 vs. N55. Let's look at the S55...shall we? Stock, dynos around what, 410-420 whp? And the stock turbos max out at about what, 525 whp? 10% huh? Again, I've already said I don't think BMW would be maxing out the stock N55 snail, for the very reason that the B58 is so underrated. So we both think it will have a bigger turbo. That doesn't mean you should continue to post made-up, factually incorrect information to allegedly support that position.
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) Last edited by PrematureApex; 02-10-2016 at 01:57 PM.. |
02-10-2016, 01:55 PM | #72 | ||
2241
Rep 2,370
Soon. |
02-10-2016, 01:58 PM | #73 | |
840
Rep 2,402
And your post is irrelevant.
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
02-10-2016, 02:15 PM | #75 | |
152
Rep 336
However this gives rise to another question; what is this "reversal-load damping" change that's mentioned in the tech training pdf? |
02-10-2016, 02:17 PM | #76 |
4403
Rep 2,856
Drives: BMW M2 CSL Turbomeister
02-10-2016, 02:44 PM | #77 |
986
Rep 1,153
"Again, I've already said I don't think BMW would be maxing out the stock N55 snail, for the very reason that the B58 is so underrated. So we both think it will have a bigger turbo."
Even if they use the stock turbo, tuners might offer a rebuilt one, like Dinan did on the N54. And in this case only one turbo would have to be rebuilt--cheap!! |
02-10-2016, 02:48 PM | #78 | |
1236
Rep 1,963
02-10-2016, 03:09 PM | #79 | |
17549
Rep 25,131
My car made front page of Bimmerpost
02-10-2016, 03:27 PM | #80 | |
1236
Rep 1,963
02-10-2016, 03:29 PM | #81 | ||
112
Rep 147
02-10-2016, 03:30 PM | #82 | ||
17549
Rep 25,131
02-10-2016, 03:32 PM | #83 | |||
17549
Rep 25,131
You won't be disappointed, have driven a DCT before, takes a little adjustment, no creep and slightly awkward at low some and parking close used to be a minor fret. Once on the open road them, my god amazing, no power loss instant play station shifts!
02-10-2016, 03:41 PM | #84 | ||||
112
Rep 147
02-10-2016, 04:13 PM | #85 | ||
7909
Rep 11,785
Subaru ? Sure Mitsubishi? Heck yes. Ford ? Probably so But I don't see BMW AG putting out any info that they used xxx turbo or that the turbo has changed. They barely even provide max boost info. |
Kikuchiyo125.00 |
02-10-2016, 04:40 PM | #86 |
1236
Rep 1,963
Good point and I hope you're right!
02-10-2016, 05:29 PM | #87 | |
840
Rep 2,402
They specifically pointed out that this "N55" had a new closed deck block, a forged crank, upgraded pistons, etc. They literally drafted marketing material for the purpose of distinguishing the M2's engine from the regular N55. They made sure to put people's minds at ease that this wasn't a standard N55. And...for some reason...you think they left out a larger turbo? Either accidentally or intentionally? How does that make any sense?
02-10-2016, 06:00 PM | #88 | |
7909
Rep 11,785
It makes a lot of sense to me.. I think BMW isn't into releasing proprietary info. I DO think there is a new turbo and here is why.. - there is reference to a redesigned manifold/turbo sounds like a new location/turbo to me - dyno curves Did you see the difference in the N54B30TO and N55B30TO dyno curves? The new motor makes a TON more power at 6500 rpm and is still making power where the N54 has already given up... It looks like it really fully pulls to 7000.... I don't think that's just tuning and beefed up internals.. - everyone doubts BMW M... and they always find a way to throw down a trump card. As you mentioned.... there is a lot of work done to the M2 motor.... and I can't see keeping the same snail when so much else has changed from the regular N55 - this is BMW M.. |
