Wrapped my shark fin
04-17-2015, 01:27 PM | #1 |
43
Rep 902
04-17-2015, 03:34 PM | #4 |
94
Rep 1,568
Great job !!
BTW, how do you get these fins off? Thanks
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you" |
04-17-2015, 04:32 PM | #5 |
43
Rep 902
Thanks guys, it was actually pretty simple. Took a fair bit of heating but once you fo hire out how to remove all the folds it really isn't diffucult, took about 20mins
The vinyl I used for this and the roof was KPMF bought from here http://www.mdpsupplies.co.uk/vehiclewrappingvws1.asp Seems to get some decent reviews and isn't that expensive. I've used it a few time so have got a feel for how much heat/stretch it can take. It's quite a nice vinyl to work with. To remove the fin I gently levered it up enough to get a blade in to slice the sticky tape that holds it on - just be very careful not to scratch the paint. It's only held on by tape Once it's all done I'll post a pic of the finished roof. |
04-17-2015, 04:36 PM | #6 |
699
Rep 4,267
Good job there V
I'd recommend the 3m vinyl it has memory lock so once in place/shape it stays there.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
04-17-2015, 04:39 PM | #7 |
43
Rep 902
Relentlessone - technique, not sure I did it how it is meant to be done but it worked.
- Heat and stretch the vinyl first (learnt that from doing my wing mirrors) let it cool in the stretched position - wrap the flat back area first - pull it tight over the middle to the front (doesnt need to be perfect you'll be lifting it again) Work your way forward on the sides (lots of heat and lots of streching involved in this bit. - finish at the front point, you'll have loads of wrinkles on the front but one more big strech should get rid of them. - once wrinkle and bubble free, run the heatgun / hairdryer over the whole area getting it hot and then let it cool, this should make it train it's shape and not life. Finish by removing and wrinkle from the underside and trim accordingly. Happy to help anyone do this if you're local and have beer in the fridge |
04-18-2015, 11:19 PM | #8 | |
289
Rep 210
Thanks V! I've watched the video tutorial on the wing mirrors where they pre-stretched it, never thought to apply that technique. |
04-19-2015, 05:50 AM | #10 |
60
Rep 615
I've done loads of wrapping & believe me the best technique is just practise and patience..u'be just done my rear diffuser on Friday check the pics out on the UK bit of the forum..
As mentioned use good quality wrap lots of heat and a clean surface..I did my kindney grills yesterday it's the 2nd time this week i'be done them, now they are a pain. |
04-21-2015, 06:04 PM | #13 |
337
Rep 1,664
When I had mine done (professionally!), the tip for the spoiler was to do the small trailing edge first, then do the top surface. It may seem better to do it the other way, but I'm told that leaves the small surface area of the lip of the spoiler under stress which can cause it to lift over time - do it first to get it established, and then do the main spoiler after.
Mine's still OK after 2 years so far Mike |
